Jetson Multimedia API 09_camera_jpeg_capture Performance
Hi.
Would you tell me why the frame rate of the 09_camera_jpeg_capture sample code of Jetson Multimedia API is low even at JPEG encode disabled?
The frame rate is around 21fps for 1280x720 resolution at JPEG encode disabled on Jetson Nano dev kit.
My camera is the Raspberry Pi v2 camera.
jetson@jetson-desktop:~/jetson_multimedia_api/samples/09_camera_jpeg_capture$ ./camera_jpeg_capture --pre-res 1280x720 --img-res 1280x720 --cap-time 5 --fps 60 --disable-jpg -s
[INFO] (NvEglRenderer.cpp:110) <renderer0> Setting Screen width 1280 height 720
PRODUCER: Creating output stream
PRODUCER: Launching consumer thread
CONSUMER: Waiting until producer is connected...
PRODUCER: Available Sensor modes :
PRODUCER: [0] W=3264 H=2464
PRODUCER: [1] W=3264 H=1848
PRODUCER: [2] W=1920 H=1080
PRODUCER: [3] W=1640 H=1232
PRODUCER: [4] W=1280 H=720
PRODUCER: [5] W=1280 H=720
PRODUCER: Requested FPS out of range. Fall back to 30
PRODUCER: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
CONSUMER: Done.
----------- Element = renderer0 -----------
Total Profiling time = 4.94986
Average FPS = 21.0107
Total units processed = 105
Num. of late units = 104
PRODUCER: Done -- exiting.
When I measure the frame rate with GStreamer on the same hardware configuration, the FPS reaches around 60fps.
jetson@jetson-desktop:~/jetson_multimedia_api/samples/09_camera_jpeg_capture$ gst-launch-1.0 -v nvarguscamerasrc ! 'video/x-raw(memory:NVMM), format=NV12,width=1280, height=720, framerate=60/1' ! fpsdisplaysink video-sink=nvoverlaysink text-overlay=false
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstNvOverlaySink-nvoverlaysink:nvoverlaysink-nvoverlaysink0: sync = true
Setting pipeline to PLAYING ...
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
New clock: GstSystemClock
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstNvOverlaySink-nvoverlaysink:nvoverlaysink-nvoverlaysink0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
GST_ARGUS: Creating output stream
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 5
   Output Stream W = 1280 H = 720
   seconds to Run    = 0
   Frame Rate = 120.000005
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 32, dropped: 0, current: 62.40, average: 62.40
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 63, dropped: 0, current: 60.03, average: 61.21
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 94, dropped: 0, current: 60.05, average: 60.83
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 125, dropped: 0, current: 60.05, average: 60.63
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 156, dropped: 0, current: 60.03, average: 60.51
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 187, dropped: 0, current: 60.07, average: 60.44
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 218, dropped: 0, current: 60.05, average: 60.38
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 249, dropped: 0, current: 60.03, average: 60.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 280, dropped: 0, current: 60.05, average: 60.31
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 310, dropped: 0, current: 59.96, average: 60.27
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 341, dropped: 0, current: 60.13, average: 60.26
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 372, dropped: 0, current: 59.98, average: 60.24
It seems that the sample code does not take the frame duration value for the 1280x720 resolution but for the 3264x2464 resolution.
I’ve solved the issue with the --sensor-mode option like bellow.
$ ./camera_jpeg_capture --pre-res 1280x720 --img-res 1280x720 --cap-time 5 --fps 60 --sensor-mode 5 --disable-jpg -s
CONSUMER: Done.
Total Profiling time = 4.95005
Average FPS = 59.9994
Total units processed = 298
Num. of late units = 0
Good to know issue resolved, thanks for the update!
