I’m trying to setup my Jetson nano headless mode. During configuration I provide to WiFi’s WPA/PSK key but WiFi not configuring.
It give me " Failure of key exchange and association"
I’m double check every thing but I recive this error again and again.!
If I pass this step, after the finishing setup I can’t edit /etc/wpa_supplicant.conf file because of permission restrictions. When I try to change this file permission using chmod It’s need root password. Configurator not ask me set the root password.
The solution for me was to select the option to manually enter my network SSID in the setup dialog. When I entered the network name manually, rather than selecting it from the list, the connection was successful. It may have just been a fluke, but it might be worth a try if you’re facing this issue.
