HI nVidia:
My system is running Jetson Linux 39.2.
After both cameras are opened, if I close and reopen the cameras, they may fail to start again. The relevant logs:
[ 250.849888] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c18 mask=0x06070000 value=0x04020000 (was 0x04020100)
[ 250.849890] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c84 mask=0x00000fff value=0x00000555 (was 0x00000666)
[ 250.849892] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c00 mask=0x00000001 value=0x00000000 (was 0x00000000)
[ 250.849894] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c88 mask=0x0000003c value=0x00000000 (was 0x00000541)
[ 250.849896] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021ce4 mask=0x000000ff value=0x00000027 (was 0x00007427)
[ 250.849898] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c84 mask=0x00000fff value=0x00000666 (was 0x00000555)
[ 250.849900] [RCE] CSI port CD IDAC calibration result with freqband=0:
[ 250.849902] [RCE] Trio A0 rxab=18 rxbc=19 rxca=15
[ 250.849904] [RCE] Trio A1 rxab=16 rxbc=19 rxca=18
[ 250.849905] [RCE] CSI port CD IDAC calibration result with freqband=0:
[ 250.849907] [RCE] Trio B0 rxab=18 rxbc=18 rxca=19
[ 250.849909] [RCE] Trio B1 rxab=22 rxbc=16 rxca=20
[ 250.849911] [RCE] CSI port CD
[ 250.849913] [RCE] AFE_HFGAIN_IO0_A=6
[ 250.849914] [RCE] AFE_HFGAIN_IO1_A=6
[ 250.849916] [RCE] AFE_HFGAIN_CLK_A=6
[ 250.849918] [RCE] AFE_HFGAIN_IO0_B=6
[ 250.849919] [RCE] AFE_HFGAIN_IO1_B=6
[ 250.849921] [RCE] AFE_HFGAIN_CLK_B=6
[ 251.297768] [RCE] VI ch[11] frame configuration: 1920x1080
[ 251.297782] [RCE] left skip pixels=0 top skip lines=0
[ 251.297785] [RCE] right crop pixels=0 bottom crop lines=0
[ 251.297787] [RCE] pixel format=VI_PIXFMT_FORMAT_T_R16 fmt=196
[ 264.141463] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c18 mask=0x06070000 value=0x04020000 (was 0x04020000)
[ 264.141477] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c84 mask=0x00000fff value=0x00000555 (was 0x00000666)
[ 264.141480] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c00 mask=0x00000001 value=0x00000000 (was 0x00000000)
[ 264.141482] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c88 mask=0x0000003c value=0x00000000 (was 0x00000541)
[ 264.141485] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021ce4 mask=0x000000ff value=0x00000027 (was 0x00007427)
[ 264.141487] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c84 mask=0x00000fff value=0x00000666 (was 0x00000555)
[ 269.033937] tegra194-vi5 13e00000.host1x:vi1@14c00000: [PIPELINE 0] VI capture setup complete (channel_id=1, csi_stream=2, vc=0)
[ 269.061346] [RCE] ===== NVCSI Stream Configuration =====
[ 269.061364] [RCE] stream_id: PP 2, csi_port: PORT C
[ 269.061367] [RCE] Brick: PHY 1, Mode: D-PHY
[ 269.061369] [RCE] Partition: CIL A, LP bypass: Enabled, Lanes: 2
[ 269.061371] [RCE] Clock information:
[ 269.061373] [RCE] CIL rate: 408000000 Hz
[ 269.061376] [RCE] MIPI clock rate: 750000 kHz
[ 269.061378] [RCE] Physical rate: 1500000 Kbps
[ 269.061380] [RCE] T_HS settle: autoconfigured, T_CLK settle: autoconfigured
[ 269.061383] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c18 mask=0x06070000 value=0x04020000 (was 0x04020100)
[ 269.061385] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c84 mask=0x00000fff value=0x00000555 (was 0x00000666)
[ 269.061388] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c00 mask=0x00000001 value=0x00000000 (was 0x00000000)
[ 269.061390] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c88 mask=0x0000003c value=0x00000000 (was 0x00000541)
[ 269.061392] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021ce4 mask=0x000000ff value=0x00000027 (was 0x00007427)
[ 269.061395] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c84 mask=0x00000fff value=0x00000666 (was 0x00000555)
[ 269.061397] [RCE] CSI port CD IDAC calibration result with freqband=0:
[ 269.061399] [RCE] Trio A0 rxab=18 rxbc=19 rxca=15
[ 269.061400] [RCE] Trio A1 rxab=16 rxbc=19 rxca=18
[ 269.061402] [RCE] CSI port CD IDAC calibration result with freqband=0:
[ 269.061404] [RCE] Trio B0 rxab=18 rxbc=18 rxca=19
[ 269.061406] [RCE] Trio B1 rxab=22 rxbc=16 rxca=20
[ 269.061408] [RCE] CSI port CD
[ 269.061410] [RCE] AFE_HFGAIN_IO0_A=6
[ 269.061411] [RCE] AFE_HFGAIN_IO1_A=6
[ 269.061413] [RCE] AFE_HFGAIN_CLK_A=6
[ 269.061415] [RCE] AFE_HFGAIN_IO0_B=6
[ 269.061417] [RCE] AFE_HFGAIN_IO1_B=6
[ 269.061418] [RCE] AFE_HFGAIN_CLK_B=6
[ 269.216347] tegra194-vi5 13e00000.host1x:vi1@14c00000: [PIPELINE 0] VI capture setup complete (channel_id=1, csi_stream=2, vc=0)
[ 269.229344] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c18 mask=0x06070000 value=0x04020000 (was 0x04020000)
[ 269.229358] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c84 mask=0x00000fff value=0x00000555 (was 0x00000666)
[ 269.229361] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c00 mask=0x00000001 value=0x00000000 (was 0x00000000)
[ 269.229364] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c88 mask=0x0000003c value=0x00000000 (was 0x00000541)
[ 269.229367] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021ce4 mask=0x000000ff value=0x00000027 (was 0x00007427)
[ 269.229394] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c84 mask=0x00000fff value=0x00000666 (was 0x00000555)
[ 269.229398] [RCE] ===== NVCSI Stream Configuration =====
[ 269.229400] [RCE] stream_id: PP 2, csi_port: PORT C
[ 269.229402] [RCE] Brick: PHY 1, Mode: D-PHY
[ 269.229404] [RCE] Partition: CIL A, LP bypass: Enabled, Lanes: 2
[ 269.229406] [RCE] Clock information:
[ 269.229408] [RCE] CIL rate: 408000000 Hz
[ 269.229410] [RCE] MIPI clock rate: 750000 kHz
[ 269.229412] [RCE] Physical rate: 1500000 Kbps
[ 269.229414] [RCE] T_HS settle: autoconfigured, T_CLK settle: autoconfigured
[ 269.229417] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c18 mask=0x06070000 value=0x04020000 (was 0x04020100)
[ 269.229420] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c84 mask=0x00000fff value=0x00000555 (was 0x00000666)
[ 269.229423] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c00 mask=0x00000001 value=0x00000000 (was 0x00000000)
[ 269.229425] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c88 mask=0x0000003c value=0x00000000 (was 0x00000541)
[ 269.229427] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021ce4 mask=0x000000ff value=0x00000027 (was 0x00007427)
[ 269.229430] [RCE] NVCSI prod write phy: 1 cil: 0 reg=0x00021c84 mask=0x00000fff value=0x00000666 (was 0x00000555)
[ 269.229433] [RCE] CSI port CD IDAC calibration result with freqband=0:
[ 269.229435] [RCE] Trio A0 rxab=18 rxbc=19 rxca=15
[ 269.229437] [RCE] Trio A1 rxab=16 rxbc=19 rxca=18
[ 269.229439] [RCE] CSI port CD IDAC calibration result with freqband=0:
[ 269.229441] [RCE] Trio B0 rxab=18 rxbc=18 rxca=19
[ 269.229443] [RCE] Trio B1 rxab=22 rxbc=16 rxca=20
[ 269.229445] [RCE] CSI port CD
[ 269.229447] [RCE] AFE_HFGAIN_IO0_A=6
[ 269.229449] [RCE] AFE_HFGAIN_IO1_A=6
[ 269.229451] [RCE] AFE_HFGAIN_CLK_A=6
[ 269.229452] [RCE] AFE_HFGAIN_IO0_B=6
[ 269.229454] [RCE] AFE_HFGAIN_IO1_B=6
[ 269.229456] [RCE] AFE_HFGAIN_CLK_B=6
[ 269.737331] [RCE] VI ch[11] frame configuration: 1920x1080
[ 269.737350] [RCE] left skip pixels=0 top skip lines=0
[ 269.737356] [RCE] right crop pixels=0 bottom crop lines=0
[ 269.737360] [RCE] pixel format=VI_PIXFMT_FORMAT_T_R16 fmt=196
[ 274.797230] tegra-i2c 3180000.i2c: I2C transfer timed out
[ 274.798097] regmap_util_write_table_8:regmap_util_write_table:-110
[ 274.798108] imx477 9-001a: Error writing mode
[ 274.901235] tegra-i2c 3180000.i2c: I2C transfer timed out
[ 274.902068] imx477 9-001a: imx477_write_reg: i2c write failed, 0x104 = 1
[ 274.902260] imx477 9-001a: imx477_set_group_hold: Group hold control error
[ 274.903709] ------------[ cut here ]------------
[ 274.903720] WARNING: CPU: 2 PID: 4235 at drivers/media/v4l2-core/v4l2-subdev.c:410 call_s_stream+0xdc/0xe8 [videodev]
[ 274.903775] Modules linked in: bnep governor_pod_scaling(O) qrtr usb_f_ncm usb_f_mass_storage nvidia_drm(O) nvidia_modeset(O) nvidia(O) nvgpu(O) usb_f_acm u_serial usb_f_rndis u_ether libcomposite snd_soc_tegra_controls(O) snd_soc_tegra_utils(O) snd_soc_tegra210_admaif snd_soc_tegra_pcm r8168(O) snd_soc_tegra186_asrc snd_soc_tegra210_sfc snd_soc_tegra210_mixer snd_soc_tegra210_ope snd_soc_tegra210_mvc snd_soc_tegra210_amx snd_soc_tegra210_i2s snd_soc_tegra210_adx snd_soc_tegra210_ahub tegra210_adma nvadsp(O) nvvrs_pseq_rtc(O) rtk_btusb(O) nvhost_nvcsi(O) nvhost_pva(O) btrtl nvhost_nvdla(O) btintel nvhost_vi5(O) btmtk btbcm bluetooth iwlmvm ecdh_generic ecc cp210x usbserial nvmap(O) crct10dif_ce nvsciipc(O) snd_soc_tegra_audio_graph_card mac80211 ivc_cdev(O) snd_soc_audio_graph_card snd_soc_simple_card_utils tegra234_oc_event(O) libarc4 fusb301(O) mttcan(O) nvpmodel_clk_cap(O) tegra_dce(O) iwlwifi arm_dsu_pmu nvpps(O) ina3221 can_dev thermal_trip_event(O) tegra_bpmp_bwmgr(O) tegra_cactmon_mc_all(O) cfg80211
[ 274.903883] nv_imx477(O) tegra234_aon(O) tegra_aconnect snd_hda_codec_hdmi at24 pwm_tegra_tachometer(O) snd_hda_tegra snd_hda_codec rfkill snd_hda_core optee_rng mc_hwpm(O) spi_tegra114 nvidia_vrs_pseq(O) rng_core host1x_fence(O) ramoops reed_solomon tpm_ftpm_tee camera_diagnostics(O) nvhost_isp5(O) tegra_capture_isp(O) tegra_camera(O) v4l2_dv_timings host1x_nvhost(O) tegra_drm(O) tegra_wmark(O) nvhwpm(O) drm_display_helper drm_dp_aux_bus cec host1x(O) tegra_camera_platform(O) mc_utils(O) capture_ivc(O) v4l2_fwnode v4l2_async videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 videodev videobuf2_common mc camchar(O) rtcpu_debug(O) tegra_camera_rtcpu(O) ivc_bus(O) hsp_mailbox_client(O) br_netfilter bridge stp llc nvme_fabrics fuse nfnetlink ip_tables x_tables ipv6 pwm_fan pwm_tegra tegra_bpmp_thermal tegra_xudc uas ucsi_ccg typec_ucsi typec nvme nvme_core phy_tegra194_p2u pcie_tegra194
[ 274.903993] CPU: 2 PID: 4235 Comm: CaptureSchedule Tainted: G O 6.8.12-tegra #2
[ 274.904000] Hardware name: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit/Jetson, BIOS 39.2.0-gcid-45755727 06/01/2026
[ 274.904004] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 274.904010] pc : call_s_stream+0xdc/0xe8 [videodev]
[ 274.904044] lr : tegra_channel_set_stream+0x27c/0x44c [tegra_camera]
[ 274.904084] sp : ffff80008c76ba30
[ 274.904086] x29: ffff80008c76ba30 x28: ffffa525c9288a20 x27: ffffa525c8933000
[ 274.904094] x26: ffff000089770108 x25: ffffa525c8933008 x24: 0000000000000000
[ 274.904101] x23: ffff000089770130 x22: 0000000000000000 x21: 0000000000000001
[ 274.904107] x20: ffff000089770080 x19: 0000000000000000 x18: 0000000000000000
[ 274.904113] x17: 0000000000000000 x16: ffffa525c79f4d44 x15: 0000ffff8c000b90
[ 274.904119] x14: 0000000000000000 x13: ffff000095cdcbc0 x12: 0000000000000001
[ 274.904125] x11: 00000000000000c0 x10: 874369b3e7d8db4b x9 : 5937b2b617660426
[ 274.904131] x8 : ffff000095cddd58 x7 : ffff0000a0bef600 x6 : 0000000000000008
[ 274.904137] x5 : 0000000016201000 x4 : 0000000000000001 x3 : ffffa52555aa9b10
[ 274.904143] x2 : 0000000000000001 x1 : 0000000000000001 x0 : ffff00008be84490
[ 274.904150] Call trace:
[ 274.904153] call_s_stream+0xdc/0xe8 [videodev]
[ 274.904186] tegra_channel_set_stream+0x27c/0x44c [tegra_camera]
[ 274.904218] vi5_channel_start_streaming+0x280/0x3f4 [tegra_camera]
[ 274.904249] tegra_channel_start_streaming+0x4c/0x78 [tegra_camera]
[ 274.904279] vb2_start_streaming+0x68/0x16c [videobuf2_common]
[ 274.904292] vb2_core_streamon+0xf8/0x1bc [videobuf2_common]
[ 274.904302] vb2_ioctl_streamon+0x4c/0x90 [videobuf2_v4l2]
[ 274.904311] v4l_streamon+0x24/0x30 [videodev]
[ 274.904344] __video_do_ioctl+0x330/0x3fc [videodev]
[ 274.904375] video_usercopy+0x2d0/0x7fc [videodev]
[ 274.904406] video_ioctl2+0x18/0x44 [videodev]
[ 274.904437] v4l2_ioctl+0x40/0x60 [videodev]
[ 274.904468] __arm64_sys_ioctl+0xac/0xf0
[ 274.904481] invoke_syscall+0x48/0x114
[ 274.904493] el0_svc_common.constprop.0+0xc0/0xe0
[ 274.904502] do_el0_svc+0x1c/0x28
[ 274.904510] el0_svc+0x30/0xd8
[ 274.904517] el0t_64_sync_handler+0x120/0x12c
[ 274.904522] el0t_64_sync+0x194/0x198
[ 274.904527] ---[ end trace 0000000000000000 ]---
[ 275.005238] tegra-i2c 3180000.i2c: I2C transfer timed out
[ 275.006638] regmap_util_write_table_8:regmap_util_write_table:-110
[ 275.006648] imx477 9-001a: Error writing mode
[ 275.125226] tegra-i2c 3180000.i2c: I2C transfer timed out
[ 275.125958] imx477 9-001a: imx477_write_reg: i2c write failed, 0x104 = 1
[ 275.126158] imx477 9-001a: imx477_set_group_hold: Group hold control error
[ 275.127571] ------------[ cut here ]------------
[ 275.127581] WARNING: CPU: 0 PID: 4235 at drivers/media/v4l2-core/v4l2-subdev.c:410 call_s_stream+0xdc/0xe8 [videodev]
[ 275.127632] Modules linked in: bnep governor_pod_scaling(O) qrtr usb_f_ncm usb_f_mass_storage nvidia_drm(O) nvidia_modeset(O) nvidia(O) nvgpu(O) usb_f_acm u_serial usb_f_rndis u_ether libcomposite snd_soc_tegra_controls(O) snd_soc_tegra_utils(O) snd_soc_tegra210_admaif snd_soc_tegra_pcm r8168(O) snd_soc_tegra186_asrc snd_soc_tegra210_sfc snd_soc_tegra210_mixer snd_soc_tegra210_ope snd_soc_tegra210_mvc snd_soc_tegra210_amx snd_soc_tegra210_i2s snd_soc_tegra210_adx snd_soc_tegra210_ahub tegra210_adma nvadsp(O) nvvrs_pseq_rtc(O) rtk_btusb(O) nvhost_nvcsi(O) nvhost_pva(O) btrtl nvhost_nvdla(O) btintel nvhost_vi5(O) btmtk btbcm bluetooth iwlmvm ecdh_generic ecc cp210x usbserial nvmap(O) crct10dif_ce nvsciipc(O) snd_soc_tegra_audio_graph_card mac80211 ivc_cdev(O) snd_soc_audio_graph_card snd_soc_simple_card_utils tegra234_oc_event(O) libarc4 fusb301(O) mttcan(O) nvpmodel_clk_cap(O) tegra_dce(O) iwlwifi arm_dsu_pmu nvpps(O) ina3221 can_dev thermal_trip_event(O) tegra_bpmp_bwmgr(O) tegra_cactmon_mc_all(O) cfg80211
[ 275.127740] nv_imx477(O) tegra234_aon(O) tegra_aconnect snd_hda_codec_hdmi at24 pwm_tegra_tachometer(O) snd_hda_tegra snd_hda_codec rfkill snd_hda_core optee_rng mc_hwpm(O) spi_tegra114 nvidia_vrs_pseq(O) rng_core host1x_fence(O) ramoops reed_solomon tpm_ftpm_tee camera_diagnostics(O) nvhost_isp5(O) tegra_capture_isp(O) tegra_camera(O) v4l2_dv_timings host1x_nvhost(O) tegra_drm(O) tegra_wmark(O) nvhwpm(O) drm_display_helper drm_dp_aux_bus cec host1x(O) tegra_camera_platform(O) mc_utils(O) capture_ivc(O) v4l2_fwnode v4l2_async videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 videodev videobuf2_common mc camchar(O) rtcpu_debug(O) tegra_camera_rtcpu(O) ivc_bus(O) hsp_mailbox_client(O) br_netfilter bridge stp llc nvme_fabrics fuse nfnetlink ip_tables x_tables ipv6 pwm_fan pwm_tegra tegra_bpmp_thermal tegra_xudc uas ucsi_ccg typec_ucsi typec nvme nvme_core phy_tegra194_p2u pcie_tegra194
[ 275.127850] CPU: 0 PID: 4235 Comm: CaptureSchedule Tainted: G W O 6.8.12-tegra #2
[ 275.127857] Hardware name: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit/Jetson, BIOS 39.2.0-gcid-45755727 06/01/2026
[ 275.127861] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 275.127867] pc : call_s_stream+0xdc/0xe8 [videodev]
[ 275.127900] lr : tegra_channel_set_stream+0x27c/0x44c [tegra_camera]
[ 275.127939] sp : ffff80008c76ba30
[ 275.127941] x29: ffff80008c76ba30 x28: ffffa525c9288a20 x27: ffffa525c8933000
[ 275.127948] x26: ffff000089770108 x25: ffffa525c8933008 x24: 0000000000000000
[ 275.127954] x23: ffff000089770130 x22: 0000000000000000 x21: 0000000000000001
[ 275.127960] x20: ffff000089770080 x19: 0000000000000000 x18: 0000000000000000
[ 275.127966] x17: 0000000000000000 x16: ffffa525c79f4d44 x15: 0000aaaacaaa1260
[ 275.127972] x14: 0000000000000000 x13: ffff000095cdcbc0 x12: 0000000000000001
[ 275.127978] x11: 00000000000000c0 x10: 874369b3e7d8db4b x9 : 5937b2b617660426
[ 275.127984] x8 : ffff000095cddd58 x7 : ffff0000a0bee000 x6 : 0000000000000008
[ 275.127990] x5 : 0000000020ce7000 x4 : 0000000000000001 x3 : ffffa52555aa9b10
[ 275.127996] x2 : 0000000000000001 x1 : 0000000000000001 x0 : ffff00008be84490
[ 275.128002] Call trace:
[ 275.128005] call_s_stream+0xdc/0xe8 [videodev]
[ 275.128038] tegra_channel_set_stream+0x27c/0x44c [tegra_camera]
[ 275.128068] vi5_channel_start_streaming+0x280/0x3f4 [tegra_camera]
[ 275.128099] tegra_channel_start_streaming+0x4c/0x78 [tegra_camera]
[ 275.128129] vb2_start_streaming+0x68/0x16c [videobuf2_common]
[ 275.128143] vb2_core_streamon+0xf8/0x1bc [videobuf2_common]
[ 275.128153] vb2_ioctl_streamon+0x4c/0x90 [videobuf2_v4l2]
[ 275.128162] v4l_streamon+0x24/0x30 [videodev]
[ 275.128195] __video_do_ioctl+0x330/0x3fc [videodev]
[ 275.128226] video_usercopy+0x2d0/0x7fc [videodev]
[ 275.128256] video_ioctl2+0x18/0x44 [videodev]
[ 275.128287] v4l2_ioctl+0x40/0x60 [videodev]
[ 275.128317] __arm64_sys_ioctl+0xac/0xf0
[ 275.128331] invoke_syscall+0x48/0x114
[ 275.128342] el0_svc_common.constprop.0+0xc0/0xe0
[ 275.128350] do_el0_svc+0x1c/0x28
[ 275.128358] el0_svc+0x30/0xd8
[ 275.128366] el0t_64_sync_handler+0x120/0x12c
[ 275.128371] el0t_64_sync+0x194/0x198
[ 275.128376] ---[ end trace 0000000000000000 ]---
[ 275.229216] tegra-i2c 3180000.i2c: I2C transfer timed out
[ 275.229868] regmap_util_write_table_8:regmap_util_write_table:-110
[ 275.229878] imx477 9-001a: Error writing mode
[ 279.511378] ------------[ cut here ]------------
[ 279.511395] WARNING: CPU: 1 PID: 4235 at drivers/media/v4l2-core/v4l2-subdev.c:410 call_s_stream+0xdc/0xe8 [videodev]
[ 279.511448] Modules linked in: bnep governor_pod_scaling(O) qrtr usb_f_ncm usb_f_mass_storage nvidia_drm(O) nvidia_modeset(O) nvidia(O) nvgpu(O) usb_f_acm u_serial usb_f_rndis u_ether libcomposite snd_soc_tegra_controls(O) snd_soc_tegra_utils(O) snd_soc_tegra210_admaif snd_soc_tegra_pcm r8168(O) snd_soc_tegra186_asrc snd_soc_tegra210_sfc snd_soc_tegra210_mixer snd_soc_tegra210_ope snd_soc_tegra210_mvc snd_soc_tegra210_amx snd_soc_tegra210_i2s snd_soc_tegra210_adx snd_soc_tegra210_ahub tegra210_adma nvadsp(O) nvvrs_pseq_rtc(O) rtk_btusb(O) nvhost_nvcsi(O) nvhost_pva(O) btrtl nvhost_nvdla(O) btintel nvhost_vi5(O) btmtk btbcm bluetooth iwlmvm ecdh_generic ecc cp210x usbserial nvmap(O) crct10dif_ce nvsciipc(O) snd_soc_tegra_audio_graph_card mac80211 ivc_cdev(O) snd_soc_audio_graph_card snd_soc_simple_card_utils tegra234_oc_event(O) libarc4 fusb301(O) mttcan(O) nvpmodel_clk_cap(O) tegra_dce(O) iwlwifi arm_dsu_pmu nvpps(O) ina3221 can_dev thermal_trip_event(O) tegra_bpmp_bwmgr(O) tegra_cactmon_mc_all(O) cfg80211
[ 279.511554] nv_imx477(O) tegra234_aon(O) tegra_aconnect snd_hda_codec_hdmi at24 pwm_tegra_tachometer(O) snd_hda_tegra snd_hda_codec rfkill snd_hda_core optee_rng mc_hwpm(O) spi_tegra114 nvidia_vrs_pseq(O) rng_core host1x_fence(O) ramoops reed_solomon tpm_ftpm_tee camera_diagnostics(O) nvhost_isp5(O) tegra_capture_isp(O) tegra_camera(O) v4l2_dv_timings host1x_nvhost(O) tegra_drm(O) tegra_wmark(O) nvhwpm(O) drm_display_helper drm_dp_aux_bus cec host1x(O) tegra_camera_platform(O) mc_utils(O) capture_ivc(O) v4l2_fwnode v4l2_async videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 videodev videobuf2_common mc camchar(O) rtcpu_debug(O) tegra_camera_rtcpu(O) ivc_bus(O) hsp_mailbox_client(O) br_netfilter bridge stp llc nvme_fabrics fuse nfnetlink ip_tables x_tables ipv6 pwm_fan pwm_tegra tegra_bpmp_thermal tegra_xudc uas ucsi_ccg typec_ucsi typec nvme nvme_core phy_tegra194_p2u pcie_tegra194
[ 279.511664] CPU: 1 PID: 4235 Comm: CaptureSchedule Tainted: G W O 6.8.12-tegra #2
[ 279.511671] Hardware name: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit/Jetson, BIOS 39.2.0-gcid-45755727 06/01/2026
[ 279.511675] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 279.511682] pc : call_s_stream+0xdc/0xe8 [videodev]
[ 279.511716] lr : tegra_channel_set_stream+0x27c/0x44c [tegra_camera]
[ 279.511755] sp : ffff80008c76ba30
[ 279.511758] x29: ffff80008c76ba30 x28: ffffa525c9288a20 x27: ffffa525c8933000
[ 279.511765] x26: ffff000089770108 x25: ffffa525c8933008 x24: 0000000000000000
[ 279.511772] x23: ffff000089770130 x22: 0000000000000000 x21: 0000000000000001
[ 279.511778] x20: ffff000089770080 x19: 0000000000000000 x18: 0000000000000000
[ 279.511784] x17: 0000000000000000 x16: ffffa525c79f4d44 x15: 0000000bbe2c6238
[ 279.511790] x14: 0000000000000001 x13: ffff000095cdcbc0 x12: 0000000000000001
[ 279.511796] x11: 00000000000000c0 x10: 874369b3e7d8db4b x9 : 5937b2b617660426
[ 279.511802] x8 : ffff000095cddd58 x7 : ffff0000a0befa00 x6 : 000000001db158fb
[ 279.511808] x5 : 0000000001000000 x4 : 0000000000000040 x3 : ffffa52555aa9b10
[ 279.511815] x2 : 0000000000000001 x1 : 0000000000000001 x0 : ffff00008be84490
[ 279.511821] Call trace:
[ 279.511824] call_s_stream+0xdc/0xe8 [videodev]
[ 279.511858] tegra_channel_set_stream+0x27c/0x44c [tegra_camera]
[ 279.511891] vi5_channel_start_streaming+0x280/0x3f4 [tegra_camera]
[ 279.511923] tegra_channel_start_streaming+0x4c/0x78 [tegra_camera]
[ 279.511953] vb2_start_streaming+0x68/0x16c [videobuf2_common]
[ 279.511967] vb2_core_streamon+0xf8/0x1bc [videobuf2_common]
[ 279.511977] vb2_ioctl_streamon+0x4c/0x90 [videobuf2_v4l2]
[ 279.511986] v4l_streamon+0x24/0x30 [videodev]
[ 279.512019] __video_do_ioctl+0x330/0x3fc [videodev]
[ 279.512050] video_usercopy+0x2d0/0x7fc [videodev]
[ 279.512081] video_ioctl2+0x18/0x44 [videodev]
[ 279.512112] v4l2_ioctl+0x40/0x60 [videodev]
[ 279.512143] __arm64_sys_ioctl+0xac/0xf0
[ 279.512156] invoke_syscall+0x48/0x114
[ 279.512168] el0_svc_common.constprop.0+0xc0/0xe0
[ 279.512177] do_el0_svc+0x1c/0x28
[ 279.512185] el0_svc+0x30/0xd8
[ 279.512192] el0t_64_sync_handler+0x120/0x12c
[ 279.512197] el0t_64_sync+0x194/0x198
[ 279.512202] ---[ end trace 0000000000000000 ]---
[ 279.613119] tegra-i2c 3180000.i2c: I2C transfer timed out
[ 279.613698] regmap_util_write_table_8:regmap_util_write_table:-110
[ 279.613709] imx477 9-001a: Error writing mode
[ 279.615384] ------------[ cut here ]------------
[ 279.615391] WARNING: CPU: 1 PID: 4235 at drivers/media/v4l2-core/v4l2-subdev.c:410 call_s_stream+0xdc/0xe8 [videodev]
[ 279.615436] Modules linked in: bnep governor_pod_scaling(O) qrtr usb_f_ncm usb_f_mass_storage nvidia_drm(O) nvidia_modeset(O) nvidia(O) nvgpu(O) usb_f_acm u_serial usb_f_rndis u_ether libcomposite snd_soc_tegra_controls(O) snd_soc_tegra_utils(O) snd_soc_tegra210_admaif snd_soc_tegra_pcm r8168(O) snd_soc_tegra186_asrc snd_soc_tegra210_sfc snd_soc_tegra210_mixer snd_soc_tegra210_ope snd_soc_tegra210_mvc snd_soc_tegra210_amx snd_soc_tegra210_i2s snd_soc_tegra210_adx snd_soc_tegra210_ahub tegra210_adma nvadsp(O) nvvrs_pseq_rtc(O) rtk_btusb(O) nvhost_nvcsi(O) nvhost_pva(O) btrtl nvhost_nvdla(O) btintel nvhost_vi5(O) btmtk btbcm bluetooth iwlmvm ecdh_generic ecc cp210x usbserial nvmap(O) crct10dif_ce nvsciipc(O) snd_soc_tegra_audio_graph_card mac80211 ivc_cdev(O) snd_soc_audio_graph_card snd_soc_simple_card_utils tegra234_oc_event(O) libarc4 fusb301(O) mttcan(O) nvpmodel_clk_cap(O) tegra_dce(O) iwlwifi arm_dsu_pmu nvpps(O) ina3221 can_dev thermal_trip_event(O) tegra_bpmp_bwmgr(O) tegra_cactmon_mc_all(O) cfg80211
[ 279.615537] nv_imx477(O) tegra234_aon(O) tegra_aconnect snd_hda_codec_hdmi at24 pwm_tegra_tachometer(O) snd_hda_tegra snd_hda_codec rfkill snd_hda_core optee_rng mc_hwpm(O) spi_tegra114 nvidia_vrs_pseq(O) rng_core host1x_fence(O) ramoops reed_solomon tpm_ftpm_tee camera_diagnostics(O) nvhost_isp5(O) tegra_capture_isp(O) tegra_camera(O) v4l2_dv_timings host1x_nvhost(O) tegra_drm(O) tegra_wmark(O) nvhwpm(O) drm_display_helper drm_dp_aux_bus cec host1x(O) tegra_camera_platform(O) mc_utils(O) capture_ivc(O) v4l2_fwnode v4l2_async videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 videodev videobuf2_common mc camchar(O) rtcpu_debug(O) tegra_camera_rtcpu(O) ivc_bus(O) hsp_mailbox_client(O) br_netfilter bridge stp llc nvme_fabrics fuse nfnetlink ip_tables x_tables ipv6 pwm_fan pwm_tegra tegra_bpmp_thermal tegra_xudc uas ucsi_ccg typec_ucsi typec nvme nvme_core phy_tegra194_p2u pcie_tegra194
[ 279.615643] CPU: 1 PID: 4235 Comm: CaptureSchedule Tainted: G W O 6.8.12-tegra #2
[ 279.615649] Hardware name: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit/Jetson, BIOS 39.2.0-gcid-45755727 06/01/2026
[ 279.615653] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 279.615659] pc : call_s_stream+0xdc/0xe8 [videodev]
[ 279.615691] lr : tegra_channel_set_stream+0x27c/0x44c [tegra_camera]
[ 279.615725] sp : ffff80008c76ba30
[ 279.615727] x29: ffff80008c76ba30 x28: ffffa525c9288a20 x27: ffffa525c8933000
[ 279.615734] x26: ffff000089770108 x25: ffffa525c8933008 x24: 0000000000000000
[ 279.615740] x23: ffff000089770130 x22: 0000000000000000 x21: 0000000000000001
[ 279.615746] x20: ffff000089770080 x19: 0000000000000000 x18: 0000000000000000
[ 279.615752] x17: 0000000000000000 x16: ffffa525c79f4d44 x15: 0000000000000000
[ 279.615757] x14: 0000000000000001 x13: ffff000095cdcbc0 x12: 0000000000000001
[ 279.615763] x11: 00000000000000c0 x10: 874369b3e7d8db4b x9 : 5937b2b617660426
[ 279.615769] x8 : ffff000095cddd58 x7 : ffff0000a0befa00 x6 : 0000000000000008
[ 279.615775] x5 : 00000000362b3000 x4 : 0000000000000001 x3 : ffffa52555aa9b10
[ 279.615782] x2 : 0000000000000001 x1 : 0000000000000001 x0 : ffff00008be84490
[ 279.615788] Call trace:
[ 279.615790] call_s_stream+0xdc/0xe8 [videodev]
[ 279.615822] tegra_channel_set_stream+0x27c/0x44c [tegra_camera]
[ 279.615852] vi5_channel_start_streaming+0x280/0x3f4 [tegra_camera]
[ 279.615883] tegra_channel_start_streaming+0x4c/0x78 [tegra_camera]
[ 279.615913] vb2_start_streaming+0x68/0x16c [videobuf2_common]
[ 279.615925] vb2_core_streamon+0xf8/0x1bc [videobuf2_common]
[ 279.615935] vb2_ioctl_streamon+0x4c/0x90 [videobuf2_v4l2]
[ 279.615944] v4l_streamon+0x24/0x30 [videodev]
[ 279.615976] __video_do_ioctl+0x330/0x3fc [videodev]
[ 279.616007] video_usercopy+0x2d0/0x7fc [videodev]
[ 279.616037] video_ioctl2+0x18/0x44 [videodev]
[ 279.616067] v4l2_ioctl+0x40/0x60 [videodev]
[ 279.616098] __arm64_sys_ioctl+0xac/0xf0
[ 279.616111] invoke_syscall+0x48/0x114
[ 279.616121] el0_svc_common.constprop.0+0xc0/0xe0
[ 279.616130] do_el0_svc+0x1c/0x28
[ 279.616137] el0_svc+0x30/0xd8
[ 279.616143] el0t_64_sync_handler+0x120/0x12c
[ 279.616148] el0t_64_sync+0x194/0x198
[ 279.616154] ---[ end trace 0000000000000000 ]---
[ 279.717121] tegra-i2c 3180000.i2c: I2C transfer timed out
[ 279.718707] regmap_util_write_table_8:regmap_util_write_table:-110
[ 279.718718] imx477 9-001a: Error writing mode
Once this issue occurs, the cameras cannot be opened again unless I reboot the Orin NX. However, if I only use a single camera, the camera can be closed and reopened normally without this issue.
This problem does not occur on other Jetson Linux versions, such as the 35.x and 36.x series.
