Hi All,
I use argus
to obtain images from csi camera. The camera sensor pipeline may be like this.
sensor->csi->vi->ISP->argus consumer
After building the output stream and sending capture request using argus::repeat()
, I want to know where the frames will be stored if the argus consumer
don’t read them. More specially, I want to know the frames will be stored before the ISP or after the ISP.
Thanks in advances,
snowtp
Hi there @snowtp,
I took the liberty and moved your post to the Jetson category.
Please share which Jetson platform exactly you are using, then the Jetson experts can narrow down how best to assist you.
hello snowtp,
may I know what’s the actual use-case? please share more details. thanks
