Jetson AGX zero-copy implementation: Using the function cudaImportExternalMemory to import reserved physical memory results in an error
We are hoping that Jetson AGX GPU core can directly access data in reserved contiguous physical memory space.
Step 1: Modify dtb file, set the reserved memory base address to 0xb0000000, and the length of the physical memory to 0x10000000. Then successfuly reboot the system.
Step 2: Open /dev/mem.
Step 3: Call mmap to map reserved physical memory.
Step 4: Call ‘cudaImportExternalMemory’ to import the fd of ‘/dev/mem’.
This step(Step 4) results in consistent error: Failed to import external memory: invalid arguement.
code snippet:
include
include <unistd.h>
include <fcntl.h>
include <sys/mman.h>
include <cuda_runtime.h>
const size_t PHYSICAL_MEM_BASE = 0xb0000000; // 外部物理内存的基地址
const size_t PHYSICAL_MEM_SIZE = 0x10000000; // 外部物理内存的大小
int main() {
int fd = open(“/dev/mem”, O_RDWR | O_SYNC);
if (fd == -1) {
std::cerr << “Failed to open /dev/mem\n”;
return 1;
// 映射外部物理内存到用户空间
void* physical_mem = mmap(0, PHYSICAL_MEM_SIZE, PROT_READ | PROT_WRITE, MAP_SHARED, fd, PHYSICAL_MEM_BASE);
if (physical_mem == MAP_FAILED) {
    std::cerr << "Failed to map physical memory\n";
    close(fd);
    return 1;
// 导入外部物理内存到 CUDA
cudaExternalMemory_t extMemObj;
cudaExternalMemoryHandleDesc handleDesc;
// 设置外部内存句柄类型和值(示例中使用外部物理内存的地址)
handleDesc.type = cudaExternalMemoryHandleTypeOpaqueFd;
handleDesc.handle.fd = fd;
cudaError_t err = cudaImportExternalMemory(&extMemObj, &handleDesc);
if (err != cudaSuccess) {
    std::cerr << "Failed to import external memory: " << cudaGetErrorString(err) << std::endl;
    munmap(physical_mem, PHYSICAL_MEM_SIZE);
    close(fd);
    return 1;
// 获取设备指针并在 CUDA 中使用
void* d_extMemPtr;
err = cudaExternalMemoryGetMappedBuffer(&d_extMemPtr, extMemObj, 0);
    std::cerr << "Failed to get mapped buffer: " << cudaGetErrorString(err) << std::endl;
    cudaDestroyExternalMemory(extMemObj);
    close(fd);
    return 1;
// 在这里可以使用 d_extMemPtr 来执行 CUDA 计算
// Use d_extMemPtr to execute Cuda computing
// 解除内存映射和关闭文件描述符
close(fd);
return 0;
Have you tried it with cudaExternalMemoryHandleTypeNvSciBuf?
Usually, we expect users to use NvSci on Jetson for memory handling.
Thank you for replying. Could you provide us an example?
Thanks,
Yezheng
@AastaLLL I have the same problem. In the Jetson Agx orin system, when modifying the dts file, reserving physical memory, open /dev/mem file to obtain fd, and using mmap function, then using the cudaImportExternalMemory function always reports “Failed to import external memory: invalid argument”. Can’t we use this function cudaImportExternalMemory,
Hi, both
Please find the NvSci example in the below link:
thanks!
@AastaLLL
Jetson AGX dtb is the following code, Could this mem region be used by NvSCI, Does this memory area require special labeling to be used by nvsci ?
“/reserved-memory {
#address-cells = <2>;
#size-cells = <2>;
ranges;
reserved_memory: memory@80000000 {
    reg = <0x0 0x80000000 0x0 0x10000000>;
    no-map;
If there are multiple reserved memory regions, how does nvSCI know which one to use ,thanks for your guidance
@AastaLLL
You will need to allocate the memory with NvSCI API.
Exporting a pre-allocated memory is not supported.
