Jetson-inference failed to load network
Hello
I have a question about jetson-inference.
I use jetson Xavier NX developer kit and jetpack4.4.
I tried to move the sample code with reference to dusty’s video.
(https://www.youtube.com/watch?v=bcM5AQSAzUY&t=480s)
However, I couldn’t run sample code.
Error
Exception: jetson-inference – detectNet failed to load network
By the way, I tried other detectNet code but it doesn’t work as well
I’m a beginner, so I can’t figure out the cause.
help me!!
Thank you
Hi @kazuki.yumiba, can you post the full console log of when you try to run the program?
Can you also check that the models were downloaded to your jetson-inference/data/networks/ directory? For example, you should have the file jetson-inference/data/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff
If you are missing the models, you can try downloading them again like this:
$ cd jetson-inference/build
$ ./download-models.sh
Hi dusty_nv.
Thank you for reply!
I tried your suggestions.
I was able to run the code thanks to your suggestions.
However, There is one concern.
When I ran my code, Red letters appear
could not register plugin creater - ::FlattenConect_TRT version 1
Is it OK?
If you know anything please tell me?
Thank you.
You can safely ignore the error, so not to worry.
Hi ! dusty_nv.
I deeply thank you for always providing the best suggestion and the best code.
If you are in trouble again, please help.
Thank you.
