Would it be possible to fix a minor bug in jetson-io please that affects custom boards? The patch required is as follows:
Edit the opt/nvidia/jetson-io/Utils/dtc.py file and change the lines:
def find_compatible_dtbo_files(compat, path):
dtbos = []
for dtbo in glob.glob(os.path.join(path, '*.dtbo')):
c = get_compatible(dtbo).split()
if c is None:
continue
for c_str in c:
if c_str in compat:
dtbos.append(dtbo)
break
return dtbos
to:
dtbos = []
if c is None:
continue
for c_str in c.split():
if c_str in compat:
dtbos.append(dtbo)
break
return dtbos
Notice how the location of the split() call is moved. Without the patch, the python script throws an error when get_compatible(dtbo) returns None.
