Jetson is not in the sudoers file. This incident will be reported
Hello, in the process of using ORIN Nano, the following error has suddenly appeared. Is there any way to solve the problem without flashing the machine again?
WXWorkCapture_17116139922983
How was user jetson added? This simply means it is not an admin account. If you have another account which is admin, then it can use sudo to add user jetson to the sudoers (never hand edit any files related to this, you’ll likely disable the system).
The user set it up on sdkmanager and it worked fine before.
If you monitor “dmesg --follow”, and run the command “sudo ls”, what do you see as a result of log lines added to dmesg? Do you see any errors in “sudo ls” (I’m not interested in the ls, I’m just interested in what sudo does to change it)?
What do you see from this command:
egrep -i '(jetson|sudo)' /etc/group
What does your user see from “id”?
What do you see from “ls -l /etc/sudoers”?
