Jetson nano and iscsi module support
Once you have that information, if you need tips on building and installing, then that can be answered. Hopefully it can all be built as a module (or at least the features for the iSCSI).
Incidentally, I have used this before as a method of access for cloning from a failing system to a new drive via a Jetson in-between. Long ago I experimented with this, and found the performance to be quite good on a Jetson despite the difficulty in initial setup.
