I have to use jetson-io.
However, jetson-io does not work.
And when you run config-by-pin.py, an error will get an error.
File “./config-by-pin.py”, line 51, in
main()
File “./config-by-pin.py”, line 34, in main
jetson = board.Board()
File “/opt/nvidia/jetson-io/Jetson/board.py”, line 147, in init
self.name = _board_get(self.compat)
File “/opt/nvidia/jetson-io/Jetson/board.py”, line 81, in _board_get
raise RuntimeError(“No board data found!”)
RuntimeError: No board data found!
The module I use is TX2I and JetPack version is 4.3.
The LT4 information is as follows:
cat /etc/nv_tegra_release
R32 (release), REVISION: 3.1, GCID: 18186506, BOARD: t186ref, EABI: aarch64, DATE: Tue Dec 10 07:03:07 UTC 2019
What should I do?
