Jetson Installation Issue: Can not transfer extra file after flashing OS
I have trying to install Jetpack on TX2 since last two month. I have had various problem solved some with your support, still I am not successful.
Jetpack 3.2: Fails to download Docs which I did download manually using links given repository.json file. However, during installation it fails to download "Nvidia Toolkit" and in terminal it gives error 404 i.e. some IP can’t be reached. This occurs before Flashing OS.
Jetpack 3.1: During initial download, it fails to download Reference, Docs and CuDNN which I downloaded manually and the packages are accepted by Jetpack. During installation of visionWorkSFM, it tries to download some files and fails. If I discard installation of VisionWorkSFM, then after flashing OS, it stops any further action as given in attached pictures.
Jetpack 3.0: After flashing OS, it stops any further action as given in attached pictures. Here, I have discard installation of “OpenCV for Tegra” and also have to download some files manually.
Errors in downloading: https://www.dropbox.com/sh/u7up197c08eijgg/AAAB6yM05KlVthm89HC135oRa?dl=0
After flashing OS: https://www.dropbox.com/sh/top3tvzg3qt1ryq/AAAdAd7rpGmsotllLrAlEJaya?dl=0
