Description of my enviornment:
- I’m using L4T 32.7.2 release.
- Ii ran the following command
Command I ran for testing fuse burning and my PEM key:
sudo ./odmfuse.sh --noburn -i 0x21 -c PKC -k //rsa_priv.pem
and this gave me following output:
*** Calculating HASH from keyfile /<Some-path>/rsa_priv.pem ... done
PKC HASH: 0x646ee1f3d78a98ab84d68*********3133bba9ed458c800*********
*** Generating fuse configuration ... done.
*** Start preparing fuse configuration ...
*** done.
**after that I removed the –noburn flag and ran the command again:**
sudo ./odmfuse.sh -i 0x21 -c PKC -k /home/path/rsa_priv.pem
This gave me the below output
*** The fuse configuration is saved in bootloader/odmfuse_pkc.xml
*** The ODM fuse has been burned successfully.
*** done.
**As the output of the above command is successful so I assumed that PKC addition and fuse burning was successful**
./flash.sh -u /home/path/rsa_priv.pem -r jetson-nano-emmc mmcblk0p1
L4T BSP Information:
R32 , REVISION: 7.2
Target Board Information:
Name: jetson-nano-emmc, Board Family: t210ref, SoC: Tegra 210,
OpMode: production, Boot Authentication: ,
Disk encryption: disabled ,
Error: The RSA key file is provided for non-PKC protected target board.
**but while running above command I am getting error, could you please help **
**Because when I am flashing without PKC key it is working but with key getting above error unable to flash with key**
