This is a known issue. Please find below for more info:
| Iptables error message | 3 | 197 | June 4, 2025 | |
| Docker compose - Unable to enable Direct Access Filtering on Jetson Orin Nano Super | 2 | 369 | March 27, 2025 | |
| Problems with Docker version 28.0.1 on Jetson Orin NX | 31 | 4408 | April 7, 2025 | |
| Issue with Docker Compose Port Mapping on Jetson Orin Nano – iptable_raw Module Missing | 4 | 228 | July 1, 2025 | |
| Anyone else having issues with docker in JP6.1(rev1) - specifically network bridge adaptor | 2 | 64 | December 19, 2024 | |
| Another solution with iptables raw issue | 3 | 689 | June 16, 2025 | |
| Docker error: failed to start daemon: Error initializing network controller | 4 | 606 | December 2, 2024 | |
| Docker fail to start jetson nano after clean install of jetpack 6.2 (fix it) | 4 | 421 | March 10, 2025 | |
| JetPack 6.0 docker integration broken exposing ports | 2 | 213 | March 11, 2025 | |
| Any software update to JetPack 6.0 causes docker to fail | 9 | 1957 | March 26, 2024 |
