jetson_inference.detectNet('ssd-mobilenet-v2') too slow
I used a humble node publishing video stream , and trying to use another humble node to receive the video on AGX Orin. the performance of detectNet is too slow. it only can output detect result in 5 seconds per frame.
Can someone give me some suggestions about how to import the speed? Thank you in advance!
And the code in Python.
[TRT]
[TRT] device GPU, /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff initialized.
[TRT] W = 7 H = 100 C = 1
[TRT] detectNet – maximum bounding boxes: 100
[TRT] loaded 91 class labels
[TRT] detectNet – number of object classes: 91
[TRT] loaded 0 class colors
[TRT] didn’t load expected number of class colors (0 of 91)
[TRT] filling in remaining 91 class colors with default colors
detected 1 objects in image
<detectNet.Detection object>
– Confidence: 0.679688
– ClassID: 1
– Left: 222.188
– Top: 2.63672
– Right: 612.188
– Bottom: 357.363
– Width: 390
– Height: 354.727
– Area: 138343
– Center: (417.188, 180)
jetson.inference – detectNet loading custom model ‘(null)’
detectNet – loading detection network model from:
– model networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff
– input_blob ‘Input’
– output_blob ‘NMS’
– output_count ‘NMS_1’
– class_labels networks/SSD-Mobilenet-v2/ssd_coco_labels.txt
– threshold 0.500000
– batch_size 1
[TRT] TensorRT version 8.6.2
Most of the elapsed time is used for initialization and pipeline setup.
This is a one-time job when creating the inference.
You can try to feed a video or camera source to check the real latency.
Hi!
Thank you for your quick reply!
But I kept running the code for more than 20 minutes. The initialization should be done at beginning. The elapsed time between different detections is too long: 3~5 minutes.
Do you have any suggestions for such case that have to use ROS image for objects detection?
Could you share the command you execute?
Do you use a camera/video input or image?
The main code are:
net = jetson_inference.detectNet(‘ssd-mobilenet-v2’)
self.create_subscription(Image, “/camera/image_color”, self.has_received_image2,qos_profile=1)
a loop:
img = self.bridge.imgmsg_to_cv2(ros_image, desired_encoding=‘passthrough’)
frame_rgb = cv2.cvtColor(img, cv2.COLOR_BGR2RGB)
img_cuda = jetson_utils.cudaFromNumpy(frame_rgb)
detections = net.Detect(img_cuda, overlay=“box,labels,conf”)
The loop includes data reader, conversion, memcpy, and finally inference.
Please try to update the loop with only inference for the benchmarking.
For example:
# a loop:
Thank you for your reply!
in my previous loop, i put net = jetson_inference.detectNet(‘ssd-mobilenet-v2’) in the loop. It’s OK now just took net = jetson_inference.detectNet(‘ssd-mobilenet-v2’) out of the loop.
we can close this case now. and thank you again!
