We are currently running our devices on Jetson Linux R35.4.1 JetPack 5.1.2 and wanted to upgrade cuda through the cuda update path described here: CUDA for Tegra
We are however using Yocto and the meta-tegra project to build and deploy our stack.
We have gotten cuda 12.5 on the device, and we can successfully run the deviceQuery app from the cuda-samples package that confirms that cuda 12.5 works.
However according to chapter 6.2.1 JetPack 5 only supports cuda upgrades up to cuda 12.2.
Why is not higher cuda versions supported?
What is potentially breaking by running cuda 12.5?
A newer CUDA 12 version is available with the JetPack 6 environment.
Since JetPack is Ubuntu22.04, the package cannot be installed on JetPack 5 which is Ubuntu 20.04.
