Jetson Nano (젯팩4.6.1)에 pytorch1.10버전을 설치했는데 pytorch1.8.0이 설치된 것으로 확인됩니다
다음 과정을 통해서 설치를 진행했습니다.
어디서 문제가 있었던 걸까요?
  24  wget https://nvidia.box.com/shared/static/p57jwntv436lfrd78inwl7iml6p13fzh.whl -O  torch-1.10.0-cp36-cp36m-linux_aarch64.whl
  25  ls
  26  sudo apt-get install python3-pip libopenblas-base libopenmpi-dev libomp-dev
  27  ls
  28  sudo apt-get install python3-pip libopenblas-base libopenmpi-dev libomp-dev
  29  pip3 install Cython
  30  pip3 install numpy torch-1.10.0-cp36-cp36m-linux_aarch64.whl
  31  clear
  32  ls
  33  python3
  34  history
nvidia@nvidia-desktop:~/Downloads$ python3
Python 3.6.9 (default, Mar 15 2022, 13:55:28)
[GCC 8.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import torch
>>> torch.__version__
'1.8.0'
Thank you.
You will need to update the link to version 1.10 as well.
For example:
$ wget https://nvidia.box.com/shared/static/fjtbno0vpo676a25cgvuqc1wty0fkkg6.whl -O torch-1.10.0-cp36-cp36m-linux_aarch64.whl
$ pip3 install torch-1.10.0-cp36-cp36m-linux_aarch64.whl
