I have a problem with my Jetson Nano 2GB. I turned on and started to setup when it suddenly turn off when I was in the Linux configuration. I use a 5v 3A power supply as the manual recommend. I check if the power supply was ok and I even try in other device and worked well. So I think the problem is on the board. What should I do?
Is the LED on the board still ON?
No, it does not
Then I think it is time to RMA this board.
