Hi 6o9eumk1m,
As bryant.eadon suggested, please attempt to capture the serial messages for our review. You may find helpful information in the reference link provided below. NVIDIA Jetson Xavier - Serial Console (ridgerun.com)
I tried debugging using minicom as you suggested, but it didn’t work well. Instead, I checked the debug messages in the terminal of SDK Manager, and an error message appeared, as shown in the picture below. What can I do from here?
However, the message instructs me to detach the device using the usbipd detach command, but the board isn’t recognized, and it’s not even attached, so I can’t do anything. What should I do here?
It looks like you’re using Ubuntu via WSL.
Have you followed this documentation to set up WSL?
We recommend installing Ubuntu on a physical machine or using a dual boot setup (with both Windows and Linux).
