Jetson Nan-TAO Toolkit
Hi, first of all, I want to use the TAO Toolkit with jetson nano, and I received a feedback from nvidia’s partners as “You can work with the TAO Toolkit with jetson nano”.However, there are no minimum system requirements on jetson nano. Can I use TAO toolkit with jetson nano?
TAO is designed on training on the platform with x86-based CPU and discrete GPUs.
After training, user can deploy to model to run inference on discrete GPUs or any Jetson devices(for example, Orin, Xaiver, etc)
So, if you run training, it is not supported in Jetson devices. If you run inference, it is supported in both dgpu devices and Jetson devices.
