We have two 900-13767-0000-001 modules that are experiencing INA voltage rail failures. The part numbers are exactly P3767, 180-13767-DAAA-A13. I assume they are different batches or there may be other identifying marks that would help, let me know. I’ve attached some pics of the serial output from each module.
We have a custom carrier board and at some point, during operation, the application product experienced some user interaction that led to the Jetson module being damaged (I assume, because hardware doesn’t typically randomly die when the environment remains stable). I am unable to trace back the user error that may have caused this, but the carrier custom board CAN bus transceiver is not functional on the first, and the second is not enumerating on the USB bus.
The exact error is PMIC_CONFIG reason 0x1C and “Can’t get handle to i2c device @4”. Both seem to show similar issues.
We’re wondering what voltage rail failed because two forum posts I found end at this finding with the moderator stating the hardware is damaged.
I want to help my team avoid damaging another unit. I would be surprised if this was caused by ESD, but perhaps our carrier board lacks the proper TVS protection. This is definitely a hardware failure on the carrier or module likely caused by user grounding issues or perhaps a surge event, but I’m wondering if anyone has insight into what causes this PMIC rail to die on the Jetson.
Has NVIDIA seen this issue on other Orins? Do you have specific recommendations to resolve this? Do you know what voltage rail is monitored by the NVIDIA i2c device 4 that would help me debug my carrier board further?
I basically want to know what I can do in the future to avoid damaging more Orins. If an RMA would be recommended, we can go that route but would like to get to root cause.
