Thank you for the answer. Until now, I always used the BSP from the vendor.
I tried your workflow. Flashing the standard way went well, cloning also (expected).
However , flashing the cloned image failed with the -3 error I had before. Here are the logs:
sudo ./flash.sh -r -S 62090379264 jetson-agx-orin-devkit mmcblk0p1
# L4T BSP Information:
# R35 , REVISION: 3.1
# User release: 0.0
# Target Board Information:
# Name: jetson-agx-orin-devkit, Board Family: t186ref, SoC: Tegra 234,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying emc_fuse_dev_params(/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3701-0000.dts)... done.
copying misc_config(/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3701-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0110 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0118 ] File rcm_state open failed
[ 0.0121 ] ERROR: failed to read rcm_state
[ 0.0121 ]
[ 0.0137 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0138 ] Assuming zero filled SBK key
[ 0.0124 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[ 0.0586 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[ 0.0651 ] Parsing partition layout
[ 0.0659 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0681 ] Kernel DTB used: None
[ 0.0681 ] WARNING: dce base dtb is not provided
[ 0.0681 ] Parsing partition layout
[ 0.0688 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0698 ] Creating list of images to be signed
[ 0.0712 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0720 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0736 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0739 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0768 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0770 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0808 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0810 ] adding BCH for mb2_t234_aligned.bin
[ 0.0834 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0912 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0914 ] adding BCH for mb2_t234_aligned.bin
[ 0.1010 ] Filling MB1 storage info
[ 0.1011 ] Parsing dev params for multi chains
[ 0.1069 ] Generating br-bct
[ 0.1079 ] Updating dev and MSS params in BR BCT
[ 0.1079 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.1103 ] Updating bl info
[ 0.1113 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[ 0.1121 ] WARNING: boot chain is not completed. set to 0
[ 0.1129 ] Generating signatures
[ 0.1145 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1147 ] Assuming zero filled SBK key
[ 0.1300 ] Warning: pub_key.key is not found
[ 0.1286 ] Parsing dev params for multi chains
[ 0.1286 ] Generating br-bct
[ 0.1292 ] Updating dev and MSS params in BR BCT
[ 0.1293 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.1302 ] Updating bl info
[ 0.1308 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1315 ] WARNING: boot chain is not completed. set to 0
[ 0.1327 ] Get Signed section of bct
[ 0.1336 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.1354 ] Signing BCT
[ 0.1371 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1375 ] Assuming zero filled SBK key
[ 0.1399 ] Sha saved in br_bct_BR.sha
[ 0.1402 ] Warning: pub_key.key is not found
[ 0.1386 ] Updating BCT with signature
[ 0.1394 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.1401 ] Offset :4608 Len :3584
[ 0.1404 ] Generating SHA2 Hash
[ 0.1420 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.1421 ] Assuming zero filled SBK key
[ 0.1422 ] Assuming zero filled SBK key
[ 0.1443 ] Sha saved in br_bct_BR.sha
[ 0.1430 ] Updating BCT with SHA2 Hash
[ 0.1436 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.1443 ] Offset :4608 Len :3584
[ 0.1445 ] Offset :68 Len :8124
[ 0.1446 ] Generating coldboot mb1-bct
[ 0.1453 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1462 ] MB1-BCT version: 0.10
[ 0.1463 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1467 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1469 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1471 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1474 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1477 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1478 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.1478 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.1478 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.1478 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.1478 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.1478 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.1478 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.1478 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.1478 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.1478 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.1478 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.1478 ]
[ 0.1478 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1478 ] Added Platform Config 9 data with size :- 100
[ 0.1478 ]
[ 0.1479 ] Updating mb1-bct with firmware information
[ 0.1490 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1509 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1526 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.1532 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1554 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1555 ] Assuming zero filled SBK key
[ 0.1569 ] Warning: pub_key.key is not found
[ 0.1563 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1574 ] Generating recovery mb1-bct
[ 0.1580 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1587 ] MB1-BCT version: 0.10
[ 0.1588 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1591 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1594 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1596 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1598 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1601 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1602 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.1602 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.1602 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.1602 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.1602 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.1602 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.1602 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.1602 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.1602 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.1602 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.1602 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.1602 ]
[ 0.1602 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1602 ] Added Platform Config 9 data with size :- 100
[ 0.1602 ]
[ 0.1603 ] Updating mb1-bct with firmware information
[ 0.1608 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1624 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.1642 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.1651 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.1678 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1681 ] Assuming zero filled SBK key
[ 0.1698 ] Warning: pub_key.key is not found
[ 0.1690 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1702 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.1702 ] Copying signatures
[ 0.1709 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1743 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1744 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1744 ] Boot Rom communication
[ 0.1751 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.1759 ] BR_CID: 0x80012344705DD2420C000000140001C0
[ 0.1767 ] Sending bct_br
[ 0.1768 ] Sending mb1
[ 0.1772 ] Sending psc_bl1
[ 0.1877 ] Sending bct_mb1
[ 0.1940 ] Boot Rom communication completed
[ 0.1960 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[ 0.1993 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[ 0.2000 ] adding BCH for applet_t234_aligned.bin
[ 0.2075 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.2077 ] Assuming zero filled SBK key
[ 0.2096 ] Warning: pub_key.key is not found
[ 0.2092 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[ 0.2112 ] Sending mb2_applet...
[ 0.2120 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[ 0.2129 ] BL: version 0.32.0.0-t234-54845784-57325615 last_boot_error: 0
[ 0.4035 ] Sending applet
[ 0.5268 ] completed
[ 0.5283 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.5293 ] MB2 Applet version 01.00.0000
[ 0.7580 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.7591 ] MB2 Applet version 01.00.0000
[ 0.7621 ] Retrieving board information
[ 0.7628 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[ 0.7634 ] MB2 Applet version 01.00.0000
[ 0.7657 ] Saved platform info in chip_info.bin
[ 0.7710 ] Chip minor revision: 1
[ 0.7711 ] Bootrom revision: 0x7
[ 0.7712 ] Ram code: 0x0
[ 0.7713 ] Chip sku: 0xd2
[ 0.7713 ] Chip Sample: prod
[ 0.7720 ] Retrieving EEPROM data
[ 0.7720 ] tegrarcm_v2 --oem platformdetails eeprom cvm /Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[ 0.7727 ] MB2 Applet version 01.00.0000
[ 0.7749 ] Saved platform info in /Linux_for_Tegra/bootloader/cvm.bin
[ 0.8092 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.8102 ] MB2 Applet version 01.00.0000
[ 0.8131 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.8138 ] MB2 Applet version 01.00.0000
[ 0.8161 ] Dumping customer Info
[ 0.8173 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[ 0.8183 ] MB2 Applet version 01.00.0000
[ 0.8205 ] Saved bct in tmp.bct
[ 0.8304 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /Linux_for_Tegra/bootloader/custinfo_out.bin
[ 0.8312 ] C[ 0.8314 ] ustomer data saved in /Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[ 0.8314 ] Rebooting to recovery mode
[ 0.8321 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 0.8357 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.8364 ] MB2 Applet version 01.00.0000
[ 0.8387 ] Booting to recovery mode
[ 0.8395 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[ 0.8402 ] MB2 Applet version 01.00.0000
Board ID(3701) version(500) sku(0004) revision(G.0)
Copy /Linux_for_Tegra/kernel/dtb/tegra234-p3701-0004-p3737-0000.dtb to /Linux_for_Tegra/kernel/dtb/tegra234-p3701-0004-p3737-0000.dtb.rec
copying bctfile(/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3701-0000-sdram-l4t.dts)... done.
copying minratchet_config(/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-ratchet-p3701-0000.dts)... done.
copying pinmux_config(/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi)... done.
copying gpioint_config(/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-gpioint-p3701-0000.dts)... done.
copying pmic_config(/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pmic-p3701-0000.dts)... done.
copying pmc_config(/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-padvoltage-p3701-0000-a04.dtsi)... done.
copying deviceprod_config(/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-cprod-p3701-0000.dts)... done.
copying prod_config(/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-prod-p3701-0000.dts)... done.
copying scr_config(/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb2-bct-scr-p3701-0000.dts)... done.
copying wb0sdram(/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3701-0000-wb0sdram-l4t.dts)... done.
copying bootrom_config(/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-reset-p3701-0000.dts)... done.
Existing uphylane_config(/Linux_for_Tegra/bootloader/tegra234-mb1-bct-uphylane-si.dtsi) reused.
copying dev_params(/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-p3701-0000.dts)... done.
copying dev_params_b(/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct_b-p3701-0000.dts)... done.
copying mb2bct_cfg(/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb2-bct-misc-p3701-0000.dts)... done.
Existing pscfwfile(/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing mb2applet(/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Existing bootloader(/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/Linux_for_Tegra/bootloader/ramdisk_tmp /Linux_for_Tegra/bootloader /Linux_for_Tegra
39726 blocks
gzip: /Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.10.104-tegra
56174 blocks
Making Recovery image...
copying recdtbfile(/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0004-p3737-0000.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 5.8546e-05 s, 342 kB/s
Existing sosfile(/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing dcefile(/Linux_for_Tegra/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/Linux_for_Tegra/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/Linux_for_Tegra/bootloader/bpmp_t234-TE990M-A1_prod.bin) reused.
copying bpfdtbfile(/Linux_for_Tegra/bootloader/t186ref/tegra234-bpmp-3701-0004-3737-0000.dtb)... done.
Existing scefile(/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/Linux_for_Tegra/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/Linux_for_Tegra/bootloader/eks_t234.img) reused.
copying dtbfile(/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0004-p3737-0000.dtb)... done.
Copying nv_boot_control.conf to rootfs
Reusing existing system.img...
done.
Not signing of kernel-dtb
Existing tbcfile(/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
Skip generating EFI system partition image.
copying tbcdtbfile(/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0004-p3737-0000.dtb)... done.
copying cfgfile(/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t234_qspi_sdmmc.xml) to flash.xml... done.
Existing flashapp(/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
copying overlay_dtb(/Linux_for_Tegra/kernel/dtb/tegra234-p3737-audio-codec-rt5658-40pin.dtbo)... done.
copying overlay_dtb(/Linux_for_Tegra/kernel/dtb/tegra234-p3737-overlay.dtbo)... done.
copying overlay_dtb(/Linux_for_Tegra/kernel/dtb/tegra234-p3701-overlay.dtbo)... done.
copying overlay_dtb(/Linux_for_Tegra/kernel/dtb/tegra234-p3737-camera-dual-imx274-overlay.dtbo)... done.
copying overlay_dtb(/Linux_for_Tegra/kernel/dtb/tegra234-p3737-camera-e3331-overlay.dtbo)... done.
copying overlay_dtb(/Linux_for_Tegra/kernel/dtb/tegra234-p3737-camera-e3333-overlay.dtbo)... done.
copying overlay_dtb(/Linux_for_Tegra/kernel/dtb/tegra234-p3737-camera-imx185-overlay.dtbo)... done.
copying overlay_dtb(/Linux_for_Tegra/kernel/dtb/tegra234-p3737-camera-imx390-overlay.dtbo)... done.
./tegraflash.py --bl uefi_jetson_with_dtb.bin --odmdata gbe-uphy-config-0,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-16 --overlay_dtb L4TConfiguration.dtbo,tegra234-p3737-audio-codec-rt5658-40pin.dtbo,tegra234-p3737-overlay.dtbo,tegra234-p3701-overlay.dtbo,tegra234-p3737-camera-dual-imx274-overlay.dtbo,tegra234-p3737-camera-e3331-overlay.dtbo,tegra234-p3737-camera-e3333-overlay.dtbo,tegra234-p3737-camera-imx185-overlay.dtbo,tegra234-p3737-camera-imx390-overlay.dtbo, --bldtb tegra234-p3701-0004-p3737-0000.dtb --applet mb1_t234_prod.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x23 --concat_cpubl_bldtb --cpubl uefi_jetson.bin --minratchet_config tegra234-mb1-bct-ratchet-p3701-0000.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --pinmux_config tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3701-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3701-0000.dts --pmc_config tegra234-mb1-bct-padvoltage-p3701-0000-a04.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3701-0000.dts --prod_config tegra234-mb1-bct-prod-p3701-0000.dts --scr_config tegra234-mb2-bct-scr-p3701-0000.dts --wb0sdram_config tegra234-p3701-0000-wb0sdram-l4t.dts --br_cmd_config tegra234-mb1-bct-reset-p3701-0000.dts --uphy tegra234-mb1-bct-uphylane-si.dtsi --dev_params tegra234-br-bct-p3701-0000.dts,tegra234-br-bct_b-p3701-0000.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3701-0000.dts --bins "psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; dce_fw display-t234-dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE990M-A1_prod.bin; bpmp_fw_dtb tegra234-bpmp-3701-0004-3737-0000.dtb; sce_fw camera-rtcpu-sce.img; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tos tos-optee_t234.img; eks eks_t234.img" --sdram_config tegra234-p3701-0000-sdram-l4t.dts --cust_info custinfo_out.bin --secondary_gpt_backup --bct_backup --boot_chain A
saving flash command in /Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0128 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0128 ] Assuming zero filled SBK key
[ 0.0112 ] Parsing partition layout
[ 0.0119 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0159 ] Change tegra234-bpmp-3701-0004-3737-0000.dtb to tegra234-bpmp-3701-0004-3737-0000_with_odm.dtb
[ 0.0364 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3701-0004-3737-0000_with_odm.dtb tegra234-bpmp-3701-0004-3737-0000_with_odm_tmp.dtb
[ 0.2977 ] Concatenating L4TConfiguration.dtbo,tegra234-p3737-audio-codec-rt5658-40pin.dtbo,tegra234-p3737-overlay.dtbo,tegra234-p3701-overlay.dtbo,tegra234-p3737-camera-dual-imx274-overlay.dtbo,tegra234-p3737-camera-e3331-overlay.dtbo,tegra234-p3737-camera-e3333-overlay.dtbo,tegra234-p3737-camera-imx185-overlay.dtbo,tegra234-p3737-camera-imx390-overlay.dtbo to tegra234-p3701-0004-p3737-0000_with_odm_overlay.dtb
[ 0.2980 ] Concatenating bl dtb to cpubl binary
[ 0.2999 ] MB2 binary: mb2_t234.bin
[ 0.2999 ] Pre-processing mb2bct config: tegra234-mb2-bct-misc-p3701-0000.dts
[ 0.3070 ] Pre-processing mb2bct config: tegra234-mb2-bct-scr-p3701-0000.dts
[ 0.5379 ] Generating coldboot mb2-bct
[ 0.5379 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct.cfg --mb2bctcfg tegra234-mb2-bct-misc-p3701-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3701-0000_cpp.dtb
[ 0.5388 ] WARNING: unknown property 'tfc_version'
[ 0.5399 ] WARNING: unknown property 'addr_header_version'
[ 0.5479 ] Updating mb2-bct with storage information
[ 0.5488 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct_MB2.bct --updatestorageinfo flash.xml.bin
[ 0.5547 ] Concatenating mb2-bct to mb2 binary
[ 0.5547 ] mb2_bin_file = mb2_t234.bin
[ 0.5547 ] mb2_bct_file = mb2_cold_boot_bct_MB2.bct
[ 0.5571 ] DCE binary: display-t234-dce.bin
[ 0.5572 ] Kernel DTB used: kernel_tegra234-p3701-0004-p3737-0000.dtb
[ 0.5572 ] Concatenating kernel-dtb to dce-fw binary
[ 0.5572 ] dce_bin = display-t234-dce.bin
[ 0.5572 ] kernel_dtb = kernel_tegra234-p3701-0004-p3737-0000.dtb
[ 0.5572 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3701-0004-p3737-0000.bin
[ 0.5612 ] Update display-t234-dce_with_kernel_tegra234-p3701-0004-p3737-0000.bin to dce_fw partitions
[ 0.5640 ] Parsing partition layout
[ 0.5661 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.5674 ] Creating list of images to be signed
[ 0.5686 ] Generating ratchet blob
[ 0.5687 ] Pre-processing config: tegra234-mb1-bct-reset-p3701-0000.dts
[ 0.5745 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[ 0.5822 ] Pre-processing config: tegra234-mb1-bct-cprod-p3701-0000.dts
[ 0.5865 ] Pre-processing config: tegra234-mb1-bct-gpioint-p3701-0000.dts
[ 0.5911 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[ 0.5974 ] Pre-processing config: tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi
[ 0.6087 ] Pre-processing config: tegra234-mb1-bct-padvoltage-p3701-0000-a04.dtsi
[ 0.6142 ] Pre-processing config: tegra234-mb1-bct-pmic-p3701-0000.dts
[ 0.6189 ] Pre-processing config: tegra234-mb1-bct-prod-p3701-0000.dts
[ 0.6232 ] Pre-processing config: tegra234-p3701-0000-sdram-l4t.dts
[ 1.7251 ] Pre-processing config: tegra234-mb1-bct-uphylane-si.dtsi
[ 1.7306 ] Pre-processing config: tegra234-p3701-0000-wb0sdram-l4t.dts
[ 2.8194 ] Pre-processing config: tegra234-mb1-bct-ratchet-p3701-0000.dts
[ 2.8240 ] Generating coldboot mb1-bct
[ 2.8247 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --wb0sdram tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 2.8254 ] MB1-BCT version: 0.10
[ 2.8255 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 2.8258 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 2.8261 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 2.8263 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 2.8265 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 2.8268 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 2.8270 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 2.8272 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 2.8275 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 2.8277 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 2.8279 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 2.8281 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 2.8284 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 2.8286 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 2.8289 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 2.8291 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 2.8293 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 2.8295 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb
[ 2.8299 ] Added Platform Config 0 data with size :- 2928
[ 2.8299 ]
[ 2.8299 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb
[ 2.8300 ] WARNING: unknown node 'g2'
[ 2.8300 ] WARNING: unknown node 'g9'
[ 2.8300 ] Added Platform Config 2 data with size :- 24
[ 2.8300 ]
[ 2.8300 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb
[ 2.8300 ] Added Platform Config 4 data with size :- 532
[ 2.8300 ]
[ 2.8300 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[ 2.8300 ] Added Platform Config 3 data with size :- 52
[ 2.8300 ]
[ 2.8300 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[ 2.8300 ] WARNING: unknown property 'major'
[ 2.8300 ] WARNING: unknown property 'minor'
[ 2.8300 ] Added Platform Config 5 data with size :- 524
[ 2.8300 ]
[ 2.8300 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[ 2.8300 ] Added Platform Config 7 data with size :- 380
[ 2.8300 ]
[ 2.8300 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[ 2.8300 ] Added Platform Config 8 data with size :- 24
[ 2.8300 ]
[ 2.8300 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 2.8301 ] Added Platform Config 9 data with size :- 100
[ 2.8301 ]
[ 2.8301 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[ 2.8301 ] ModuleCount 0 NumProdNames 0
[ 2.8301 ] Added Platform Config 6 data with size :- 16
[ 2.8301 ]
[ 2.8301 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[ 2.8301 ]
[ 2.8301 ] Updating mb1-bct with firmware information
[ 2.8307 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 2.8374 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 2.8391 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 2.8398 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 2.8423 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 2.8425 ] Assuming zero filled SBK key
[ 2.8444 ] Warning: pub_key.key is not found
[ 2.8439 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 2.8454 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[ 2.8462 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 2.8468 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 2.8470 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 2.8502 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 2.8504 ] Header already present for nvdec_t234_prod_aligned.fw
[ 2.8528 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[ 2.8564 ] adding BCH for xusb_t234_prod_aligned.bin
[ 2.8648 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[ 2.8694 ] adding BCH for tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned.dtb
[ 2.8808 ] Header already present for pscfw_t234_prod_aligned.bin
[ 2.8848 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[ 2.8886 ] Header already present for sc7_t234_prod.bin
[ 2.8905 ] Header already present for psc_rf_t234_prod_aligned.bin
[ 2.8923 ] adding BCH for mb2rf_t234_aligned.bin
[ 2.8936 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[ 2.9009 ] adding BCH for tos-optee_t234_aligned.img
[ 2.9636 ] adding BCH for eks_t234_aligned.img
[ 2.9842 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3701-0004-p3737-0000_aligned.bin
[ 3.0857 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3701-0004-p3737-0000_aligned.bin, ratio = 7%
[ 3.0994 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3701-0004-p3737-0000_aligned_blob_w_bin_aligned.bin
[ 3.1102 ] adding BCH for spe_t234_aligned.bin
[ 3.1180 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[ 3.1239 ] adding BCH for adsp-fw_aligned.bin
[ 3.1351 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 3.1429 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 3.1432 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 3.1488 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 3.1490 ] Header already present for nvdec_t234_prod_aligned.fw
[ 3.1505 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[ 3.1543 ] adding BCH for xusb_t234_prod_aligned.bin
[ 3.1632 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[ 3.1687 ] adding BCH for tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned.dtb
[ 3.1814 ] Header already present for pscfw_t234_prod_aligned.bin
[ 3.1845 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[ 3.1885 ] Header already present for sc7_t234_prod.bin
[ 3.1904 ] Header already present for psc_rf_t234_prod_aligned.bin
[ 3.1924 ] adding BCH for mb2rf_t234_aligned.bin
[ 3.1938 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[ 3.2020 ] adding BCH for tos-optee_t234_aligned.img
[ 3.2668 ] adding BCH for eks_t234_aligned.img
[ 3.2876 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3701-0004-p3737-0000_aligned.bin
[ 3.3941 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3701-0004-p3737-0000_aligned.bin, ratio = 7%
[ 3.4071 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3701-0004-p3737-0000_aligned_blob_w_bin_aligned.bin
[ 3.4195 ] adding BCH for spe_t234_aligned.bin
[ 3.4274 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[ 3.4338 ] adding BCH for adsp-fw_aligned.bin
[ 3.4528 ] Filling MB1 storage info
[ 3.4529 ] Parsing dev params for multi chains
[ 3.4590 ] Generating br-bct
[ 3.4597 ] Updating dev and MSS params in BR BCT
[ 3.4598 ] tegrabct_v2 --dev_param tegra234-br-bct-p3701-0000_cpp.dtb --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 3.5326 ] Updating bl info
[ 3.5337 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[ 3.5402 ] Generating br-bct
[ 3.5410 ] Updating dev and MSS params in BR BCT
[ 3.5411 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3701-0000_cpp.dtb --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 3.6027 ] Updating bl info
[ 3.6039 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[ 3.6051 ] Generating BCT backup image
[ 3.6052 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 3.6060 ] 32768+0 records in
[ 3.6319 ] 32768+0 records out
[ 3.6319 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0250365 s, 1.3 MB/s
[ 3.6319 ]
[ 3.6320 ] Concatenating BCT for chain A to bct_backup.img
[ 3.6320 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 3.6347 ] 8192+0 records in
[ 3.6400 ] 8192+0 records out
[ 3.6400 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.00465413 s, 1.8 MB/s
[ 3.6400 ]
[ 3.6400 ] Concatenating BCT for chain B to bct_backup.img
[ 3.6400 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 3.6410 ] 8192+0 records in
[ 3.6463 ] 8192+0 records out
[ 3.6463 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.00482203 s, 1.7 MB/s
[ 3.6463 ]
[ 3.6463 ] Generating signatures
[ 3.6481 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.6483 ] Assuming zero filled SBK key
[ 3.7307 ] Warning: pub_key.key is not found
[ 3.7309 ] Parsing dev params for multi chains
[ 3.7310 ] Generating br-bct
[ 3.7318 ] Updating dev and MSS params in BR BCT
[ 3.7319 ] tegrabct_v2 --dev_param tegra234-br-bct-p3701-0000_cpp.dtb --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 3.7973 ] Updating customer data section
[ 3.7983 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[ 3.7993 ] Updating bl info
[ 3.8000 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 3.8018 ] Get Signed section of bct
[ 3.8030 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 3.8042 ] Signing BCT
[ 3.8060 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.8062 ] Assuming zero filled SBK key
[ 3.8085 ] Sha saved in br_bct_BR.sha
[ 3.8089 ] Warning: pub_key.key is not found
[ 3.8072 ] Updating BCT with signature
[ 3.8084 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 3.8093 ] Offset :4608 Len :3584
[ 3.8096 ] Generating SHA2 Hash
[ 3.8113 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 3.8114 ] Assuming zero filled SBK key
[ 3.8115 ] Assuming zero filled SBK key
[ 3.8135 ] Sha saved in br_bct_BR.sha
[ 3.8121 ] Updating BCT with SHA2 Hash
[ 3.8128 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 3.8140 ] Offset :4608 Len :3584
[ 3.8144 ] Offset :68 Len :8124
[ 3.8147 ] Generating br-bct
[ 3.8155 ] Updating dev and MSS params in BR BCT
[ 3.8156 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3701-0000_cpp.dtb --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 3.8764 ] Updating customer data section
[ 3.8776 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[ 3.8785 ] Updating bl info
[ 3.8792 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 3.8806 ] Get Signed section of bct
[ 3.8813 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 3.8823 ] Signing BCT
[ 3.8840 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.8841 ] Assuming zero filled SBK key
[ 3.8862 ] Sha saved in br_bct_BR.sha
[ 3.8865 ] Warning: pub_key.key is not found
[ 3.8848 ] Updating BCT with signature
[ 3.8856 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 3.8863 ] Offset :4608 Len :3584
[ 3.8866 ] Generating SHA2 Hash
[ 3.8884 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 3.8885 ] Assuming zero filled SBK key
[ 3.8910 ] Sha saved in br_bct_BR.sha
[ 3.8897 ] Updating BCT with SHA2 Hash
[ 3.8905 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 3.8914 ] Offset :4608 Len :3584
[ 3.8916 ] Offset :68 Len :8124
[ 3.8918 ] Generating BCT backup image
[ 3.8918 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 3.8926 ] 32768+0 records in
[ 3.9203 ] 32768+0 records out
[ 3.9203 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0271963 s, 1.2 MB/s
[ 3.9203 ]
[ 3.9204 ] Concatenating BCT for chain A to bct_backup.img
[ 3.9204 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 3.9216 ] 8192+0 records in
[ 3.9267 ] 8192+0 records out
[ 3.9267 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.00462551 s, 1.8 MB/s
[ 3.9267 ]
[ 3.9267 ] Concatenating BCT for chain B to bct_backup.img
[ 3.9267 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 3.9277 ] 8192+0 records in
[ 3.9329 ] 8192+0 records out
[ 3.9329 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.00461857 s, 1.8 MB/s
[ 3.9329 ]
[ 3.9330 ] Generating coldboot mb1-bct
[ 3.9341 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --wb0sdram tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 3.9350 ] MB1-BCT version: 0.10
[ 3.9352 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 3.9355 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 3.9358 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 3.9360 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 3.9363 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 3.9365 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 3.9368 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 3.9370 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 3.9372 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 3.9374 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 3.9376 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 3.9379 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 3.9381 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 3.9383 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 3.9385 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 3.9387 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 3.9389 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 3.9391 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb
[ 3.9394 ] Added Platform Config 0 data with size :- 2928
[ 3.9396 ]
[ 3.9396 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb
[ 3.9396 ] WARNING: unknown node 'g2'
[ 3.9396 ] WARNING: unknown node 'g9'
[ 3.9396 ] Added Platform Config 2 data with size :- 24
[ 3.9396 ]
[ 3.9396 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb
[ 3.9396 ] Added Platform Config 4 data with size :- 532
[ 3.9396 ]
[ 3.9396 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[ 3.9396 ] Added Platform Config 3 data with size :- 52
[ 3.9396 ]
[ 3.9396 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[ 3.9396 ] WARNING: unknown property 'major'
[ 3.9396 ] WARNING: unknown property 'minor'
[ 3.9396 ] Added Platform Config 5 data with size :- 524
[ 3.9396 ]
[ 3.9396 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[ 3.9396 ] Added Platform Config 7 data with size :- 380
[ 3.9396 ]
[ 3.9397 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[ 3.9397 ] Added Platform Config 8 data with size :- 24
[ 3.9397 ]
[ 3.9397 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 3.9397 ] Added Platform Config 9 data with size :- 100
[ 3.9397 ]
[ 3.9397 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[ 3.9397 ] ModuleCount 0 NumProdNames 0
[ 3.9397 ] Added Platform Config 6 data with size :- 16
[ 3.9397 ]
[ 3.9397 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[ 3.9397 ]
[ 3.9397 ] Updating mb1-bct with firmware information
[ 3.9406 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 3.9426 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 3.9442 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 3.9450 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 3.9474 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.9477 ] Assuming zero filled SBK key
[ 3.9500 ] Warning: pub_key.key is not found
[ 3.9491 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 3.9503 ] Generating recovery mb1-bct
[ 3.9510 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --wb0sdram tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 3.9518 ] MB1-BCT version: 0.10
[ 3.9519 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 3.9522 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 3.9524 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 3.9526 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 3.9529 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 3.9531 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 3.9533 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 3.9535 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 3.9537 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 3.9540 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 3.9542 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 3.9544 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 3.9546 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 3.9548 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 3.9550 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 3.9553 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 3.9554 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 3.9557 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb
[ 3.9559 ] Added Platform Config 0 data with size :- 2928
[ 3.9560 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb
[ 3.9563 ] WARNING: unknown node 'g2'
[ 3.9564 ] WARNING: unknown node 'g2'
[ 3.9564 ] WARNING: unknown node 'g9'
[ 3.9564 ] Added Platform Config 2 data with size :- 24
[ 3.9564 ]
[ 3.9564 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb
[ 3.9564 ] Added Platform Config 4 data with size :- 532
[ 3.9565 ]
[ 3.9565 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[ 3.9565 ] Added Platform Config 3 data with size :- 52
[ 3.9565 ]
[ 3.9565 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[ 3.9565 ] WARNING: unknown property 'major'
[ 3.9565 ] WARNING: unknown property 'minor'
[ 3.9565 ] Added Platform Config 5 data with size :- 524
[ 3.9565 ]
[ 3.9565 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[ 3.9565 ] Added Platform Config 7 data with size :- 380
[ 3.9565 ]
[ 3.9565 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[ 3.9565 ] Added Platform Config 8 data with size :- 24
[ 3.9565 ]
[ 3.9565 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 3.9565 ] Added Platform Config 9 data with size :- 100
[ 3.9565 ]
[ 3.9565 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[ 3.9565 ] ModuleCount 0 NumProdNames 0
[ 3.9565 ] Added Platform Config 6 data with size :- 16
[ 3.9565 ]
[ 3.9565 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[ 3.9565 ]
[ 3.9566 ] Updating mb1-bct with firmware information
[ 3.9575 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[ 3.9594 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 3.9611 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 3.9619 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 3.9644 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.9646 ] Assuming zero filled SBK key
[ 3.9663 ] Warning: pub_key.key is not found
[ 3.9658 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 3.9672 ] Generating coldboot mem-bct
[ 3.9681 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb --membct tegra234-p3701-0000-sdram-l4t_cpp_1.bct tegra234-p3701-0000-sdram-l4t_cpp_2.bct tegra234-p3701-0000-sdram-l4t_cpp_3.bct tegra234-p3701-0000-sdram-l4t_cpp_4.bct
[ 3.9693 ] packing sdram params with Wb0 file tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb
[ 4.0304 ] Packing sdram param for instance[0]
[ 4.0305 ] Packing sdram param for instance[1]
[ 4.0306 ] Packing sdram param for instance[2]
[ 4.0307 ] Packing sdram param for instance[3]
[ 4.0309 ] Packing sdram param for instance[4]
[ 4.0310 ] Packing sdram param for instance[5]
[ 4.0311 ] Packing sdram param for instance[6]
[ 4.0312 ] Packing sdram param for instance[7]
[ 4.0313 ] Packing sdram param for instance[8]
[ 4.0315 ] Packing sdram param for instance[9]
[ 4.0316 ] Packing sdram param for instance[10]
[ 4.0317 ] Packing sdram param for instance[11]
[ 4.0318 ] Packing sdram param for instance[12]
[ 4.0319 ] Packing sdram param for instance[13]
[ 4.0320 ] Packing sdram param for instance[14]
[ 4.0321 ] Packing sdram param for instance[15]
[ 4.0920 ] Getting sector size from pt
[ 4.0932 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 4.0944 ] BlockSize read from layout is 0x200
[ 4.0955 ] tegrahost_v2 --chip 0x23 0 --blocksize 512 --magicid MEMB --addsigheader_multi tegra234-p3701-0000-sdram-l4t_cpp_1.bct tegra234-p3701-0000-sdram-l4t_cpp_2.bct tegra234-p3701-0000-sdram-l4t_cpp_3.bct tegra234-p3701-0000-sdram-l4t_cpp_4.bct
[ 4.0964 ] Binary 0 length is 58752
[ 4.0965 ] Binary 0 align length is 58880
[ 4.0971 ] Binary 1 length is 58752
[ 4.0972 ] Binary 1 align length is 58880
[ 4.0979 ] Binary 2 length is 58752
[ 4.0980 ] Binary 2 align length is 58880
[ 4.0985 ] Binary 3 length is 58752
[ 4.0986 ] Binary 3 align length is 58880
[ 4.0992 ] Buffer length is 235520
[ 4.0992 ] adding BCH for tegra234-p3701-0000-sdram-l4t_cpp_1.bct
[ 4.0994 ] new length is 243712
[ 4.1005 ] tegrahost_v2 --chip 0x23 0 --align mem_coldboot_aligned.bct
[ 4.1023 ] tegrahost_v2 --chip 0x23 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[ 4.1030 ] Header already present for mem_coldboot_aligned.bct
[ 4.1054 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.1055 ] Assuming zero filled SBK key
[ 4.1070 ] Warning: pub_key.key is not found
[ 4.1061 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[ 4.1076 ] Generating recovery mem-bct
[ 4.1083 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb --membct tegra234-p3701-0000-sdram-l4t_cpp_1.bct tegra234-p3701-0000-sdram-l4t_cpp_2.bct tegra234-p3701-0000-sdram-l4t_cpp_3.bct tegra234-p3701-0000-sdram-l4t_cpp_4.bct
[ 4.1091 ] packing sdram params with Wb0 file tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb
[ 4.1910 ] Packing sdram param for instance[0]
[ 4.1912 ] Packing sdram param for instance[1]
[ 4.1913 ] Packing sdram param for instance[2]
[ 4.1914 ] Packing sdram param for instance[3]
[ 4.1915 ] Packing sdram param for instance[4]
[ 4.1916 ] Packing sdram param for instance[5]
[ 4.1917 ] Packing sdram param for instance[6]
[ 4.1918 ] Packing sdram param for instance[7]
[ 4.1919 ] Packing sdram param for instance[8]
[ 4.1920 ] Packing sdram param for instance[9]
[ 4.1921 ] Packing sdram param for instance[10]
[ 4.1923 ] Packing sdram param for instance[11]
[ 4.1924 ] Packing sdram param for instance[12]
[ 4.1925 ] Packing sdram param for instance[13]
[ 4.1926 ] Packing sdram param for instance[14]
[ 4.1927 ] Packing sdram param for instance[15]
[ 4.2676 ] Reading ramcode from backup chip_info.bin file
[ 4.2677 ] RAMCODE Read from Device: 0
[ 4.2677 ] Using ramcode 0
[ 4.2677 ] Disabled BPMP dtb trim, using default dtb
[ 4.2677 ]
[ 4.2687 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
[ 4.2703 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[ 4.2710 ] adding BCH for mem_rcm_aligned.bct
[ 4.2744 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.2745 ] Assuming zero filled SBK key
[ 4.2759 ] Warning: pub_key.key is not found
[ 4.2751 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[ 4.2763 ] Copying signatures
[ 4.2770 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 4.3128 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 4.3134 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 4.3134 ] Boot Rom communication
[ 4.3150 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 4.3161 ] BR_CID: 0x80012344705DD2420C000000140001C0
[ 4.3169 ] Sending bct_br
[ 4.3170 ] Sending mb1
[ 4.3174 ] Sending psc_bl1
[ 4.3277 ] Sending bct_mb1
[ 4.3338 ] Boot Rom communication completed
[ 4.3338 ] Generating blob for T23x
[ 4.3368 ] tegrahost_v2 --chip 0x23 0 --align blob_uefi_jetson_with_dtb_aligned.bin
[ 4.3389 ] tegrahost_v2 --chip 0x23 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader blob_uefi_jetson_with_dtb_aligned.bin zerosbk
[ 4.3398 ] adding BCH for blob_uefi_jetson_with_dtb_aligned.bin
[ 4.4042 ] tegrasign_v3.py --key None --list blob_uefi_jetson_with_dtb_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.4045 ] Assuming zero filled SBK key
[ 4.4121 ] Warning: pub_key.key is not found
[ 4.4116 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_uefi_jetson_with_dtb_aligned_sigheader.bin.encrypt blob_uefi_jetson_with_dtb_aligned_sigheader.bin.hash zerosbk
[ 4.4188 ] Get magic id
[ 4.4205 ] tegraparser_v2 --get_magic psc_fw
[ 4.4213 ] PFWP
[ 4.4214 ] partition type psc_fw, magic id = PFWP
[ 4.4224 ] tegrahost_v2 --chip 0x23 0 --align blob_pscfw_t234_prod_aligned.bin
[ 4.4241 ] tegrahost_v2 --chip 0x23 0 --magicid PFWP --ratchet_blob ratchet_blob.bin --appendsigheader blob_pscfw_t234_prod_aligned.bin zerosbk
[ 4.4247 ] Header already present for blob_pscfw_t234_prod_aligned.bin
[ 4.4313 ] tegrasign_v3.py --key None --list blob_pscfw_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.4317 ] Assuming zero filled SBK key
[ 4.4345 ] Warning: pub_key.key is not found
[ 4.4342 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_pscfw_t234_prod_aligned_sigheader.bin.encrypt blob_pscfw_t234_prod_aligned_sigheader.bin.hash zerosbk
[ 4.4363 ] Get magic id
[ 4.4370 ] tegraparser_v2 --get_magic mts_mce
[ 4.4379 ] MTSM
[ 4.4380 ] partition type mts_mce, magic id = MTSM
[ 4.4392 ] tegrahost_v2 --chip 0x23 0 --align blob_mce_flash_o10_cr_prod_aligned.bin
[ 4.4410 ] tegrahost_v2 --chip 0x23 0 --magicid MTSM --ratchet_blob ratchet_blob.bin --appendsigheader blob_mce_flash_o10_cr_prod_aligned.bin zerosbk
[ 4.4419 ] Header already present for blob_mce_flash_o10_cr_prod_aligned.bin
[ 4.4461 ] tegrasign_v3.py --key None --list blob_mce_flash_o10_cr_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.4463 ] Assuming zero filled SBK key
[ 4.4497 ] Warning: pub_key.key is not found
[ 4.4499 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_mce_flash_o10_cr_prod_aligned_sigheader.bin.encrypt blob_mce_flash_o10_cr_prod_aligned_sigheader.bin.hash zerosbk
[ 4.4518 ] Get magic id
[ 4.4526 ] tegraparser_v2 --get_magic mb2_applet
[ 4.4534 ] MB2A
[ 4.4535 ] partition type mb2_applet, magic id = MB2A
[ 4.4551 ] tegrahost_v2 --chip 0x23 0 --align blob_applet_t234_aligned.bin
[ 4.4567 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --ratchet_blob ratchet_blob.bin --appendsigheader blob_applet_t234_aligned.bin zerosbk
[ 4.4574 ] adding BCH for blob_applet_t234_aligned.bin
[ 4.4659 ] tegrasign_v3.py --key None --list blob_applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.4661 ] Assuming zero filled SBK key
[ 4.4700 ] Warning: pub_key.key is not found
[ 4.4701 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_applet_t234_aligned_sigheader.bin.encrypt blob_applet_t234_aligned_sigheader.bin.hash zerosbk
[ 4.4726 ] Generating recovery mb2-bct
[ 4.4726 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct.cfg --recov --mb2bctcfg tegra234-mb2-bct-misc-p3701-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3701-0000_cpp.dtb
[ 4.4734 ] WARNING: unknown property 'tfc_version'
[ 4.4745 ] WARNING: unknown property 'addr_header_version'
[ 4.4822 ] Updating mb2-bct with storage information
[ 4.4832 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct_MB2.bct --updatestorageinfo flash.xml.bin
[ 4.4847 ] Concatenating mb2-bct to mb2 binary
[ 4.4847 ] mb2_bin_file = mb2_t234.bin
[ 4.4847 ] mb2_bct_file = mb2_bct_MB2.bct
[ 4.4851 ] Get magic id
[ 4.4858 ] tegraparser_v2 --get_magic mb2_bootloader
[ 4.4866 ] MB2B
[ 4.4867 ] partition type mb2_bootloader, magic id = MB2B
[ 4.4877 ] tegrahost_v2 --chip 0x23 0 --align blob_mb2_t234_with_mb2_bct_MB2_aligned.bin
[ 4.4893 ] tegrahost_v2 --chip 0x23 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader blob_mb2_t234_with_mb2_bct_MB2_aligned.bin zerosbk
[ 4.4901 ] adding BCH for blob_mb2_t234_with_mb2_bct_MB2_aligned.bin
[ 4.5024 ] tegrasign_v3.py --key None --list blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.5027 ] Assuming zero filled SBK key
[ 4.5054 ] Warning: pub_key.key is not found
[ 4.5048 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.encrypt blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.hash zerosbk
[ 4.5066 ] Get magic id
[ 4.5073 ] tegraparser_v2 --get_magic xusb_fw
[ 4.5081 ] XUSB
[ 4.5083 ] partition type xusb_fw, magic id = XUSB
[ 4.5096 ] tegrahost_v2 --chip 0x23 0 --align blob_xusb_t234_prod_aligned.bin
[ 4.5117 ] tegrahost_v2 --chip 0x23 0 --magicid XUSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_xusb_t234_prod_aligned.bin zerosbk
[ 4.5127 ] adding BCH for blob_xusb_t234_prod_aligned.bin
[ 4.5183 ] tegrasign_v3.py --key None --list blob_xusb_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.5184 ] Assuming zero filled SBK key
[ 4.5201 ] Warning: pub_key.key is not found
[ 4.5193 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_xusb_t234_prod_aligned_sigheader.bin.encrypt blob_xusb_t234_prod_aligned_sigheader.bin.hash zerosbk
[ 4.5207 ] Kernel DTB used: kernel_tegra234-p3701-0004-p3737-0000.dtb
[ 4.5207 ] Concatenating kernel-dtb to dce-fw binary
[ 4.5207 ] dce_bin = display-t234-dce.bin
[ 4.5207 ] kernel_dtb = kernel_tegra234-p3701-0004-p3737-0000.dtb
[ 4.5207 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3701-0004-p3737-0000.bin
[ 4.5260 ] Get magic id
[ 4.5270 ] tegraparser_v2 --get_magic dce_fw
[ 4.5286 ] DCEF
[ 4.5287 ] partition type dce_fw, magic id = DCEF
[ 4.5367 ] tegrahost_v2 --chip 0x23 0 --align blob_display-t234-dce_with_kernel_tegra234-p3701-0004-p3737-0000_aligned.bin
[ 4.5386 ] tegrahost_v2 --chip 0x23 0 --magicid DCEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_display-t234-dce_with_kernel_tegra234-p3701-0004-p3737-0000_aligned.bin zerosbk
[ 4.5394 ] adding BCH for blob_display-t234-dce_with_kernel_tegra234-p3701-0004-p3737-0000_aligned.bin
[ 4.7237 ] tegrasign_v3.py --key None --list blob_display-t234-dce_with_kernel_tegra234-p3701-0004-p3737-0000_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.7238 ] Assuming zero filled SBK key
[ 4.7407 ] Warning: pub_key.key is not found
[ 4.7401 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_display-t234-dce_with_kernel_tegra234-p3701-0004-p3737-0000_aligned_sigheader.bin.encrypt blob_display-t234-dce_with_kernel_tegra234-p3701-0004-p3737-0000_aligned_sigheader.bin.hash zerosbk
[ 4.7575 ] Get magic id
[ 4.7585 ] tegraparser_v2 --get_magic nvdec
[ 4.7593 ] NDEC
[ 4.7594 ] partition type nvdec, magic id = NDEC
[ 4.7605 ] tegrahost_v2 --chip 0x23 0 --align blob_nvdec_t234_prod_aligned.fw
[ 4.7620 ] tegrahost_v2 --chip 0x23 0 --magicid NDEC --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvdec_t234_prod_aligned.fw zerosbk
[ 4.7630 ] Header already present for blob_nvdec_t234_prod_aligned.fw
[ 4.7684 ] tegrasign_v3.py --key None --list blob_nvdec_t234_prod_aligned_sigheader.fw_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.7686 ] Assuming zero filled SBK key
[ 4.7707 ] Warning: pub_key.key is not found
[ 4.7701 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_nvdec_t234_prod_aligned_sigheader.fw.encrypt blob_nvdec_t234_prod_aligned_sigheader.fw.hash zerosbk
[ 4.7721 ] Get magic id
[ 4.7728 ] tegraparser_v2 --get_magic bpmp_fw
[ 4.7736 ] BPMF
[ 4.7737 ] partition type bpmp_fw, magic id = BPMF
[ 4.7749 ] tegrahost_v2 --chip 0x23 0 --align blob_bpmp_t234-TE990M-A1_prod_aligned.bin
[ 4.7765 ] tegrahost_v2 --chip 0x23 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader blob_bpmp_t234-TE990M-A1_prod_aligned.bin zerosbk
[ 4.7773 ] Header already present for blob_bpmp_t234-TE990M-A1_prod_aligned.bin
[ 4.7901 ] tegrasign_v3.py --key None --list blob_bpmp_t234-TE990M-A1_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.7903 ] Assuming zero filled SBK key
[ 4.7933 ] Warning: pub_key.key is not found
[ 4.7927 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_bpmp_t234-TE990M-A1_prod_aligned_sigheader.bin.encrypt blob_bpmp_t234-TE990M-A1_prod_aligned_sigheader.bin.hash zerosbk
[ 4.7952 ] Using bpmp-dtb concatenated with odmdata in blob
[ 4.7953 ] Get magic id
[ 4.7963 ] tegraparser_v2 --get_magic bpmp_fw_dtb
[ 4.7973 ] BPMD
[ 4.7974 ] partition type bpmp_fw_dtb, magic id = BPMD
[ 4.7987 ] tegrahost_v2 --chip 0x23 0 --align blob_tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned.dtb
[ 4.8007 ] tegrahost_v2 --chip 0x23 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned.dtb zerosbk
[ 4.8016 ] adding BCH for blob_tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned.dtb
[ 4.8067 ] tegrasign_v3.py --key None --list blob_tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.8069 ] Assuming zero filled SBK key
[ 4.8085 ] Warning: pub_key.key is not found
[ 4.8077 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned_sigheader.dtb.encrypt blob_tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned_sigheader.dtb.hash zerosbk
[ 4.8091 ] Get magic id
[ 4.8097 ] tegraparser_v2 --get_magic sce_fw
[ 4.8105 ] SCEF
[ 4.8106 ] partition type sce_fw, magic id = SCEF
[ 4.8116 ] tegrahost_v2 --chip 0x23 0 --align blob_camera-rtcpu-sce_aligned.img
[ 4.8132 ] tegrahost_v2 --chip 0x23 0 --magicid SCEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_camera-rtcpu-sce_aligned.img zerosbk
[ 4.8139 ] adding BCH for blob_camera-rtcpu-sce_aligned.img
[ 4.8207 ] tegrasign_v3.py --key None --list blob_camera-rtcpu-sce_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.8209 ] Assuming zero filled SBK key
[ 4.8229 ] Warning: pub_key.key is not found
[ 4.8222 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_camera-rtcpu-sce_aligned_sigheader.img.encrypt blob_camera-rtcpu-sce_aligned_sigheader.img.hash zerosbk
[ 4.8237 ] Get magic id
[ 4.8244 ] tegraparser_v2 --get_magic rce_fw
[ 4.8252 ] RCEF
[ 4.8253 ] partition type rce_fw, magic id = RCEF
[ 4.8265 ] tegrahost_v2 --chip 0x23 0 --align blob_camera-rtcpu-t234-rce_aligned.img
[ 4.8283 ] tegrahost_v2 --chip 0x23 0 --magicid RCEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_camera-rtcpu-t234-rce_aligned.img zerosbk
[ 4.8292 ] adding BCH for blob_camera-rtcpu-t234-rce_aligned.img
[ 4.8420 ] tegrasign_v3.py --key None --list blob_camera-rtcpu-t234-rce_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.8423 ] Assuming zero filled SBK key
[ 4.8445 ] Warning: pub_key.key is not found
[ 4.8438 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_camera-rtcpu-t234-rce_aligned_sigheader.img.encrypt blob_camera-rtcpu-t234-rce_aligned_sigheader.img.hash zerosbk
[ 4.8463 ] Get magic id
[ 4.8472 ] tegraparser_v2 --get_magic ape_fw
[ 4.8483 ] APEF
[ 4.8486 ] partition type ape_fw, magic id = APEF
[ 4.8504 ] tegrahost_v2 --chip 0x23 0 --align blob_adsp-fw_aligned.bin
[ 4.8521 ] tegrahost_v2 --chip 0x23 0 --magicid APEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_adsp-fw_aligned.bin zerosbk
[ 4.8528 ] adding BCH for blob_adsp-fw_aligned.bin
[ 4.8636 ] tegrasign_v3.py --key None --list blob_adsp-fw_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.8639 ] Assuming zero filled SBK key
[ 4.8665 ] Warning: pub_key.key is not found
[ 4.8659 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_adsp-fw_aligned_sigheader.bin.encrypt blob_adsp-fw_aligned_sigheader.bin.hash zerosbk
[ 4.8680 ] Get magic id
[ 4.8688 ] tegraparser_v2 --get_magic spe_fw
[ 4.8696 ] SPEF
[ 4.8697 ] partition type spe_fw, magic id = SPEF
[ 4.8706 ] tegrahost_v2 --chip 0x23 0 --align blob_spe_t234_aligned.bin
[ 4.8723 ] tegrahost_v2 --chip 0x23 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_spe_t234_aligned.bin zerosbk
[ 4.8731 ] adding BCH for blob_spe_t234_aligned.bin
[ 4.8807 ] tegrasign_v3.py --key None --list blob_spe_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.8815 ] Assuming zero filled SBK key
[ 4.8845 ] Warning: pub_key.key is not found
[ 4.8838 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_spe_t234_aligned_sigheader.bin.encrypt blob_spe_t234_aligned_sigheader.bin.hash zerosbk
[ 4.8856 ] Get magic id
[ 4.8863 ] tegraparser_v2 --get_magic tos
[ 4.8871 ] TOSB
[ 4.8872 ] partition type tos, magic id = TOSB
[ 4.8885 ] tegrahost_v2 --chip 0x23 0 --align blob_tos-optee_t234_aligned.img
[ 4.8901 ] tegrahost_v2 --chip 0x23 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tos-optee_t234_aligned.img zerosbk
[ 4.8909 ] adding BCH for blob_tos-optee_t234_aligned.img
[ 4.9145 ] tegrasign_v3.py --key None --list blob_tos-optee_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.9148 ] Assuming zero filled SBK key
[ 4.9198 ] Warning: pub_key.key is not found
[ 4.9192 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tos-optee_t234_aligned_sigheader.img.encrypt blob_tos-optee_t234_aligned_sigheader.img.hash zerosbk
[ 4.9217 ] Get magic id
[ 4.9225 ] tegraparser_v2 --get_magic eks
[ 4.9233 ] EKSB
[ 4.9234 ] partition type eks, magic id = EKSB
[ 4.9244 ] tegrahost_v2 --chip 0x23 0 --align blob_eks_t234_aligned.img
[ 4.9262 ] tegrahost_v2 --chip 0x23 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_eks_t234_aligned.img zerosbk
[ 4.9272 ] adding BCH for blob_eks_t234_aligned.img
[ 4.9295 ] tegrasign_v3.py --key None --list blob_eks_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.9296 ] Assuming zero filled SBK key
[ 4.9313 ] Warning: pub_key.key is not found
[ 4.9306 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_eks_t234_aligned_sigheader.img.encrypt blob_eks_t234_aligned_sigheader.img.hash zerosbk
[ 4.9334 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 4.9348 ] The number of images in blob is 16
[ 4.9351 ] blobsize is 18121712
[ 4.9352 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3276864
[ 4.9421 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 375168
[ 4.9426 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 190592
[ 4.9429 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 277312
[ 4.9431 ] Not supported type: mb2_applet
[ 4.9432 ] Added binary blob_mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt of size 437984
[ 4.9434 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164352
[ 4.9437 ] Added binary blob_display-t234-dce_with_kernel_tegra234-p3701-0004-p3737-0000_sigheader.bin.encrypt of size 9465472
[ 4.9479 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 4.9518 ] Added binary blob_bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt of size 1048000
[ 4.9522 ] Added binary blob_tegra234-bpmp-3701-0004-3737-0000_with_odm_sigheader.dtb.encrypt of size 140416
[ 4.9525 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[ 4.9528 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 537952
[ 4.9530 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 400960
[ 4.9533 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 4.9535 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1064752
[ 4.9537 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 4.9622 ] Sending membct and RCM blob
[ 4.9634 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 4.9644 ] BL: version 0.32.0.0-t234-54845784-57325615 last_boot_error: 0
[ 4.9648 ] Sending bct_mem
[ 4.9649 ] Sending blob
[ 6.2501 ] completed
[ 6.2501 ] Retrieving storage infomation
[ 6.2514 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails storage storage_info.bin
[ 6.2526 ] MB2 version 01.00.0000
[ 7.1360 ] Saved platform info in storage_info.bin
[ 8.1434 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 8.1484 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 8.1494 ] MB2 version 01.00.0000
[ 8.1514 ] Flashing the device
[ 8.1523 ] tegraparser_v2 --storageinfo storage_info.bin --generategpt --pt flash.xml.bin
[ 8.1533 ] gpt_secondary_3_0.bin:
[ 8.1535 ] partition_id partition_name StartingLba EndingLba
[ 8.1537 ] 1 BCT 0 2047
[ 8.1540 ] 2 A_mb1 2048 3071
[ 8.1543 ] 3 A_psc_bl1 3072 3583
[ 8.1545 ] 4 A_MB1_BCT 3584 3839
[ 8.1548 ] 5 A_MEM_BCT 3840 4351
[ 8.1550 ] 6 A_tsec-fw 4352 6399
[ 8.1553 ] 7 A_nvdec 6400 8447
[ 8.1556 ] 8 A_mb2 8448 9471
[ 8.1556 ] 9 A_xusb-fw 9472 9983
[ 8.1556 ] 10 A_bpmp-fw 9984 13055
[ 8.1557 ] 11 A_bpmp-fw-dtb 13056 21247
[ 8.1557 ] 12 A_psc-fw 21248 22783
[ 8.1557 ] 13 A_mts-mce 22784 23807
[ 8.1557 ] 14 A_sc7 23808 24191
[ 8.1557 ] 15 A_pscrf 24192 24575
[ 8.1557 ] 16 A_mb2rf 24576 24831
[ 8.1557 ] 17 A_cpu-bootloader 24832 31999
[ 8.1557 ] 18 A_secure-os 32000 40191
[ 8.1557 ] 19 A_smm-fw 40192 44287
[ 8.1557 ] 20 A_eks 44288 44799
[ 8.1557 ] 21 A_dce-fw 44800 55039
[ 8.1557 ] 22 A_spe-fw 55040 56191
[ 8.1557 ] 23 A_rce-fw 56192 58239
[ 8.1557 ] 24 A_adsp-fw 58240 62335
[ 8.1557 ] 25 A_reserved_on_boot 62336 65023
[ 8.1557 ] 26 B_mb1 65024 66047
[ 8.1557 ] 27 B_psc_bl1 66048 66559
[ 8.1557 ] 28 B_MB1_BCT 66560 66815
[ 8.1557 ] 29 B_MEM_BCT 66816 67327
[ 8.1557 ] 30 B_tsec-fw 67328 69375
[ 8.1557 ] 31 B_nvdec 69376 71423
[ 8.1557 ] 32 B_mb2 71424 72447
[ 8.1557 ] 33 B_xusb-fw 72448 72959
[ 8.1557 ] 34 B_bpmp-fw 72960 76031
[ 8.1558 ] 35 B_bpmp-fw-dtb 76032 84223
[ 8.1558 ] 36 B_psc-fw 84224 85759
[ 8.1558 ] 37 B_mts-mce 85760 86783
[ 8.1558 ] 38 B_sc7 86784 87167
[ 8.1558 ] 39 B_pscrf 87168 87551
[ 8.1558 ] 40 B_mb2rf 87552 87807
[ 8.1558 ] 41 B_cpu-bootloader 87808 94975
[ 8.1558 ] 42 B_secure-os 94976 103167
[ 8.1558 ] 43 B_smm-fw 103168 107263
[ 8.1558 ] 44 B_eks 107264 107775
[ 8.1558 ] 45 B_dce-fw 107776 118015
[ 8.1558 ] 46 B_spe-fw 118016 119167
[ 8.1558 ] 47 B_rce-fw 119168 121215
[ 8.1558 ] 48 B_adsp-fw 121216 125311
[ 8.1558 ] 49 B_reserved_on_boot 125312 127999
[ 8.1558 ] 50 uefi_variables 128000 128511
[ 8.1558 ] 51 uefi_ftw 128512 129535
[ 8.1558 ] 52 worm 129920 130303
[ 8.1558 ] 53 BCT-boot-chain_backup 130304 130431
[ 8.1558 ] 54 reserved_partition 130432 130559
[ 8.1558 ] 55 secondary_gpt_backup 130560 130687
[ 8.1559 ] 56 B_VER 130688 130815
[ 8.1559 ] 57 A_VER 130816 130943
[ 8.1559 ] gpt_primary_1_3.bin:
[ 8.1559 ] partition_id partition_name StartingLba EndingLba
[ 8.1559 ] 1 APP 3050048 124320319
[ 8.1559 ] 2 A_kernel 40 262183
[ 8.1559 ] 3 A_kernel-dtb 262184 263719
[ 8.1559 ] 4 A_reserved_on_user 263720 328487
[ 8.1559 ] 5 B_kernel 328488 590631
[ 8.1559 ] 6 B_kernel-dtb 590632 592167
[ 8.1559 ] 7 B_reserved_on_user 592168 656935
[ 8.1559 ] 8 recovery 656936 820775
[ 8.1559 ] 9 recovery-dtb 820776 821799
[ 8.1559 ] 10 esp 821800 952871
[ 8.1559 ] 11 recovery_alt 952872 1116711
[ 8.1559 ] 12 recovery-dtb_alt 1116712 1117735
[ 8.1559 ] 13 esp_alt 1117736 1248807
[ 8.1559 ] 14 reserved 1248808 3050023
[ 8.1559 ] gpt_secondary_1_3.bin:
[ 8.1560 ] 12 recovery-dtb_alt 1116712 1117735
[ 8.1560 ] 13 esp_alt 1117736 1248807
[ 8.1560 ] 14 reserved 1248808 3050023
[ 8.1560 ]
[ 8.1560 ] Start flashing
[ 8.1572 ] tegradevflash_v2 --pt flash.xml.bin --create
[ 8.1584 ] Bootloader version 01.00.0000
[ 8.1603 ] Erasing spi: 0 ......... [Done]
[ 201.1747 ] Writing partition secondary_gpt with gpt_secondary_3_0.bin [ 16896 bytes ]
[ 201.1749 ] [................................................] 100%
[ 201.3942 ] Erasing sdmmc_user: 3 ......... [Done]
[ 203.4714 ] Writing partition master_boot_record with mbr_1_3.bin [ 512 bytes ]
[ 203.4717 ] [................................................] 100%
[ 203.4746 ] Writing partition primary_gpt with gpt_primary_1_3.bin [ 16896 bytes ]
[ 203.4768 ] [................................................] 100%
[ 203.4803 ] Writing partition secondary_gpt with gpt_secondary_1_3.bin [ 16896 bytes ]
[ 203.4874 ] [................................................] 100%
[ 203.4971 ] Writing partition A_mb1 with mb1_t234_prod_aligned_sigheader.bin.encrypt [ 268240 bytes ]
[ 203.4975 ] [................................................] 100%
[ 203.5090 ] Writing partition A_psc_bl1 with psc_bl1_t234_prod_aligned_sigheader.bin.encrypt [ 119616 bytes ]
[ 206.8048 ] [................................................] 100%
[ 206.8123 ] Writing partition A_nvdec with nvdec_t234_prod_sigheader.fw.encrypt [ 294912 bytes ]
[ 208.2875 ] [................................................] 100%
[ 208.2998 ] Writing partition A_mb2 with mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt [ 437984 bytes ]
[ 211.9204 ] [................................................] 100%
[ 211.9378 ] Writing partition A_xusb-fw with xusb_t234_prod_sigheader.bin.encrypt [ 164352 bytes ]
[ 217.3193 ] [................................................] 100%
[ 217.3581 ] Writing partition A_bpmp-fw with bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt [ 1048000 bytes ]
[ 219.3766 ] [................................................] 100%
[ 219.4131 ] Writing partition A_bpmp-fw-dtb with tegra234-bpmp-3701-0004-3737-0000_with_odm_sigheader.dtb.encrypt [ 140416 bytes ]
[ 232.2729 ] [................................................] 100%
[ 232.2802 ] Writing partition A_psc-fw with pscfw_t234_prod_sigheader.bin.encrypt [ 375168 bytes ]
[ 234.0129 ] [................................................] 100%
[ 234.0274 ] Writing partition A_mts-mce with mce_flash_o10_cr_prod_sigheader.bin.encrypt [ 190592 bytes ]
[ 238.6362 ] [................................................] 100%
[ 238.6448 ] Writing partition A_sc7 with sc7_t234_prod_sigheader.bin.encrypt [ 167344 bytes ]
[ 240.9929 ] [................................................] 100%
[ 241.0011 ] Writing partition A_pscrf with psc_rf_t234_prod_sigheader.bin.encrypt [ 119104 bytes ]
[ 243.0605 ] [................................................] 100%
[ 243.0675 ] Writing partition A_mb2rf with mb2rf_t234_sigheader.bin.encrypt [ 122784 bytes ]
[ 244.5359 ] [................................................] 100%
[ 244.5429 ] Writing partition A_cpu-bootloader with uefi_jetson_with_dtb_sigheader.bin.encrypt [ 3276864 bytes ]
[ 246.0551 ] [................................................] 100%
[ 284.7457 ] Writing partition A_secure-os with tos-optee_t234_sigheader.img.encrypt [ 1064752 bytes ]
[ 286.3643 ] [................................................] 100%
[ 299.2633 ] Writing partition A_eks with eks_t234_sigheader.img.encrypt [ 9232 bytes ]
[ 299.4693 ] [................................................] 100%
[ 299.4729 ] Writing partition A_dce-fw with display-t234-dce_with_kernel_tegra234-p3701-0004-p3737-0000_aligned_blob_w_bin_sigheader.bin.encrypt [ 744640 bytes ]
[ 299.5975 ] [................................................] 100%
[ 299.6229 ] Writing partition A_spe-fw with spe_t234_sigheader.bin.encrypt [ 270336 bytes ]
[ 308.7644 ] [................................................] 100%
[ 308.7762 ] Writing partition A_rce-fw with camera-rtcpu-t234-rce_sigheader.img.encrypt [ 537952 bytes ]
[ 312.0948 ] [................................................] 100%
[ 312.1147 ] Writing partition A_adsp-fw with adsp-fw_sigheader.bin.encrypt [ 400960 bytes ]
[ 318.7196 ] [................................................] 100%
[ 318.7352 ] Writing partition B_mb1 with mb1_t234_prod_aligned_sigheader.bin.encrypt [ 268240 bytes ]
[ 323.6638 ] [................................................] 100%
[ 323.6749 ] Writing partition B_psc_bl1 with psc_bl1_t234_prod_aligned_sigheader.bin.encrypt [ 119616 bytes ]
[ 326.9705 ] [................................................] 100%
[ 326.9781 ] Writing partition B_nvdec with nvdec_t234_prod_sigheader.fw.encrypt [ 294912 bytes ]
[ 328.4523 ] [................................................] 100%
[ 328.4644 ] Writing partition B_mb2 with mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt [ 437984 bytes ]
[ 332.0841 ] [................................................] 100%
[ 332.1006 ] Writing partition B_xusb-fw with xusb_t234_prod_sigheader.bin.encrypt [ 164352 bytes ]
[ 337.4804 ] [................................................] 100%
[ 337.4892 ] Writing partition B_bpmp-fw with bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt [ 1048000 bytes ]
[ 339.5086 ] [................................................] 100%
[ 339.5438 ] Writing partition B_bpmp-fw-dtb with tegra234-bpmp-3701-0004-3737-0000_with_odm_sigheader.dtb.encrypt [ 140416 bytes ]
[ 352.4031 ] [................................................] 100%
[ 352.4111 ] Writing partition B_psc-fw with pscfw_t234_prod_sigheader.bin.encrypt [ 375168 bytes ]
[ 354.1435 ] [................................................] 100%
[ 354.1584 ] Writing partition B_mts-mce with mce_flash_o10_cr_prod_sigheader.bin.encrypt [ 190592 bytes ]
[ 358.7667 ] [................................................] 100%
[ 358.7761 ] Writing partition B_sc7 with sc7_t234_prod_sigheader.bin.encrypt [ 167344 bytes ]
[ 361.1237 ] [................................................] 100%
[ 361.1321 ] Writing partition B_pscrf with psc_rf_t234_prod_sigheader.bin.encrypt [ 119104 bytes ]
[ 363.1907 ] [................................................] 100%
[ 363.1980 ] Writing partition B_mb2rf with mb2rf_t234_sigheader.bin.encrypt [ 122784 bytes ]
[ 364.6659 ] [................................................] 100%
[ 364.6734 ] Writing partition B_cpu-bootloader with uefi_jetson_with_dtb_sigheader.bin.encrypt [ 3276864 bytes ]
[ 366.1855 ] [................................................] 100%
[ 404.8758 ] Writing partition B_secure-os with tos-optee_t234_sigheader.img.encrypt [ 1064752 bytes ]
[ 406.4946 ] [................................................] 100%
[ 419.3940 ] Writing partition B_eks with eks_t234_sigheader.img.encrypt [ 9232 bytes ]
[ 419.6004 ] [................................................] 100%
[ 419.6038 ] Writing partition B_dce-fw with display-t234-dce_with_kernel_tegra234-p3701-0004-p3737-0000_aligned_blob_w_bin_sigheader.bin.encrypt [ 744640 bytes ]
[ 419.7296 ] [................................................] 100%
[ 419.7555 ] Writing partition B_spe-fw with spe_t234_sigheader.bin.encrypt [ 270336 bytes ]
[ 428.8976 ] [................................................] 100%
[ 428.9089 ] Writing partition B_rce-fw with camera-rtcpu-t234-rce_sigheader.img.encrypt [ 537952 bytes ]
[ 432.2275 ] [................................................] 100%
[ 432.2476 ] Writing partition B_adsp-fw with adsp-fw_sigheader.bin.encrypt [ 400960 bytes ]
[ 438.8519 ] [................................................] 100%
[ 438.8683 ] Writing partition B_VER with qspi_bootblob_ver.txt [ 109 bytes ]
[ 443.7959 ] [................................................] 100%
[ 443.7994 ] Writing partition A_VER with qspi_bootblob_ver.txt [ 109 bytes ]
[ 443.8088 ] [................................................] 100%
[ 443.8127 ] Writing partition master_boot_record with mbr_1_3.bin [ 512 bytes ]
[ 443.8221 ] [................................................] 100%
[ 443.8252 ] Writing partition A_kernel with boot.img [ 43065344 bytes ]
[ 443.8305 ] [................................................] 100%
[ 445.3760 ] Writing partition A_kernel-dtb with kernel_tegra234-p3701-0004-p3737-0000.dtb [ 368247 bytes ]
[ 445.3784 ] [................................................] 100%
[ 445.3932 ] Writing partition B_kernel with boot.img [ 43065344 bytes ]
[ 445.3973 ] [................................................] 100%
[ 446.9611 ] Writing partition B_kernel-dtb with kernel_tegra234-p3701-0004-p3737-0000.dtb [ 368247 bytes ]
[ 446.9627 ] [................................................] 100%
[ 446.9778 ] Writing partition recovery with recovery.img [ 46723072 bytes ]
[ 446.9826 ] [................................................] 100%
[ 448.6661 ] Writing partition recovery-dtb with tegra234-p3701-0004-p3737-0000.dtb.rec [ 368247 bytes ]
[ 448.6705 ] [................................................] 100%
[ 448.6853 ] Writing partition esp with esp.img [ 67108864 bytes ]
[ 448.6892 ] [................................................] 100%
[ 451.1101 ] Writing partition APP with system.img [ 3797291008 bytes ]
Error: Return value 3 ] 000%
Command tegradevflash_v2 --pt flash.xml.bin --create
Failed flashing t186ref.
I am not sure what I can do now.
Additional information: I am flashing from a Docker runned with /dev/bus/usb:/dev/bus/usb command to link the computer USB to Docker USB. However it should not change anything since all the usefull files are in the Docker and I am not exiting the container between two steps.
Here what’s happening in the Dockerfile that generated the container:
It gets rootfs from there, R35.3.1 from here and the firmware from the vendor I sent you above. Then it copies files from the kernel_out folder of the vendor BSP into Linux_for_Tegra folder , and run the apply_binaries script. According to these flashing instructions from the vendor:
1. prepare the sdk
ONLY NEEDED IF NO AGX ORIN WAS FLASHED BEFORE
-start the sdkmanager
-select the Jetson AGX Orin modules as target Hardware
-select Jetpack 5.1.1 as target operating system
-start the installation until the sdk asks you for either use automatic or manual setup
-> at this point you can choose to "skip" the rest of the installation and continue with step 2 of this instructions
2. copy the contents of the kernel_out folder in the auvidea packet to the nvida_sdk folder
-> cp ~/kernel_out/* /home/USER/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra
3. switch in the AGX Orin folder and apply binaries
-> cd /home/USER/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra
-> sudo ./apply_binaries.sh
4. start the sdkmanger and follow the normal installation process
You can also use the following commands to flash the AGX Orin after Step 3:
cd /home/USER/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/
sudo ./flash jetson-agx-orin-devkit mmcblk0p1
The thing is that all of this worked perfectly for the standard image, and failed for the cloned one, that’s why I am confident about the docker.
The only difference I noticed with the docker is that If I try to flash the cloned image from a freshly runned Docker, I get an error saying that esp.img is missing. I need to flash it with the standard image in order to have a esp.img file and then try the flashing with the cloned image (in order to remove this error).
Ideally I would like to be able to flash a new card that has never been flashed, with the cloned image directly.
I am not sure what I cant try now.
