I am trying to modify the GPIO pin out to enable SPI on Orin. I was about to run sudo /opt/nvidia/jetson-io/jetson-io.py once. But after that every time it crashed.
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
Do you mean you can generate a new device tree file through jetson-io.py, but cannot boot up with the new dtb?
