I use L4T Driver Package of Jetson Linux 34.1 to flash xavier dev board, the xavier can bring up successfully and lcd display normally.
Then I build an Image from source code of Jetson Linux 34.1, and replace the Image in the target with the one I just built.
The problem is that: the lcd can not bring up, but log can be output from serial port, and I can log in from serial terminal.
Problem two:
I use L4T Driver Package of Jetson Linux 34.1 to flash orin dev board, the orin dev board only display logo during bring up and then lcd become black and display nothing. But log can be output from serial port, and I can log in from serial terminal.
I am using nvidia developer kit. I have tested flash up using skdmanager and Linux_for_tegra tool generated from Jetson Linux 34.1 | NVIDIA Developer. Both method can not bring up lcd.
