I’m working with jetson inference and am trying to collect my own dataset and training the model. I created a folder called “example” in jetson-inference/python/training/classification/data and made the txt file. Then, I ran the camera-capture dev/video0 command on terminal. When I put the paths to the folder and the txt file, I get an error saying “failed to create data set subdirectory //train” “failed to create data set subdirectory //val” “failed to create data set subdirectory //test”. I think this might be the issue? Am I inserting the wrong path?
Anyways, after I collect the images, I run the command “python3 train.py --model-dir=models/example data/example”. But then I get this:
Use GPU: 0 for training
=> dataset classes: 2 ['airpods', 'lysol']
File "train.py", line 506, in <module>
main()
File "train.py", line 135, in main
main_worker(args.gpu, ngpus_per_node, args)
File "train.py", line 191, in main_worker
normalize,
File "/usr/local/lib/python3.6/dist-packages/torchvision-0.7.0a0+78ed10c-py3.6-linux-aarch64.egg/torchvision/datasets/folder.py", line 208, in __init__
is_valid_file=is_valid_file)
File "/usr/local/lib/python3.6/dist-packages/torchvision-0.7.0a0+78ed10c-py3.6-linux-aarch64.egg/torchvision/datasets/folder.py", line 100, in __init__
raise RuntimeError(msg)
RuntimeError: Found 0 files in subfolders of: data/example/val
Supported extensions are: .jpg,.jpeg,.png,.ppm,.bmp,.pgm,.tif,.tiff,.webp
I think the issue might be that there isnt anything in my val folder?? But I’m not sure what’s supposed to be in my val folder? The captured images are all in the train folder
