Hi @chinami556, perhaps you can expand more on what you are trying to integrate Jetson with. Is your aim to send video from the x86 system, and do processing on the Jetson? Generally video transport would be done over a network connection (ideally gigabit ethernet). Using the networking stacks (i.e. UDP/TCP) are pretty much the same between x86 and ARM. In many cases it would be similar to if you were sending the data between two x86 machines.
