could you please point-out what’s the issue? did you meant there’s ERROR Transfer failure?
may I also confirm what’s your real use-case, or, how you reproduce the failure on Jetson Nano developer kit?
42.415680] tegra-xusb 70090000.xusb: ERROR Transfer event TRB DMA ptr not part of current TD ep_index 2 comp_code 4
[ 42.426191] tegra-xusb 70090000.xusb: Looking for event-dma 00000000ffd4dd10 trb-start 00000000ffd4cd20 trb-end 00000000ffd4cd20 seg-start 00000000ffd4c000 seg-end 00000000ffd4cff0
[ 102.035348] usb 2-1.1: reset SuperSpeed USB device number 3 using tegra-xusb
[ 102.060007] usb 2-1.1: Not enough bandwidth for new device state.
[ 102.066139] usb 2-1.1: Not enough bandwidth for altsetting 17
[ 102.066144] usb 2-1.1: failed to restore interface 1 altsetting 17 (error=-28)
Its keep on doing this even though i have connected with external usb hub with power supply and connect the camera to it,
It is reproduced by connecting the USB3.0 camera to Jetson nano. after sometime it is coming up with these logs on jetson nano
215.761285] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 216.209249] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 217.185310] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 218.529301] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 218.977302] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 227.665359] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 228.085490] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 228.505429] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 229.137187] usb 2-1.1: Device not responding to setup address.
[ 229.360983] usb 2-1.1: Device not responding to setup address.
[ 229.572738] usb 2-1.1: device not accepting address 5, error -71
[ 229.905360] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 231.937488] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 234.821520] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 235.317488] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 236.713462] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 237.201467] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 260.305634] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 261.265687] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 262.337655] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 262.769727] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 264.085700] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 265.073668] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 265.653880] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 267.089698] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 268.481766] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 269.329712] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 270.757689] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
[ 271.533706] usb 2-1.1: reset SuperSpeed USB device number 5 using tegra-xusb
is it effect camera functionality? are you able to enable preview stream by gst pipeline?
for instance, $ gst-launch-1.0 -v v4l2src device=/dev/video1 ! video/x-raw,framerate=30/1,width=640,height=480 ! xvimagesink
besides, r32.6.1 is really old release version.
please try moving to the latest rel-32 public release, (i.e. linux-tegra-r3275) for verification.
We use our partner AI who recommends jetpack 4.6 as their stable version.
most of the devices are working as expected but few of them are having these glitches,
