i went through the 2 days to a demo and tried out the following python-code. My question is, is it possible to fit my own keras-network in instead of googlenet and if so, where can i find the code to adapt that?
width = 640
height = 480
network = "googlenet"
camera = "/dev/video0"
# load the recognition network
net = jetson.inference.imageNet(network, [])
# create the camera and display
font = jetson.utils.cudaFont()
camera = jetson.utils.gstCamera(width, height, camera)
display = jetson.utils.glDisplay()
while display.IsOpen():
# capture the image
img, width, height = camera.CaptureRGBA()
#classify the image
class_idx, confidence = net.Classify(img, width, height)
#find the object description
class_desc = net.GetClassDesc(class_idx)
#overlay the result on the image
font.OverlayText(img, width, height, "{:05.2f}% {:s}".format(confidence * 100, class_desc), 5, 5, font.White, font.Gray40)
#render the image
display.RenderOnce(img, width, height)
#update the title bar
display.SetTitle("{:s} | Network {:.0f} FPS".format(net.GetNetworkName(), 1000.0 / net.GetNetworkTime()))
Thank you for your help.
You will need to convert the keras model into .uff file first.
Here is a sample for your reference: /usr/src/tensorrt/samples/python/uff_ssd/
After having the uff file, you can follow this page to feed a customized model:
https://github.com/dusty-nv/jetson-inference/blob/master/docs/imagenet-custom.md
I will try it out and give feedback, thank you
In the /usr/src/tensorrt/samples/python/uff_ssd/ sample, I tried to exexcute the requirements.txt but it got stuck at Pycuda installation.
Building wheels for collected packages: pycuda
Building wheel for pycuda (setup.py) ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-yz75nu2i/pycuda/setup.py'"'"'; __file__='"'"'/tmp/pip-install-yz75nu2i/pycuda/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-wq06hbq4 --python-tag cp36
cwd: /tmp/pip-install-yz75nu2i/pycuda/
Complete output (106 lines):
*** WARNING: nvcc not in path.
*** May need to set CUDA_INC_DIR for installation to succeed.
*** I have detected that you have not run configure.py.
*** Additionally, no global config files were found.
*** I will go ahead with the default configuration.
*** In all likelihood, this will not work out.
*** See README_SETUP.txt for more information.
*** If the build does fail, just re-run configure.py with the
*** correct arguments, and then retry. Good luck!
*** HIT Ctrl-C NOW IF THIS IS NOT WHAT YOU WANT
Continuing in 1 seconds...
/usr/lib/python3.6/distutils/dist.py:261: UserWarning: Unknown distribution option: 'test_requires'
warnings.warn(msg)
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-aarch64-3.6
creating build/lib.linux-aarch64-3.6/pycuda
copying pycuda/debug.py -> build/lib.linux-aarch64-3.6/pycuda
copying pycuda/elementwise.py -> build/lib.linux-aarch64-3.6/pycuda
copying pycuda/characterize.py -> build/lib.linux-aarch64-3.6/pycuda
copying pycuda/curandom.py -> build/lib.linux-aarch64-3.6/pycuda
copying pycuda/driver.py -> build/lib.linux-aarch64-3.6/pycuda
copying pycuda/reduction.py -> build/lib.linux-aarch64-3.6/pycuda
copying pycuda/gpuarray.py -> build/lib.linux-aarch64-3.6/pycuda
copying pycuda/autoinit.py -> build/lib.linux-aarch64-3.6/pycuda
copying pycuda/_cluda.py -> build/lib.linux-aarch64-3.6/pycuda
copying pycuda/scan.py -> build/lib.linux-aarch64-3.6/pycuda
copying pycuda/tools.py -> build/lib.linux-aarch64-3.6/pycuda
copying pycuda/_mymako.py -> build/lib.linux-aarch64-3.6/pycuda
copying pycuda/__init__.py -> build/lib.linux-aarch64-3.6/pycuda
copying pycuda/cumath.py -> build/lib.linux-aarch64-3.6/pycuda
copying pycuda/compiler.py -> build/lib.linux-aarch64-3.6/pycuda
creating build/lib.linux-aarch64-3.6/pycuda/gl
copying pycuda/gl/autoinit.py -> build/lib.linux-aarch64-3.6/pycuda/gl
copying pycuda/gl/__init__.py -> build/lib.linux-aarch64-3.6/pycuda/gl
creating build/lib.linux-aarch64-3.6/pycuda/sparse
copying pycuda/sparse/coordinate.py -> build/lib.linux-aarch64-3.6/pycuda/sparse
copying pycuda/sparse/pkt_build.py -> build/lib.linux-aarch64-3.6/pycuda/sparse
copying pycuda/sparse/cg.py -> build/lib.linux-aarch64-3.6/pycuda/sparse
copying pycuda/sparse/inner.py -> build/lib.linux-aarch64-3.6/pycuda/sparse
copying pycuda/sparse/packeted.py -> build/lib.linux-aarch64-3.6/pycuda/sparse
copying pycuda/sparse/__init__.py -> build/lib.linux-aarch64-3.6/pycuda/sparse
copying pycuda/sparse/operator.py -> build/lib.linux-aarch64-3.6/pycuda/sparse
creating build/lib.linux-aarch64-3.6/pycuda/compyte
copying pycuda/compyte/array.py -> build/lib.linux-aarch64-3.6/pycuda/compyte
copying pycuda/compyte/dtypes.py -> build/lib.linux-aarch64-3.6/pycuda/compyte
copying pycuda/compyte/__init__.py -> build/lib.linux-aarch64-3.6/pycuda/compyte
running egg_info
writing pycuda.egg-info/PKG-INFO
writing dependency_links to pycuda.egg-info/dependency_links.txt
writing requirements to pycuda.egg-info/requires.txt
writing top-level names to pycuda.egg-info/top_level.txt
reading manifest file 'pycuda.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no files found matching 'doc/source/_static/*.css'
warning: no files found matching 'doc/source/_templates/*.html'
warning: no files found matching '*.cpp' under directory 'bpl-subset/bpl_subset/boost'
warning: no files found matching '*.html' under directory 'bpl-subset/bpl_subset/boost'
warning: no files found matching '*.inl' under directory 'bpl-subset/bpl_subset/boost'
warning: no files found matching '*.txt' under directory 'bpl-subset/bpl_subset/boost'
warning: no files found matching '*.h' under directory 'bpl-subset/bpl_subset/libs'
warning: no files found matching '*.ipp' under directory 'bpl-subset/bpl_subset/libs'
warning: no files found matching '*.pl' under directory 'bpl-subset/bpl_subset/libs'
writing manifest file 'pycuda.egg-info/SOURCES.txt'
creating build/lib.linux-aarch64-3.6/pycuda/cuda
copying pycuda/cuda/pycuda-complex-impl.hpp -> build/lib.linux-aarch64-3.6/pycuda/cuda
copying pycuda/cuda/pycuda-complex.hpp -> build/lib.linux-aarch64-3.6/pycuda/cuda
copying pycuda/cuda/pycuda-helpers.hpp -> build/lib.linux-aarch64-3.6/pycuda/cuda
copying pycuda/sparse/pkt_build_cython.pyx -> build/lib.linux-aarch64-3.6/pycuda/sparse
running build_ext
building '_driver' extension
creating build/temp.linux-aarch64-3.6
creating build/temp.linux-aarch64-3.6/src
creating build/temp.linux-aarch64-3.6/src/cpp
creating build/temp.linux-aarch64-3.6/src/wrapper
creating build/temp.linux-aarch64-3.6/bpl-subset
creating build/temp.linux-aarch64-3.6/bpl-subset/bpl_subset
creating build/temp.linux-aarch64-3.6/bpl-subset/bpl_subset/libs
creating build/temp.linux-aarch64-3.6/bpl-subset/bpl_subset/libs/python
creating build/temp.linux-aarch64-3.6/bpl-subset/bpl_subset/libs/python/src
creating build/temp.linux-aarch64-3.6/bpl-subset/bpl_subset/libs/python/src/object
creating build/temp.linux-aarch64-3.6/bpl-subset/bpl_subset/libs/python/src/converter
creating build/temp.linux-aarch64-3.6/bpl-subset/bpl_subset/libs/system
creating build/temp.linux-aarch64-3.6/bpl-subset/bpl_subset/libs/system/src
creating build/temp.linux-aarch64-3.6/bpl-subset/bpl_subset/libs/smart_ptr
creating build/temp.linux-aarch64-3.6/bpl-subset/bpl_subset/libs/smart_ptr/src
creating build/temp.linux-aarch64-3.6/bpl-subset/bpl_subset/libs/thread
creating build/temp.linux-aarch64-3.6/bpl-subset/bpl_subset/libs/thread/src
creating build/temp.linux-aarch64-3.6/bpl-subset/bpl_subset/libs/thread/src/pthread
aarch64-linux-gnu-gcc -pthread -fwrapv -Wall -O3 -DNDEBUG -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DBOOST_ALL_NO_LIB=1 -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_MULTI_INDEX_DISABLE_SERIALIZATION=1 -DBOOST_PYTHON_SOURCE=1 -Dboost=pycudaboost -DBOOST_THREAD_DONT_USE_CHRONO=1 -DPYGPU_PACKAGE=pycuda -DPYGPU_PYCUDA=1 -DHAVE_CURAND=1 -Isrc/cpp -Ibpl-subset/bpl_subset -I/usr/local/lib/python3.6/dist-packages/numpy/core/include -I/usr/include/python3.6m -c src/cpp/cuda.cpp -o build/temp.linux-aarch64-3.6/src/cpp/cuda.o
In file included from src/cpp/cuda.cpp:4:0:
src/cpp/cuda.hpp:14:10: fatal error: cuda.h: No such file or directory
#include <cuda.h>
compilation terminated.
error: command 'aarch64-linux-gnu-gcc' failed with exit status 1
ERROR: Failed building wheel for pycuda
Running setup.py clean for pycuda
Failed to build pycuda
Installing collected packages: pycuda
Running setup.py install for pycuda ... error
command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-yz75nu2i/pycuda/setup.py'"'"'; __file__='"'"'/tmp/pip-install-yz75nu2i/pycuda/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-ldafdzjk/install-record.txt --single-version-externally-managed --compile
warnings.warn(msg)
running install
running build
running build_py
creating build
running egg_info
running build_ext
#include <cuda.h>
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-yz75nu2i/pycuda/setup.py'"'"'; __file__='"'"'/tmp/pip-install-yz75nu2i/pycuda/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-ldafdzjk/install-record.txt --single-version-externally-managed --compile Check the logs for full command output.
I haven’t figured out the problem yet, what would your opinion be about that issue?
Looking forward hearing from you.
Hi steffen.epp, add these lines to the bottom of your ~/.bashrc file:
export PATH=/usr/local/cuda-10.0/bin${PATH:+:${PATH}}
export LD_LIBRARY_PATH=/usr/local/cuda-10.0/lib64${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
Then close and restart your terminal instance. PyCUDA should then be able to find your CUDA toolkit when you install PyCUDA again.
I still get an error message. Is it even possible to install pycuda with “sudo pip3 install pycuda”, or do i have to do it according to: https://wiki.tiker.net/PyCuda/Installation/Linux
command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-76uga2ts/pycuda/setup.py'"'"'; __file__='"'"'/tmp/pip-install-76uga2ts/pycuda/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-wjaoky4h/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.6/pycuda
cwd: /tmp/pip-install-76uga2ts/pycuda/
warnings.warn(msg)
running install
running build
running build_py
creating build
running egg_info
running build_ext
#include <cuda.h>
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-76uga2ts/pycuda/setup.py'"'"'; __file__='"'"'/tmp/pip-install-76uga2ts/pycuda/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-wjaoky4h/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.6/pycuda Check the logs for full command output.
Yes, I normally install pycuda through pip. From the log, it still can’t find NVCC in your path:
Try running the following your terminal or .bashrc before trying to install pycuda:
export PATH=/usr/local/cuda/bin${PATH:+:${PATH}}
export LD_LIBRARY_PATH=/usr/local/cuda/lib64${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
Note that I changed these paths to reference /usr/local/cuda (instead of /usr/local/cuda-10.0 specifically) in case you have a different JetPack/CUDA version installed.
Hello, sorry for the late response.
I added it to the bashrc and i ran it in the terminal before trying to install it. But it is still not working with the same error message.
Anything else i can do there?
Hi Steffen, what if you try setting CUDA_INC_DIR
also?
export CUDA_INC_DIR=/usr/local/cuda/include
yes, if i set cuda_inc_dir it is still not working.
I also tried to run it with the user tag. Didn’t work either.
I also checked the path and the nvcc file is there.
As a temporary solution, if i convert the custom model to an .uff on my linux laptop & then copy it on the nano. It looked to me, that I just need PyCuda for converting my custom model, and not when loading the model in?
Maybe I miss something. Here is my bashrc:
bashrc
case $- in
i) ;;
*) return;;
esac
HISTCONTROL=ignoreboth
shopt -s histappend
HISTSIZE=1000
HISTFILESIZE=2000
shopt -s checkwinsize
[ -x /usr/bin/lesspipe ] && eval “$(SHELL=/bin/sh lesspipe)”
if [ -z "{debian_chroot:-}" ] && [ -r /etc/debian_chroot ]; then
debian_chroot=(cat /etc/debian_chroot)
fi
case “$TERM” in
xterm-color|*-256color) color_prompt=yes;;
esac
if [ -n “$force_color_prompt” ]; then
if [ -x /usr/bin/tput ] && tput setaf 1 >&/dev/null; then
# We have color support; assume it’s compliant with Ecma-48
# (ISO/IEC-6429). (Lack of such support is extremely rare, and such
# a case would tend to support setf rather than setaf.)
color_prompt=yes
else
color_prompt=
fi
fi
if [ "color_prompt" = yes ]; then
PS1='{debian_chroot:+(debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w\[\033[00m\]\$ '
else
PS1='{debian_chroot:+($debian_chroot)}\u@\h:\w$ ’
fi
unset color_prompt force_color_prompt
If this is an xterm set the title to user@host:dir
case “TERM" in
xterm*|rxvt*)
PS1="\[\e]0;{debian_chroot:+($debian_chroot)}\u@\h: \w\a]$PS1”
esac
enable color support of ls and also add handy aliases
if [ -x /usr/bin/dircolors ]; then
test -r ~/.dircolors && eval “(dircolors -b ~/.dircolors)" || eval "(dircolors -b)”
alias ls=‘ls --color=auto’
alias grep='grep --color=auto'
alias fgrep='fgrep --color=auto'
alias egrep='egrep --color=auto'
fi
alias ll=‘ls -alF’
alias la=‘ls -A’
alias l=‘ls -CF’
Add an “alert” alias for long running commands. Use like so:
sleep 10; alert
alias alert=‘notify-send --urgency=low -i “([ ? = 0 ] && echo terminal || echo error)” "(history|tail -n1|sed -e '\''s/^\s*[0-9]\+\s*//;s/[;&|]\s*alert//’’’)"’
Alias definitions.
You may want to put all your additions into a separate file like
~/.bash_aliases, instead of adding them here directly.
See /usr/share/doc/bash-doc/examples in the bash-doc package.
if [ -f ~/.bash_aliases ]; then
. ~/.bash_aliases
fi
enable programmable completion features (you don’t need to enable
this, if it’s already enabled in /etc/bash.bashrc and /etc/profile
sources /etc/bash.bashrc).
if ! shopt -oq posix; then
if [ -f /usr/share/bash-completion/bash_completion ]; then
. /usr/share/bash-completion/bash_completion
elif [ -f /etc/bash_completion ]; then
. /etc/bash_completion
fi
fi
export LLVM_CONFIG="/home/dlinano/emotionAwareHMI/librosa/llvm-7.0.1.src/llvm_build_dir/bin/llvm-config"
alias llvm=’/home/dlinano/emotionAwareHMI/librosa/llvm-7.0.1.src/llvm_build_dir/bin/llvm-lit’
export PATH=/usr/local/cuda-10.0/bin${PATH:+:{PATH}}
export LD_LIBRARY_PATH=/usr/local/cuda-10.0/lib64{LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
Yes, you could convert the model to UFF on PC and copy it to your Jetson. Alternatively these ML containers for Jetson already include pyCUDA installed (these are for JetPack 4.4 DP). You can access the TensorRT samples from within those containers as well.
Also, the imageNet class from jetson-inference isn’t already tested against UFF models, since I had previously used ONNX and caffe models for classification. So you may need to add some calls to the UFF loader and pre-processing for your model (i.e. mean pixel subtraction coefficients and desired tensor format) to imageNet.cpp. You can see existing support for UFF in detectNet.cpp, since that uses the SSD models from UFF format.
