Making progress using a REAL PC , but not quite there. Goal is to flash LINUX and ALL the components. Here is what happens:
- I select ALL components - UNIX, real time etc.
- After configuration for manual, able to flash LINUX OS
- I disconnect the (force) jumper while the LINUX flashing is taking place
- At the end of LINUX flash, I get the prompt AGAIN to flash etc., instead of flashing
the rest of the SDK components. * Not quite sure how to proceed here. - Result is that LINUX has been flashed, but none of the rest of components
I am NOT able to flash the components. The system does boot, but I am missing many run time components, which cause issues during jetson-inference.
- Why does the flash process , after LINUX, not flash the rest of the components?
- Specifically, what components do I need to flash to run the containers in “jetson_inference”.
Thx
