Jetson doesn't connect to keyboard/mouse nor ssh
Till yesterday, I was able to ssh into the jetson using a mutually shared hotspot between jetson and the host. Today, jetson won’t connect to it.
I thought of changing the WiFi connection and connected it to a screen, mouse and a keyboard. The screen on boot up shows the log:
The jetson is working on 15W power mode and I am brought to the loging screen but mouse or keyboard won’t work. The keyboard did work in the first attempt but now it doesn’t.
Lastly, I tried to $ ssh jetson@192.168.55.1 where jetson is my user. And there is no response except
ssh: connect to host 192.168.55.1 port 22: Connection timed out
With ping 192.168.55.3, there is no response.
What has gone wrong with it ?
Can you post a serial console boot log? Also, with serial console, you should be able to log in and check the output of “ifconfig” to see if the address changed or failed to assign to networking.
