Jetson Image Creator
I tried to create ajetson disk image using
"jetson-disk-image-creator.sh " script with following command :
sudo ./jetson-disk-image-creator.sh -o sd-blob.img -b jetson-agx-orin-devkit -d SD
But when i executed this i came across the following error:
Chip SKU(00:00:00:D0) ramcode() fuselevel(fuselevel_production) board_FAB()
Error: Unrecognized module SKU
Can anyone help me.
I have also attached the screenshot of the terminal
AGX Orin has eMMC memory, and does not use the SD card image. The boot stages don’t have the driver unless you have a third party carrier board (in which case the third party has to provide the driver via its board support package). One would normally flash eMMC for an AGX Orin.
i want to create for an eMMC memory only, for that how do i create an image on host pc?
Also i would like to know whether and how can i create a backup of the complete disk and the reflash it again?
You just flash, and after flash, you will find these files:
  • Linux_for_Tegra/bootloader/system.img (a sparse file)
  • Linux_for_Tegra/bootloader/system.img.raw (a raw file)
The above would be true regardless of whether you flash on command line or via JetPack/SDKM. If you want to generate this without actually flashing, then you’d use command line. An example with flash:
sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1
A variation of this, which does not actually flash:
sudo ./flash.sh --no-flash jetson-agx-orin-devkit mmcblk0p1
Incidentally, sometimes the --no-flash is used to create a signed version of the non-rootfs content. During a flash all partitions, except for rootfs/APP, are signed before being flashed. The default is a NULL key, but the other non-rootfs content is still signed before flashing. Those signed files would normally be deleted after flash, but the --no-flash can be used to keep those files around as well as for creating system.img and system.img.raw.
If you have a Jetson set up the way you like it, then instead of generating an image on the host PC via the sample rootfs, you could instead do one of these:
  • Clone the rootfs/APP partition using a recovery mode Jetson and command line. Example:
    sudo ./flash.sh -r -k APP -G my_backup.img jetson-agx-orin-devkit mmcblk0p1
    (produces raw clone my_backup.img.raw and sparse clone my_backup.img)
  • Use standard tools such as rsync to do a network backup of the rootfs.
both the sparse and the raw file where not present after flashing
Does the host PC have enough disk space? If this fails during creation, then no file will exist. From the location where the “Linux_for_Tegra/bootloader/” directory exists (cd there), what do you see from:
df -H -T .
(the trailing “.” is important…it means “the current directory”)
