I tried to translate the RPi overlay to Jetson Nano format. That is what i got:
/dts-v1/;
/plugin/;
overlay-name = "Audioinjector Ultra";
jetson-header-name = "Jetson 40pin Header";
compatible = "nvidia,jetson-nano", "nvidia,jetson-xavier", "nvidia,jetson-tx2", "nvidia,jetson-tx1", "nvidia,tegra210";
fragment@0 {
target = <&tegra_i2s4>;
__overlay__ {
status = "okay";
fragment@1 {
target = <&i2c1>;
__overlay__ {
#address-cells = <1>;
#size-cells = <0>;
status = "okay";
cs4265: cs4265@4e {
#sound-dai-cells = <0x0>;
compatible = "cirrus,cs4265";
reg = <0x4e>;
reset-gpios = <&gpio 149 0>;
status = "okay";
fragment@2 {
target = <&tegra_sound>;
__overlay__ {
compatible = "simple-audio-card";
i2s-controller = <&tegra_i2s4>;
status = "okay";
simple-audio-card,name = "audioinjector-ultra";
simple-audio-card,widgets =
"Line", "OUTPUTS",
"Line", "INPUTS";
nvidia,audio-routing =
"OUTPUTS","LINEOUTL",
"OUTPUTS","LINEOUTR",
"OUTPUTS","SPDIFOUT",
"LINEINL","INPUTS",
"LINEINR","INPUTS",
"MICL","INPUTS",
"MICR","INPUTS";
simple-audio-card,format = "i2s";
simple-audio-card,bitclock-master = <&sound_master>;
simple-audio-card,frame-master = <&sound_master>;
simple-audio-card,cpu {
sound-dai = <&tegra_i2s4>;
dai-tdm-slot-num = <2>;
dai-tdm-slot-width = <32>;
sound_master: simple-audio-card,codec {
sound-dai = <&cs4265>;
system-clock-frequency = <12288000>;
After reboot I got this error from dmesg:
[ 2.416875] No Device Node present for smmu client: snd-soc-dummy !!
[ 2.416884] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 2.416963] iommu: Adding device snd-soc-dummy to group 37
[ 2.421346] OF: /sound/simple-audio-card,cpu: could not get #sound-dai-cells for /aconnect@702c0000/ahub/i2s@702d1300
[ 2.427955] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 2.432222] asoc-simple-card sound: parse error -22
[ 2.435693] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 2.437216] asoc-simple-card: probe of sound failed with error -22
Any ideas?
