Jetson-io not found in Orin nano
I want to configure my jetson orin nano to work with the RPi HQ camera. And for that, i have to work with the Jetson-io interface to enable support for IMX477.
But when i try to look for / run the jetson-io.py file, I get this response
can’t open file ‘/opt/nvidia/jetson-io/jetson-io.py’: [Errno 2] No such file or directory
i also check inside the nvidia folder, but there is no jetson-io folder inside.
What’s your version?
Could you use sdkmanager to flash it again to check?
R35 (release), REVISION: 4.1, GCID: 33958178, BOARD: t186ref, EABI: aarch64, DATE: Tue Aug 1 19:57:35 UTC 2023
I will re-flash Jetpack later since i have some ongoing work with the system. Is there anything else i can look into other than flashing it again?
Maybe check the UART log if more clue.
Hi shane,
This was on me. The jetson-io did get installed upon reflashing. But it seems the camera drivers that i am installing later uninstalls the jetson-io.
Thanks anyways
