Jetson Board with WiFi connectivity
Sir/Ma`am,
Pardon me if this point is already discussed here, since I’m new to this.
I’m working on an application that requires WiFi to be integrated with my board. After referring some videos and Jetson product specifications, I could conclude that some of the boards under Jetson series can support WiFi. After exploring Intel WiFi chipsets, I could converge on Intel® Wireless-AC 9260. Can you please confirm which Jetson board will be most suitable to integrate this chipsets? I’m looking for industrial grade chipsets with minimal power consumption requirements.
Thanks and Regards,
H C Trivedi
You can refer to:
Jetson Orin NX Series and Jetson Orin Nano Series Supported Component List
Jetson AGX Orin Series Supported Component List
@kayccc Many thanks for the prompt response.
While I explored the specifications of Jetson Orin series, I feel that end product will be an over design as I probably won’t need these many resources. On the same line, can Jetson Xavier series (or for that matter any other industrial grade module) meet my end requirements (listed below). And also, for other Jetson series, supported component list available?
  1. Receive video stream over Ethernet.
  2. Transmit received stream over WiFi
  3. Display wirelessly received stream
  4. transmit the received wireless stream over Ethernet.
  5. operational environment: industrial / automotive grade can be considered.
Thanks and Regards,
H C Trivedi
Except AGX Orin industrial module, then you can think to use AGX Xavier industrial module instead, please refer to Jetson AGX Xavier Series Supported Component List
Hello @kayccc
I had explored this module from intel earlier. But intel says this product is discontinued. Link is provided below for your ready reference.
https://www.intel.com/content/www/us/en/products/sku/94150/intel-dual-band-wirelessac-8265/specifications.html
As that module was lnuchaed at couple years ago, you can do the search in AGX Xavier forum to know what other users are using as reference: Latest Jetson & Embedded Systems/Jetson AGX Xavier topics - NVIDIA Developer Forums
We don’t have the recommanded list.
hello @kayccc ,
Can you please share environmental specifications for Jetson Orin NX series?
