when I fellow the page to install jetpack on Jetson 36.3.0, it gives me the error:
root@mtdpjiangnbk:/# sudo apt -y install nvidia-jetpack
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
nvidia-jetpack : Depends: nvidia-jetpack-runtime (= 6.0+b106) but it is not going to be installed
Depends: nvidia-jetpack-dev (= 6.0+b106) but it is not going to be installed
nvidia-l4t-jetsonpower-gui-tools : Depends: nvidia-l4t-core (= 36.3.0-20240719161631) but 36.3.0-20240506102626 is to be installed
nvidia-l4t-nvfancontrol : Depends: nvidia-l4t-core (= 36.3.0-20240719161631) but 36.3.0-20240506102626 is to be installed
nvidia-l4t-nvpmodel : Depends: nvidia-l4t-core (= 36.3.0-20240719161631) but 36.3.0-20240506102626 is to be installed
nvidia-l4t-nvpmodel-gui-tools : Depends: nvidia-l4t-core (= 36.3.0-20240719161631) but 36.3.0-20240506102626 is to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
debconf: delaying package configuration, since apt-utils is not installed
/var/lib/dpkg/tmp.ci/preinst: line 43: /proc/device-tree/compatible: No such file or directory
dpkg: error processing archive /tmp/apt-dpkg-install-OH2Stm/18-nvidia-l4t-core_36.2.0-20231218214829_arm64.deb (--unpack):
new nvidia-l4t-core package pre-installation script subprocess returned error exit status 1
/bin/df: no file systems processed
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
I do same thing on 36.4.3 and it is working fine, but I cannot use 36.4.3 for now as I need Jetpack 6.0
Please let me know if that is a known issue or something?
thanks
root@mtdpjiangnbk:/# dpkg-query --show nvidia-l4t-core
nvidia-l4t-core 36.2.0-20231130105725
root@mtdpjiangnbk:/# apt -y install nvidia-jetpack
nvidia-jetpack : Depends: nvidia-jetpack-runtime (= 6.0-b52) but it is not going to be installed
Depends: nvidia-jetpack-dev (= 6.0-b52) but it is not going to be installed
nvidia-l4t-jetsonpower-gui-tools : Depends: nvidia-l4t-core (= 36.2.0-20231218214829) but 36.2.0-20231130105725 is to be installed
nvidia-l4t-nvfancontrol : Depends: nvidia-l4t-core (= 36.2.0-20231218214829) but 36.2.0-20231130105725 is to be installed
nvidia-l4t-nvpmodel : Depends: nvidia-l4t-core (= 36.2.0-20231218214829) but 36.2.0-20231130105725 is to be installed
nvidia-l4t-nvpmodel-gui-tools : Depends: nvidia-l4t-core (= 36.2.0-20231218214829) but 36.2.0-20231130105725 is to be installed
sorry for confusion, I tried 36.3.0 first, it does not work, then I tried 36.2.0, same problem.
I use this command in a PC/QEMU environment to build a image to burn.
Hi @DavidDDD , I got a little further today, when I install jetpack on a Orin board, it complain rootfs ab enabled, I think the reason is same as below
I am confused that why install jetpack has anything to do with rootfs ab. May I know any solution or workaround for it?
the goal for us is to create an image in cloud which has jetpack installed, then just program the image to the Orin device.
That is reason cannot use sdk manager or run in the device. thanks
Preparing to unpack .../18-nvidia-l4t-core_36.3.0-20240719161631_arm64.deb ...
WARNING: rootfs A/B is enabled, can not update using Debian OTA, quit.
dpkg: error processing archive /tmp/apt-dpkg-install-TKo4Jy/18-nvidia-l4t-core_36.3.0-20240719161631_arm64.deb (--unpack):
we use an ARM64 docker container to prepare an image first, the jetpack etc are installed in this image. Then we just flash the image to different device.
Now the jetpack 6.0 cannot install on this image (jetpack 6.1 works on Jetson Linux 36.4.3).
I know we can clone this device has installed jetpack 6.0 , but it requires manual steps etc which we try to avoid.
So the goal still run a PC base building image, and in PC it can simulate ARM64 and install jetpack etc to a image, then just program the image to different devices.
also if we run full disk image encryption, the clone method does not work.
Thanks ~0507
We have the developer kit Orin NX module + Orin Nano carrier board. Please share the steps to replicate the issue. We will set up the developer kit and check.
