Jetson Clocks have default value "running"
I’m using the Orin Nano. According to this post, it seems that ‘jetson clocks’ should not be ‘running’ at boot time. However, when I use jtop, I find that its default state at boot is ‘running’. I would like to know how to enable the DVFS governor.
Could you check with tegrastats?
Here is the tegrastas output:
jetson@unbutu:~$ sudo tegrastats
05-04-2024 06:14:14 RAM 1151/6481MB (lfb 1099x4MB) SWAP 0/3240MB (cached 0MB) CPU [0%@1510,0%@1510,0%@1510,0%@1510,0%@1510,0%@1510] EMC_FREQ 0%@2133 GR3D_FREQ 0%@624 GR3D2_FREQ 0%@0 VIC_FREQ 435 APE 200 CV0@-256C CPU@48.5C SOC2@47.718C SOC0@46.718C CV1@-256C GPU@47.843C tj@48.5C SOC1@47.187C CV2@-256C VDD_IN 5102mW/5102mW VDD_CPU_GPU_CV 946mW/946mW VDD_SOC 1461mW/1461mW
05-04-2024 06:14:15 RAM 1150/6481MB (lfb 1097x4MB) SWAP 0/3240MB (cached 0MB) CPU [0%@1510,0%@1510,0%@1510,0%@1510,0%@1510,0%@1510] EMC_FREQ 0%@2133 GR3D_FREQ 0%@624 GR3D2_FREQ 0%@0 VIC_FREQ 435 APE 200 CV0@-256C CPU@48.781C SOC2@47.687C SOC0@46.75C CV1@-256C GPU@47.906C tj@48.781C SOC1@47.343C CV2@-256C VDD_IN 5062mW/5082mW VDD_CPU_GPU_CV 946mW/946mW VDD_SOC 1461mW/1461mW
05-04-2024 06:14:16 RAM 1150/6481MB (lfb 1097x4MB) SWAP 0/3240MB (cached 0MB) CPU [0%@1510,0%@1510,0%@1510,0%@1510,0%@1510,0%@1510] EMC_FREQ 0%@2133 GR3D_FREQ 0%@624 GR3D2_FREQ 0%@0 VIC_FREQ 435 APE 200 CV0@-256C CPU@48.562C SOC2@47.656C SOC0@46.781C CV1@-256C GPU@48.156C tj@48.562C SOC1@47.312C CV2@-256C VDD_IN 5054mW/5072mW VDD_CPU_GPU_CV 906mW/932mW VDD_SOC 1461mW/1461mW
^C
and nvpmodel:
jetson@unbutu:~$  sudo nvpmodel -q
NV Power Mode: 15W
0
What is the jetpack version you are using?
Version: 5.1.1-b56
I wonder if this is because the seller made some settings before I purchased the device? Is it possible to switch back to DVFS mode through a command?
Jetson clocks should not run by default as you said. Your situation is abnormal.
Is it a custom board or NV devkit?
It is an NV devkit. But I’m using the SSD provided by the seller along with the OS they supplied.
I guess they enabled jetson clocks by default.
Thank you, Wayne. I will seek help from the seller.
I have another question I’d like to inquire about:
I am writing a script to capture the power consumption of the device, hoping to output the device’s VDD_IN/VDD_CPU_GPU_CV/VDD_SOC by usingsudo tegrastats. The script works well on the Orin Nano.
But the output of sudo tegrastats on the AGX Xavier (for the power consumption part) is:
GPU 0mW/0mW CPU 456mW/456mW SOC 1064mW/1064mW CV 0mW/0mW VDDRQ 152mW/152mW SYS5V 1650mW/1650mW
It seems I cannot directly obtain the values of VDD_CPU_GPU_CV/VDD_IN like on the Orin Nano. I wonder if these can be calculated? For example, can VDD_CPU_GPU_CV be calculated by adding GPU+CPU+CV? Can VDD_IN be calculated by adding CPU+GPU+SOC+VDDRQ+SYS5V?
Once again, thanks for your help.
You could refer to this document for detail.
https://docs.nvidia.com/jetson/archives/r35.5.0/DeveloperGuide/SD/PlatformPowerAndPerformance/JetsonOrinNanoSeriesJetsonOrinNxSeriesAndJetsonAgxOrinSeries.html#jetson-orin-nx-series-and-jetson-orin-nano-series
