Jetson Jetpack 4.5.1 endless reboot
After using SDK Manager (latest) to flash OS to AGX-1 the AGX-1 is now stuck in endless reboot showing nVidia splash screen, and then black, and then nVidia splash screen.
I expected SDK manager to reset everything, but it appears that the boot sequence is wrong. I had previously flash JP4.4.1 and modified boot to use sda1 rather than mmcblkp01 for the /dev/sda1 (see below).
sed -i -e "s/mmcblk0p1/sda1/" /mnt/boot/extlinux/extlinux.conf
Is there a special mechanism for full factory reset on AGX-1 prior to use of SDK Manager? I have been unplugging AGX-1 and then pressing center button and holding and pressing left button (front); successful in recovery mode and USB connection to Ubuntu18.04 VM on macOS11.2.3 using VirtualBox (latest).
I also tried flashing uSD card with JetPack 4.5.1 uSD card image for Xavier NX; it worked in the same fashion, i.e. endless reboot w/ nVidia splash screens.
Device also has 500 GB nVME in M2 slot; 1 TB SSD connected via USB3 cable.
IDK; reflashed MMC w/o uSD card. All good now.
Is your issue on AGX or on NX?
When you see those errors on AGX, do you also have M2 card and SSD connected at that case?
The M2 card is attached and uSD card is attached and presenting as /dev/sda
FIXED:
  1. Setup Ubuntu18 VM w/ 100 GB of disk a 4 vCPU
  2. Install nVidia SDK Manager
  3. Run SDK Manager and put AGX-1 into recovery mode
  4. Insert 32GB uSD card (n.b. flashed with Jetson NX JP4.5.1; don’t think it mattered)
  5. Perform all tasks in SDK manager to flash and install OS
  6. Power-off AGX-1 when it begins reboot cycle; remove uSD card
  7. Power-on and start AGX-1
This solution worked with a 32 GB AGX-1 with attached nVME storage (500GB) and no other storage attached (e.g. external SSD USB disk)
