I am trying to flash Jetson Nano J1010 using SDK Manager on Ubuntu 20.04 LTS. But I can not find any jumper, so that I can put the device in recovery mode for Flash?
Apart from that, when I tried to connect the Jetson Nano J1010 using PC for Installation. SDK manager not detecting the device and the reason which I think is because Jetson Nano is not in recovery mode.
If your board is still able to boot into linux, then you can use command to let to enter recovery mode. However, if it cannot, then you need to find a jumper to do that. So please let us know if it still can boot or not.
Make sure your board is really in recovery mode. You can use serial console to tell it. When the board is in RCM, it is basically brick. You won’t see any log and it will not respond to you in serial console.
