I am trying to use $ sudo /opt/nvidia/jetson-io/jetson-io.py
to set up spi ports on 40 pin connector on Jetson AGX. But after reboot I could see that changes didn’t save.
I am currently booting from m.2 drive rather than internal emmc
I was trying to follow similar entries on the forum:
had a look into following file /boot/extlinux/extlinux.conf
and changed it from root=/dev/mmcblk0p1
to root=/dev/nvme0n1p1
but without any success
LABEL JetsonIO
MENU LABEL Custom 40-pin Header Config
LINUX /boot/Image
FDT /boot/kernel_tegra194-p2888-0001-p2822-0000-user-custom.dtb
INITRD /boot/initrd
APPEND ${cbootargs} quiet root=/dev/nvme0n1p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4
Is there something I am missing?
