Jetson is not switching to the login screen stuck in the boot stage, I am getting the first screen where it shows NVIDIA and options to select like F11, after that there is a blinking on the top right corner of the screen and It is not moving forward before it has happened and I reflashed it, but I don’t want to use the reflash without knowing the actual cause and I don’t want to lose the data, can anyone help me solve this situation.
Since the board still reaches the NVIDIA/UEFI screen, please try the following checks before reflashing:
Select the boot device manually
Press F11 at the NVIDIA/UEFI screen and select the boot device where Jetson Linux is installed, such as NVMe, SD card, USB, or eMMC. -
Remove extra boot media
Disconnect any extra USB storage or SD card that is not your intended boot device, then power cycle the board and try again. -
Check the boot media connection
If your rootfs is on removable media, please power off the board and reseat the NVMe, SD card, or USB drive. -
Try a text console
At the blinking cursor, tryCtrl+Alt+F2orCtrl+Alt+F3to check whether a text login console appears.
If it still stops at the same point, please share the following information:
- JetPack/L4T version
- exact Jetson module and carrier board
- boot media type
- full UART serial console log from power-on until it stops
For reference, the Jetson Linux documentation describes selecting the boot device from the UEFI Boot Manager:
Hope this helps!
Do you know why this particular boot error happens? Because, I faced this boot issue thrice already and every time I cannot flash the jetson every time.
From the HDMI symptom alone, we cannot identify one single root cause yet.
Since the board reaches the NVIDIA/UEFI screen, the early power-on and firmware stage is getting far enough to show the UEFI menu. The failure is likely after boot selection starts, for example boot order selecting the wrong device, boot media not being detected reliably, rootfs/file-system corruption, kernel boot failure, or the login/display service not starting.
Because you have seen this issue three times already, please do not reflash immediately next time it happens. Please capture the full UART serial console log from power-on until it reaches the blinking cursor, and also share:
- boot media type, such as NVMe, eMMC, SD card, or USB
- whether F11 Boot Manager can show and boot the intended boot device manually
Recommendation: The UART log is the key item to find the actual cause without losing data. The HDMI blinking cursor only shows the visible symptom; the serial console should show whether boot stops in UEFI, kernel loading, rootfs mount, or userspace/login.
