JETSON CLOCK issues
I am currently experiencing an issue with date and time resetting after system shutdown on my Jetson device. The system in use is an NVIDIA Jetson Thor (128GB) running a Linux-based environment with containerized workloads (Docker, vLLM, Open WebUI, and PostgreSQL). After powering off and restarting the device, the system clock does not retain the correct date and time, resulting in incorrect timestamps that affect system logs, scheduled services, and network-dependent operations.
I would like to understand the root cause of this behavior and determine the appropriate solution to ensure time persistence across reboots. Specifically, I am looking for clarification on whether this issue is related to RTC (Real-Time Clock) configuration, absence of a backup power source (such as a CMOS/RTC battery), or NTP synchronization settings on Jetson platforms.
Additionally, I would appreciate guidance on how to properly resolve this issue. From my initial understanding, potential fixes may include enabling and verifying NTP synchronization (timedatectl set-ntp true), manually syncing the hardware clock using hwclock --systohc, or checking whether the device relies solely on system time without a battery-backed RTC. If Jetson Thor lacks a persistent RTC backup, I would also like to know the recommended approach (e.g., configuring automatic time sync on boot or using an external RTC module) to ensure accurate timekeeping across reboots.
Any insights into best practices for maintaining consistent system time on Jetson devices would be greatly appreciated.
If you have enable the NTP the system should resynchronize the time after connect to network atuomatically.
