Jetson Linux with Ceph (rbd)
I am trying to setup my Jetson AGX Orin Developer Kit as part of a Kubernetes cluster with Ceph used for persistent storage. I need the rbd kernel module but it looks like Jetson Linux does not include it. I don’t know if I need to compile a new kernel or just build the module… And either way, how to do it.
Thanks for the help!
Do you know which config(s) have to be enabled? If yes, you can refer to kernel section in developer guide to enable them and rebuild kernel image.
So from what I have found I should set the flag CONFIG_BLK_DEV_RBD, but that seems to be set in the /boot/config already, but the .ko file isn’t there.
$ cat /boot/config-5.15.0-107-generic | grep CONFIG_BLK_DEV_RBD
CONFIG_BLK_DEV_RBD=m
Any more info on how to get the in tree kernel mods installed that don’t come with the Nvidia kernel?
By default it is not enabled:
$ zcat /proc/config.gz | grep CONFIG_BLK_DEV_RBD
# CONFIG_BLK_DEV_RBD is not set
Please follow developer guide to enable the config and try on AGX Orin developer kit:
Kernel Customization — NVIDIA Jetson Linux Developer Guide 1 documentation
