Jetson-containers help pages dead links
Folks,
Trying to run jetson-containers build w args command fails.
Jetpack 6.2 install CUDNN_VERSION==9.3.0.
Previous documents describe using environment variables to control the versions, as linked below.
Seems the method has changed. How can it be specified?
Thank you
CUDNN_VERSION=9.8.0 jetson-containers build --build-flags '--build-arg CUDNN_VERSION="9.8.0"' jupyterlab python:3.12 cuda-python:12.6 jax:0.6.2
Package Environment Variable Versions
cuda CUDA_VERSION cuda/config.py
cudnn CUDNN_VERSION cudnn/config.py
tensorrt TENSORRT_VERSION tensorrt/config.py
python PYTHON_VERSION python/config.py
pytorch PYTORCH_VERSION pytorch/config.py
ubuntu LSB_RELEASE l4t_version.py
cuda CUDA_ARCH l4t_version.py
I see CUDNN_VERSION==9.3.0 is used CUDA_VERSION=12.8, thanks
