Hi
I am working on Jetson Nano and would like run an android application. I believe this is possible for a some linux systems by installing “Anbox”. Is it possible to run an android application in Jetson Nano? If yes is there an example or procedure to install the required libraries.
I saw somwhere at the forum - folks used quemu on jetson;
if the android OS can be loaded into the emulator it might work, but I did not try, neither sure if the performance will not be a show-stopper
At the moment Android is not officially supported on the jetson nano. Perhaps at a later point of time there might be some community effort to port it to nano.
Android is available officially only for Jetson TK1.
In the meantime the best one can do is to run it on a emulator like qemu with some additional performance tricks. See this post here:
Jetson Nano Developer Kit is a small, powerful computer that lets you run multiple neural networks in parallel for applications like image classification, object detection, segmentation, and speech processing. All in an easy-to-use platform that runs in as little as 5 watts. mybkexperiencemcdvoice
