JETSON NANO 2GB camera
Is the JETSON NANO 2GB hardware fully compatible with 4GB? With the NANO 2GB carrier board designed by myself, can four cameras be turned on at the same time?
The HW connection is the same. Should be able working if the sensor not support high fps and higher resolution.
