Jetson_benchmarks got Error opening engine file
Hi All,
I run jetson_benchmark in Orin Nano 4G.
I got 0 FPS using the command
sudo python3 benchmark.py --model_name inception_v4 --csv_file_path home/orin_nano/jetson_benchmarks/benchmark_csv/orin-nano-benchmarks.csv --model_dir /home/orin_nano/jetson_benchmarks/models/ --jetson_clocks
I check the log in modules file, I got “Error opening engine file”.
I have already tried to change the inception_v4 WS_GPU to 1024 and 512 but it got the same result.
Could you give some suggestion?
inception_v4_b32_ws512_gpu.txt (4.8 KB)
The error indicates that it cannot find the TensorRT engine.
Have you applied the setup command below?
Yes, I have already follow the" Set up instructions" and " Install Requirements".
Could you check if the download_models.py save all the required model successfully?
For example, we save the model to $(pwd)/models with the below command:
$ python3 utils/download_models.py --all --csv_file_path benchmark_csv/orin-nano-benchmarks.csv --save_dir $(pwd)/models
Within $(pwd)/models, we can find all the models are downloaded:
$ ll models/
total 210996
drwxrwxr-x 2 nvidia nvidia     4096 Sep  4 05:39 ./
drwxrwxr-x 6 nvidia nvidia     4096 Sep  4 05:37 ../
-rw-rw-r-- 1 nvidia nvidia   120973 Sep  4 05:38 inception_v4.prototxt
-rw-rw-r-- 1 nvidia nvidia    22561 Sep  4 05:39 mobilenet_v1_ssd.prototxt
-rw-rw-r-- 1 nvidia nvidia    45979 Sep  4 05:39 pose_estimation.prototxt
-rw-rw-r-- 1 nvidia nvidia    35016 Sep  4 05:39 ResNet50_224x224.prototxt
-rw-rw-r-- 1 nvidia nvidia    32058 Sep  4 05:39 ssd_resnet34_1200x1200.prototxt
-rw-rw-r-- 1 nvidia nvidia   273491 Mar 12  2020 super_resolution_bsd500-bs1.onnx
-rw-rw-r-- 1 nvidia nvidia   273491 Mar 12  2020 super_resolution_bsd500-bs2.onnx
-rw-rw-r-- 1 nvidia nvidia   273491 Mar 12  2020 super_resolution_bsd500-bs4.onnx
-rw-rw-r-- 1 nvidia nvidia   273491 Mar 12  2020 super_resolution_bsd500-bs8.onnx
-rw-rw-r-- 1 nvidia nvidia  1971389 Sep  4 05:39 unet-segmentation.uff
-rw-rw-r-- 1 nvidia nvidia     5936 Sep  4 05:38 vgg19_N2.prototxt
-rw-rw-r-- 1 nvidia nvidia 35448300 Sep 28  2022 yolov3-tiny-416-bs16.onnx
-rw-rw-r-- 1 nvidia nvidia 35448300 Sep 28  2022 yolov3-tiny-416-bs1.onnx
-rw-rw-r-- 1 nvidia nvidia 35448300 Sep 28  2022 yolov3-tiny-416-bs2.onnx
-rw-rw-r-- 1 nvidia nvidia 35448628 Sep 28  2022 yolov3-tiny-416-bs32.onnx
-rw-rw-r-- 1 nvidia nvidia 35448300 Sep 28  2022 yolov3-tiny-416-bs4.onnx
-rw-rw-r-- 1 nvidia nvidia 35447411 Sep 28  2022 yolov3-tiny-416-bs8.onnx
HI,
I checked $(pwd)/models,
$ ll models/
total 210996
drwxr-xr-x 2 orin_nano orin_nano     4096  九   5 17:15 ./
drwxr-xr-x 6 root      root          4096  八  31 13:42 ../
-rw-rw-r-- 1 orin_nano orin_nano   120973  九   5 17:13 inception_v4.prototxt
-rw-rw-r-- 1 orin_nano orin_nano    22561  九   5 17:15 mobilenet_v1_ssd.prototxt
-rw-rw-r-- 1 orin_nano orin_nano    45979  九   5 17:13 pose_estimation.prototxt
-rw-rw-r-- 1 orin_nano orin_nano    35016  九   5 17:15 ResNet50_224x224.prototxt
-rw-rw-r-- 1 orin_nano orin_nano    32058  九   5 17:15 ssd_resnet34_1200x1200.prototxt
-rw-rw-r-- 1 orin_nano orin_nano   273491  三  12  2020 super_resolution_bsd500-bs1.onnx
-rw-rw-r-- 1 orin_nano orin_nano   273491  三  12  2020 super_resolution_bsd500-bs2.onnx
-rw-rw-r-- 1 orin_nano orin_nano   273491  三  12  2020 super_resolution_bsd500-bs4.onnx
-rw-rw-r-- 1 orin_nano orin_nano   273491  三  12  2020 super_resolution_bsd500-bs8.onnx
-rw-rw-r-- 1 orin_nano orin_nano  1971389  九   5 17:13 unet-segmentation.uff
-rw-rw-r-- 1 orin_nano orin_nano     5936  九   5 17:13 vgg19_N2.prototxt
-rw-rw-r-- 1 orin_nano orin_nano 35448300  九  28  2022 yolov3-tiny-416-bs16.onnx
-rw-rw-r-- 1 orin_nano orin_nano 35448300  九  28  2022 yolov3-tiny-416-bs1.onnx
-rw-rw-r-- 1 orin_nano orin_nano 35448300  九  28  2022 yolov3-tiny-416-bs2.onnx
-rw-rw-r-- 1 orin_nano orin_nano 35448628  九  28  2022 yolov3-tiny-416-bs32.onnx
-rw-rw-r-- 1 orin_nano orin_nano 35448300  九  28  2022 yolov3-tiny-416-bs4.onnx
-rw-rw-r-- 1 orin_nano orin_nano 35447411  九  28  2022 yolov3-tiny-416-bs8.onnx
the result is same as yours but run $ sudo python3 benchmark.py --all --csv_file_path /home/orin_nano/jetson_benchmarks/benchmark_csv/orin-nano-benchmarks.csv --model_dir /home/orin_nano/jetson_benchmarks/models/ --jetson_clocks , it still got 0 FPS and Error in Build,the log is still the same.
Thanks for the info.
We will check it further.
Will get back to you soon.
We can get the inception_v4 result.
Could you double-check it again?
$ sudo python3 benchmark.py --all --csv_file_path benchmark_csv/orin-nano-benchmarks.csv --model_dir $(pwd)/models --jetson_clocks
Please close all other applications and Press Enter to continue...
Setting Jetson orin in max performance mode
Jetson clocks are Set
Running all benchmarks.. This will take at least 2 hours...
------------Executing inception_v4------------
---------------------- 89.2536105263158 0 0
Model Name: inception_v4
FPS:358.53
