Jetson-io.py not working on Jetpack 5.13
Hello I am trying to configure pwm pins with jetson-io.py but the command does not work.
I tried this command: sudo /opt/nvidia/jetson-io/jetson-io.py
I used this same thing to configure some pins a couple weeks ago but now it does not work. When I run it, a dark green page appears that says Jetson Expansion Header Tool at the top and then disappears almost instantly.
How can I fix this?
Hi anay.gokhale123,
Are you using the devkit or custom board for Orin Nano?
Do you have the reproduce steps for us to verify locally?
(i.e. what operation may cause it does not work?)
Is there the error log could be shared?
I am using the devkit.
I just started it and opened a terminal and ran the command mentioned in my original post. I didn’t do anything else.
There is no error log as there is no error message printed. This is the screen that flashes for less than a second
After this disappears, the terminal just goes back to normal with no error message present
Where did you get the image?
I just had to setup a 20.04 box to install j5.1.4 using sdkmanager. The nvme install works, I just did this in the last 24 hours. They have an issue going on so we back peddled to jp5. Also if the window does stay open try pulling the corner to make it larger, ncurses is touchy sometimes, then it will display all the options. It does not expose the gpio.
Just wanted to give an update, I ended up re-flashing my sd card with JP5.1.4, and now it works just fine. I am not sure what the issue might have been but I’m good for the time being
Cool!!! Glad you go it up and running.
