I have two fresh dockers built…is it docker not cleaning up after a build or is it the Jetson containers just being huge, over 500GB of disk space needed for a 10GB image
There are server containers and you can pick one which fitting your use-case. For example, if you need only CUDA, you can use
And it is possible for certain use-cases, the container is with large size.
