求助关于Jetson AGX Xavier 在Sdkmanager中刷机失败
1:59:01 ERROR: Flash Jetson Linux - flash: Error: Return value 4 11:59:01 INFO: Flash Jetson Linux - flash: Command tegradevflash_v2 --oem platformdetails eeprom cvb /home/czc/nvidia/nvidia_sdk/JetPack_5.1.5_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/bbd.bin 11:59:01 ERROR: Flash Jetson Linux - flash: — Error: Reading board information failed. 11:59:01 INFO: Flash Jetson Linux - flash: [OEMPreconfig] SDKM_INSTALL_ERROR [exec_command]: /bin/bash -c /home/czc/.nvsdkm/replays/scripts/JetPack_5.1.5_Linux/NV_L4T_FLASH_JETSON_LINUX_COMP.sh; [error]: Password for L4T new user Nvidia: — Error: Reading board information failed. 11:59:01 INFO: Flash Jetson Linux - flash: [ Component Install Finished with Error ] 11:59:01 INFO: Flash Jetson Linux - flash: [host] [ 3.05 MB released. Disk Avail on Partition /dev/sda5: 14.99 GB ] 11:59:01 INFO: Flash Jetson Linux - flash: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 16s ] 11:59:01 ERROR: Flash Jetson Linux - flash: command error code: 11 11:59:01 ERROR: Flash Jetson Linux - flash: command terminated with error 11:59:01 SUMMARY: Flash Jetson Linux - flash: Installation failed. 11:59:01 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component 11:59:01 SUMMARY: Multimedia API - target: Depends on failed component 11:59:01 SUMMARY: TensorRT on Target - target: Depends on failed component 11:59:01 SUMMARY: TensorRT Runtime - target: Depends on failed component 11:59:01 SUMMARY: VPI on Target - target: Depends on failed component 11:59:01 SUMMARY: VPI Runtime - target: Depends on failed component 11:59:01 SUMMARY: CuPVA Runtime - target: Depends on failed component 11:59:01 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component 11:59:01 SUMMARY: CUDA Runtime - target: Depends on failed component 11:59:01 SUMMARY: cuDNN on Target - target: Depends on failed component 11:59:01 SUMMARY: CuDNN Runtime - target: Depends on failed component 11:59:01 SUMMARY: OpenCV - target: Depends on failed component 11:59:01 SUMMARY: OpenCV Runtime - target: Depends on failed component 11:59:01 SUMMARY: DateTime Target Setup - target: Depends on failed component
我lssub命令显示Bus 001 Device 006: ID 0955:7e19 NVIDIA Corp.这是在刷机状态吧
我之前试过手动刷机,刷机成功了但是关机完第二次启动就进入UEFI界面了,然后就黑屏了,每次开机都这样
我还发现我用usb-typec接口连接的时候,刚连接时可以手动刷机的,但是过一段时间就不行了,但是lssub始终有连接,但是bootloader检测出了问题
我是严格按照文档里开启的recovery mode
Please provide the sdk manager full log by pressing EXPORT LOGS ins sdk manger.
Also, please record the serial console log at the same time.
Please make sure your device in recovery mode before flashing.
ImageVersion: ;
01:20:55.212 - info: Event: Session before ended
01:20:55.245 - warn: downloaded size is bigger then total
01:20:55.253 - warn: downloaded size is bigger then total
01:20:55.254 - warn: downloaded size is bigger then total
01:20:55.255 - warn: downloaded size is bigger then total
01:20:55.258 - warn: downloaded size is bigger then total
01:20:55.265 - warn: downloaded size is bigger then total
01:20:55.265 - error: progress monitor error: downloaded size is bigger than total size for NV_DEVTOOLS_TARGET_GROUP@JETSON_AGX_XAVIER_TARGETS
01:20:55.266 - warn: downloaded size is bigger then total
01:20:55.266 - error: progress monitor error: downloaded size is bigger than total size for NV_DEVTOOLS_TARGET_GROUP@JETSON_AGX_XAVIER_TARGETS
01:20:55.354 - info: Stopping all currently running download services
01:20:55.354 - info: Stopping the download for: https://developer.nvidia.com/downloads/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.1.5/Jetson_515_b11/./cudnn-local-tegra-repo-ubuntu2004-8.6.0.166_1.0-1_arm64.deb
01:20:55.355 - info: Stopping the download for: https://developer.nvidia.com/downloads/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.1.5/Jetson_515_b11/./cuda-repo-l4t-11-4-local_11.4.19-1_arm64.deb
01:20:55.355 - info: Stopping the download for: https://developer.nvidia.com/downloads/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.1.5/Jetson_515_b11/./nv-tensorrt-local-repo-l4t-8.5.2-cuda-11.4_1.0-1_arm64.deb
01:20:55.356 - info: Stopping the download for: https://developer.nvidia.com/downloads/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.1.5/Jetson_515_b11/./libnvidia-container0_0.11.0+jetpack_arm64.deb
01:20:55.356 - info: Stopping the download for: https://developer.nvidia.com/downloads/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.1.5/Jetson_515_b11/./libnvidia-container1_1.10.0-1_arm64.deb
01:20:55.356 - info: Stopping the download for: https://developer.nvidia.com/downloads/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.1.5/Jetson_515_b11/./libnvidia-container-tools_1.10.0-1_arm64.deb
01:20:55.356 - info: Stopping the download for: https://developer.nvidia.com/downloads/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.1.5/Jetson_515_b11/./nvidia-container-toolkit_1.11.0_rc.1-1_arm64.deb
01:20:55.356 - info: Stopping the download for: https://developer.nvidia.com/downloads/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.1.5/Jetson_515_b11/./nvidia-container-runtime_3.9.0-1_all.deb
01:20:55.356 - info: Stopping the download for: https://developer.nvidia.com/downloads/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.1.5/Jetson_515_b11/./nvidia-docker2_2.11.0-1_all.deb
01:20:55.356 - info: Stopping the download for: Log in | NVIDIA Developer
01:20:55.356 - info: Stopping the download for: https://developer.nvidia.com/downloads/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.1.5/Jetson_515_b11/./OpenCV-4.5.4-8-g3e4c170df4-aarch64-libs.deb
01:20:55.356 - info: Stopping the download for: https://developer.nvidia.com/downloads/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.1.5/Jetson_515_b11/./OpenCV-4.5.4-8-g3e4c170df4-aarch64-dev.deb
01:20:55.356 - info: Stopping the download for: https://developer.nvidia.com/downloads/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.1.5/Jetson_515_b11/./OpenCV-4.5.4-8-g3e4c170df4-aarch64-licenses.deb
01:20:55.357 - info: Stopping the download for: https://developer.nvidia.com/downloads/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.1.5/Jetson_515_b11/./OpenCV-4.5.4-8-g3e4c170df4-aarch64-python.deb
01:20:55.357 - info: Stopping the download for: https://developer.nvidia.com/downloads/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.1.5/Jetson_515_b11/./OpenCV-4.5.4-8-g3e4c170df4-aarch64-samples.deb
01:20:55.357 - info: Stopping the download for: https://developer.nvidia.com/downloads/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.1.5/Jetson_515_b11/./cupva-2.3.0-l4t.deb
01:20:55.357 - info: Stopping the download for: https://developer.nvidia.com/downloads/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.1.5/Jetson_515_b11/./vpi-lib-2.4.8-aarch64-l4t.deb
01:20:55.357 - info: Stopping the download for: https://developer.nvidia.com/downloads/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.1.5/Jetson_515_b11/./vpi-python3.8-2.4.8-aarch64-l4t.deb
01:20:55.357 - info: Stopping the download for: https://developer.nvidia.com/downloads/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.1.5/Jetson_515_b11/./vpi-python3.9-2.4.8-aarch64-l4t.deb
01:20:55.357 - info: Stopping the download for: https://developer.nvidia.com/downloads/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.1.5/Jetson_515_b11/./vpi-dev-2.4.8-aarch64-l4t.deb
01:20:55.357 - info: Stopping the download for: https://developer.nvidia.com/downloads/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.1.5/Jetson_515_b11/./vpi-samples-2.4.8-aarch64-l4t.deb
01:20:55.363 - info: Stopping the download for: https://developer.nvidia.com/downloads/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.1.5/Jetson_515_b11/./vpi-demos-2.4.8-aarch64-l4t.deb
01:20:55.363 - info: Event: Session ended - failure
01:20:55.364 - info: Setting SessionInitialStatus with value: Download: 100. Install: 80
01:20:55.364 - info: Setting custom dimension value SessionInitialStatus - Download: 100. Install: 80
01:20:55.365 - error: cannot get component by id undefined
01:20:55.365 - info: target duration: all (end time - start time): 00:00:13. duration summary: 00:00:13
01:20:55.366 - info: Setting custom dimension value Step3Selection - Target: Installed. Flash: Installed.
01:20:55.370 - info: Setting custom dimension value EventCategory - Install Jetson - finished failed
01:20:55.370 - info: Setting custom dimension value EventCategory2 - Install Jetson - finished failed
01:20:55.370 - info: Setting custom dimension value EventAction - 5.1.5.Linux.target.JETSON_AGX_XAVIER_TARGETS
01:20:55.370 - info: Setting custom dimension value EventLabel - RetryIndex: 0, Component: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_AGX_XAVIER_TARGETS#35.6, Error Code: 1011. Error: Failed to execute commands with GenericInstaller. Failed in flash: .
01:20:55.371 - info: Setting custom dimension value EventCategory - Retry Jetson - finished failed
01:20:55.371 - info: Setting custom dimension value EventCategory2 - Retry Jetson - finished failed
01:20:55.371 - info: Setting custom dimension value EventAction - 5.1.5.Linux.target.JETSON_AGX_XAVIER_TARGETS
01:20:55.371 - info: Setting custom dimension value EventLabel - RetryIndex: 0, Component: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_AGX_XAVIER_TARGETS#35.6, Error Code: 1011. Error: Failed to execute commands with GenericInstaller. Retry Trigger Component: . Retry Trigger Error Code: 0. Retry Trigger Error: .
01:20:55.372 - info: Session timing is: 00:00:52
01:20:55.373 - info: Session timing WITHOUT dialogs is: 00:00:13
01:20:55.376 - info: Setting custom dimension value Action - None
01:20:55.377 - error: completeSetup failed. Error:
01:20:55.378 - error: install process failure
01:20:55.382 - info:
********************** Completed install for bundle JetPack 5.1.5 Linux for Jetson AGX Xavier time: 17-Oct-2025-01.20:55 is succeeded: false **********************
01:20:55.417 - info: The overall duration (Download + Install) is 00:00:52
01:20:55.417 - info: *** Dialogs Timing Summary ***
pre_flash: duration: 00:00:38
*** End of Dialogs Timing Summary ***
01:20:55.426 - info:
*** Download Summary ***
    - Bundle: JetPack 5.1.5 Linux for Jetson AGX Xavier
    - Download server: DevZone
    - 0B downloaded of 7.91GB
    - Download started on: Fri Oct 17 2025 01:20:03 GMT-0700 (北美太平洋夏令时间).
    - Download ended on: Fri Oct 17 2025 01:20:55 GMT-0700 (北美太平洋夏令时间).
    - Download duration: 00:00:52.
    - Average total download speed: 0B/s = total downloaded bytes / download duration.
    - Average total bandwidth: 0B/s, average accumulation of all file chunk's speed, downloaded concurrently.
    - Average file chunk's download speed: 0B/s, average of all downloaded file chunk's speed.
    - Max 6 concurrent files using 12 threads.
    Total 24 files:
    - 0 downloaded, 22 cached, 0 failed, 2 skipped
    Details:
  • OpenCV-4.5.4-8-g3e4c170df4-aarch64-libs.deb: Cached.
  • cupva-2.3.0-l4t.deb: Cached.
  • vpi-python3.8-2.4.8-aarch64-l4t.deb: Cached.
  • vpi-python3.9-2.4.8-aarch64-l4t.deb: Cached.
  • vpi-lib-2.4.8-aarch64-l4t.deb: Cached.
  • nvidia-container-runtime_3.9.0-1_all.deb: Cached.
  • nvidia-container-toolkit_1.11.0_rc.1-1_arm64.deb: Cached.
  • libnvidia-container-tools_1.10.0-1_arm64.deb: Cached.
  • libnvidia-container1_1.10.0-1_arm64.deb: Cached.
  • libnvidia-container0_0.11.0+jetpack_arm64.deb: Cached.
  • nvidia-docker2_2.11.0-1_all.deb: Cached.
  • nvidia-l4t-jetson-multimedia-api_35.6.1-20250304015758_arm64.deb: Cached.
  • nv-tensorrt-local-repo-l4t-8.5.2-cuda-11.4_1.0-1_arm64.deb: Cached.
  • cudnn-local-tegra-repo-ubuntu2004-8.6.0.166_1.0-1_arm64.deb: Cached.
  • OpenCV-4.5.4-8-g3e4c170df4-aarch64-licenses.deb: Cached.
  • OpenCV-4.5.4-8-g3e4c170df4-aarch64-samples.deb: Cached.
  • OpenCV-4.5.4-8-g3e4c170df4-aarch64-dev.deb: Cached.
  • OpenCV-4.5.4-8-g3e4c170df4-aarch64-python.deb: Cached.
  • vpi-dev-2.4.8-aarch64-l4t.deb: Cached.
  • vpi-samples-2.4.8-aarch64-l4t.deb: Cached.
  • vpi-demos-2.4.8-aarch64-l4t.deb: Cached.
  • cuda-repo-l4t-11-4-local_11.4.19-1_arm64.deb: Cached.
*** End of Download Summary ***
01:20:55.429 - info:
*** Install summary of 20 components ***
    Install Jetson - JetPack 5.1.5 Linux for Jetson AGX Xavier - finished failed
	Failure root cause: Failed Component ID: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_AGX_XAVIER_TARGETS#35.6. Error Code: 1011. Error: Failed to execute commands with GenericInstaller.
    Install started on: 01:20:42 GMT-0700 (北美太平洋夏令时间).
    Install ended on: 01:20:55 GMT-0700 (北美太平洋夏令时间).
    Install duration:  00:00:13.
    Install idle time: 0.000s.
    Real install duration (duration - idle time): 00:00:13.
    Total 20 components: 0 installed, 2 up-to-date, 1 failed, 0 skipped, 17 dependency failures.
    Install details:
  • NV_L4T_DRIVERS_COMP@JETSON_AGX_XAVIER_TARGETS: Up-to-date.
  • NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_AGX_XAVIER_TARGETS: Up-to-date.
  • NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_AGX_XAVIER_TARGETS: Failed - 00:00:13 -start: 01:20:42 GMT-0700 (北美太平洋夏令时间) - end: 01:20:55 GMT-0700 (北美太平洋夏令时间).
  • NV_DATETIME_SETUP_TARGET_COMP@JETSON_AGX_XAVIER_TARGETS: DependencyFailure.
  • NV_L4T_CUDA_RUNTIME_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: DependencyFailure.
  • NV_L4T_CUDNN_RUNTIME_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: DependencyFailure.
  • NV_L4T_TENSORRT_RUNTIME_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: DependencyFailure.
  • NV_L4T_OPENCV_RUNTIME_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: DependencyFailure.
  • NV_L4T_CUPVA_RUNTIME_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: DependencyFailure.
  • NV_L4T_VPI_RUNTIME_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: DependencyFailure.
  • NV_L4T_DOCKER_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: DependencyFailure.
  • NV_L4T_MULTIMEDIA_API_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: DependencyFailure.
  • NV_L4T_CUDA_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: DependencyFailure.
  • NV_L4T_CUDNN_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: DependencyFailure.
  • NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: DependencyFailure.
  • NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: DependencyFailure.
  • NV_L4T_VPI_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: DependencyFailure.
  • : DependencyFailure.
*** End of Install Summary ***
01:20:55.436 - info: Engine.install is complete.
01:20:55.517 - info: Begin to send feedback. Feedback ID: 4yct9x1r.
01:20:55.583 - info: feedback body length: 235479
01:20:57.929 - info: Send feedback(4yct9x1r) succeed.
01:20:57.930 - info: Setting custom dimension value EventCategory - Send feedback finished - Succeeded
01:20:57.930 - info: Setting custom dimension value EventCategory2 - Send feedback finished - Succeeded
01:20:57.930 - info: Setting custom dimension value EventAction - General Feedback
01:20:57.930 - info: Setting custom dimension value EventLabel -
01:20:57.932 - info: Send GA install failure feedback succeed.
01:20:57.935 - error: null
01:21:03.141 - error: Event failed to send. Error: RequestError: connect ECONNREFUSED 216.239.34.178:443
01:21:03.142 - error: Failed to send GA4 event. Error: RequestError: connect ECONNREFUSED 216.239.34.178:443
01:21:03.142 - error: Event failed to send. Error: RequestError: connect ECONNREFUSED 216.239.34.178:443
01:21:16.382 - error: Event failed to send. Error: RequestError: connect ECONNREFUSED 216.239.34.178:443
01:21:16.383 - error: Event failed to send. Error: RequestError: connect ECONNREFUSED 216.239.34.178:443
01:21:16.384 - error: Event failed to send. Error: RequestError: connect ECONNREFUSED 216.239.34.178:443
01:21:16.385 - error: Event failed to send. Error: RequestError: connect ECONNREFUSED 216.239.34.178:443
01:21:16.386 - error: Event failed to send. Error: RequestError: connect ECONNREFUSED 216.239.34.178:443
01:21:16.387 - error: Event failed to send. Error: RequestError: connect ECONNREFUSED 216.239.34.178:443
01:21:16.388 - error: Event failed to send. Error: RequestError: connect ECONNREFUSED 216.239.34.178:443
01:21:16.388 - error: Failed to send GA4 event. Error: RequestError: connect ECONNREFUSED 216.239.34.178:443
01:21:16.389 - error: Event failed to send. Error: RequestError: connect ECONNREFUSED 216.239.34.178:443
01:21:16.522 - error: Event failed to send. Error: RequestError: connect ECONNREFUSED 216.239.34.178:443
01:21:16.523 - error: Event failed to send. Error: RequestError: connect ECONNREFUSED 216.239.34.178:443
01:21:16.524 - error: Failed to send GA4 event. Error: RequestError: connect ECONNREFUSED 216.239.34.178:443
01:21:16.525 - error: Failed to send GA4 event. Error: RequestError: connect ECONNREFUSED 216.239.34.178:443
01:21:18.969 - error: Event failed to send. Error: RequestError: connect ECONNREFUSED 216.239.34.178:443
01:21:18.970 - error: Failed to send GA4 event. Error: RequestError: connect ECONNREFUSED 216.239.34.178:443
01:21:55.102 - info: exporting logs from /home/czc/.nvsdkm/componentLogs/JetPack_5.1.5_Linux
Bus 003 Device 003: ID 0955:7019 NVidia Corp. 和文档上一致
czc@ubuntu:~/nvidia/nvidia_sdk/JetPack_5.1.5_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader$ sudo ./tegrarcm_v2 --instance 0 --uid[sudo] czc 的密码:
BR_CID: 0x88021911644101c8040000000e0282c0
Failed to read UID
刚开始通信检查可以,几秒后就不行了
czc@ubuntu:~/nvidia/nvidia_sdk/JetPack_5.1.5_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra$ sudo ./flash.sh jetson-agx-xavier-devkit internal
L4T BSP Information:
R35 , REVISION: 6.1
User release: 0.0
ECID is
Error: probing the target board failed.
czc@ubuntu:~/nvidia/nvidia_sdk/JetPack_5.1.5_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra$ lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 005: ID 0e0f:0002 VMware, Inc. Virtual USB Hub
Bus 003 Device 004: ID 0e0f:0002 VMware, Inc. Virtual USB Hub
Bus 003 Device 006: ID 0955:7019 NVidia Corp.
Bus 003 Device 002: ID 0e0f:0003 VMware, Inc. Virtual Mouse
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Hi
Based on the lsusb output showing 0955:7e19 NVIDIA Corp, your device appears to be a Jetson Xavier NX.
Please confirm if it is an AGX Xavier or a Xavier NX, and then run the corresponding commands
