Hi - Can DetectNet live camera example found in the Jetson-inference Github page be able to use a different network. For example, instead of using Detectnet network, I use faster R-CNN.
Best,
Zack
Best,
Zack
Hi Zack, yes you can substitute network in detectnet-camera program by using command line arguments similar to those used in this step:
https://github.com/dusty-nv/jetson-inference#processing-images-from-the-command-line-on-jetson
Use this kind of command line:
$ ./detectnet-camera \
--prototxt=$NET/deploy.prototxt \
--model=$NET/snapshot_iter_38600.caffemodel \
--input_blob=data \
--output_cvg=coverage \
--output_bbox=bboxes
