Hello
The internal hardware clock of the Jetson module seems to be running faster than the actual time.
If I run systemd-timesync.service and do not synchronize with an NTP server, it gets faster and faster. Is there a way to synchronize without NTP?
Regards.
kayccc
4
Sorry for the late response.
shgarg
5
is this seen on rel-35 or rel-36 ? Is RTC default here tegra rtc or vrs rtc ?
You can get this by:
cat /sys/class/rtc/rtc0/name
Check the version by below command.
cat /etc/nv_tegra_release
system
Closed
8
